GruntGR Αύγουστος 18, 2005 #41 Αύγουστος 18, 2005 καμια σχεση, απλα σου δινει μια ιδεα για το ποσο ανταποκρισιμο ειναι το ασυρματο η ενσυρματο σου απο αποψη διαυλου και να δεις αν λειτουργει το 250hz hack πχ χωρις προβληματα, αμα το παει ο μορφεας το mx510 στα 500hz θα παρατηρησει οτι αυτα τα 500hz ΔΕΝ ειναι σταθερα και πρεπει να το κουναει ΣΥΝΕΧΕΙΑ, οποτε τον βλεπω να σταματησει να καμπερωνεται και να κουναει το στοχαστρο σαν μανιακος για να ειναι παντα στα 500hz :P επισης το usb port hack βοηθαει στο να εξαλειφτει το φαινομενο του negative accel σε περιπτωση που εχεις mouse με 8bit data path και 800dpi sensor sensitivity οπως το all time classic mx500, more info εδω : First, a couple of facts ... Windows XP and the USB low speed HID protocol supports an 8 BYTE data packet = 64 bits maximum size. Windows XP restricts the USB low speed HID protocol to a 8ms-polling rate contrary to USB spec. Windows 2000 and ME comply with the USB spec. This is why we had to find another way around instead of increasing polling rate; it wont work in WinXP (but it will work, in OSX and Linux, for instance). The 8 bit data packet is just a convention that most mice use to report X/Y information. There is in fact no such restriction in Windows, as long as the total information sent, including things like button presses etc, does not exceed 64 bits. How much data is apportioned to X/Y is determined by the FIRMWARE of the mouse, the default drivers on the OS will take their cue from the firmware and receive data accordingly (the beauty of USB plug and play). The problem with 8 bits for X/Y info is well known. -127/+127 (left/right) is the maximum info that can be sent, resulting in a very low maximum top speed of around 11 per second at 800dpi and 6400 frames per second. On top of this problem, the old MX500 did not have buffer overflow protection, so if it exceeded +127 instead of staying at +127, it would either error and reset to zero, or worse, reset to -127, resulting in the mouse going in the OPPOSITE direction as fast as possible! With 12 bits, the maximum is -2048/+2048; with 16bits the maximum is -32k/+32k. 2) Connection speed/baud The next critical link to performance is the connection between the mouse and the computer. USB 1.0 has a polling rate fixed at 125 polls/sec and allows for communication to and from the peripheral. See below (HID Drivers) for advanced 16-bit data-rate technology for the Diamondback. φυσικα στην περιπτωση των logitech me 800dpi κι 8bit data path υπαρχει ενα utility για το mouseware το οποιο σου επιτρεπει να πας τα dpi απο 800 σε 400 και ετσι all problems solved απλα πας απο "precision" σε "speed" και κανεις reboot, το μονο που θα χασεις θα ειναι το 2πλασιο sensitivity απτην μανα του, χρησιμο σε αναλυσεις 1152 κ πανω αμα δουλευεις σε photoshop πχ αφου αμα το πειραξεις απτα μουφο xp και το πας πανω απτην μεση δεν θα μπορεις στο τελος να σημαδεψεις το pixel που θελεις, στα FPS/TPS ειναι καπως διαφορετικη ιστορια υπαρχουνε επιτυχημενοι high sens players( fisker απο SK|swe cs squad, zero4 απο την Q3 scene ) αλλα θελει πολλη εξασκηση και ισως χρειαστει και τweaking για περισσοτερα σχετικα με ta mice πηγαινε www.razerone.com κ κανε κλικ εκει που λει razer technology
Qlim4X Αύγουστος 18, 2005 #42 Αύγουστος 18, 2005 υπαρχει καπιο προγραμα που να μετραει την ανταποκρισει του ποντικιου σου???
GruntGR Αύγουστος 18, 2005 #43 Αύγουστος 18, 2005 μην βιαζεστε να απαντησετε, μολις εμαθα οτι ειναι κατοχος ασυρματου ball mouse ακομα και το 2 χρονων(made in 2001 ομως) ποντικι μου απο αυτην την αποψη σκιζει http://geocities.com/gougougr2000/msintelioptical1.1.JPG πολυ :OT: βγηκαμε παντως
Qlim4X Αύγουστος 18, 2005 #44 Αύγουστος 18, 2005 που θα βρουμε αυτο το προγραματακι ρε τρελε???(αυτο που εχειθς σε sceenshot
Qlim4X Αύγουστος 18, 2005 #45 Αύγουστος 18, 2005 ασε το βρικα και μου εβαλε 54max δηλαδη ποσο κακο ειναι αυτο????
GruntGR Αύγουστος 18, 2005 #46 Αύγουστος 18, 2005 κοιτα δεν ειναι κακο ..... ειναι ΠΟΛΥ ΚΑΚΟ :P:P:P αλλοι σκιζουν με τα 125( google cooller )αλλοι σκιζονται να το πανε στα 250hz αλλοι περιμενουν το copperhead με τα 1000hz, κλαφτα χαραλαμπε ακομα και για desktop 50hz ειναι αισχρα και ακομα και στο desktop η διαφορα φαινεται και με το ματι αφου θα βλεπεις πιο ομαλη κινηση του κερσορα, με 50 hz υποθετω πως το βλεπεις λες και εχει λοξυγγα
Qlim4X Αύγουστος 18, 2005 #47 Αύγουστος 18, 2005 Αρχική απάντηση από GruntGR κοιτα δεν ειναι κακο ..... ειναι ΠΟΛΥ ΚΑΚΟ :P:P:P αλλοι σκιζουν με τα 125( google cooller )αλλοι σκιζονται να το πανε στα 250hz αλλοι περιμενουν το copperhead με τα 1000hz, κλαφτα χαραλαμπε ακομα και για desktop 50hz ειναι αισχρα και ακομα και στο desktop η διαφορα φαινεται και με το ματι αφου θα βλεπεις πιο ομαλη κινηση του κερσορα, με 50 hz υποθετω πως το βλεπεις λες και εχει λοξυγγα καπος ετσι λες και κανει πολυ μικρα πηδιματακια τσουπ τσουπ τσουπ παντος στο αλλο pc με ενα microsoft optical εχω 125 λολολολ
trendy Αύγουστος 18, 2005 #48 Αύγουστος 18, 2005 και το mx1000 που τωρα που ξαναβλεπω την pic αποτι βλεπω μονο σταθερα δεν ειναι αυτα τα 130 hz Είναι επειδή έκανα μια μικρή κίνηση αριστερά-δεξιά. Αν το τραβήξω όλο μια ευθεία τα νούμερα είναι μεγαλύτερα και ο μ.ό. ξεπερνάει τα 130. edit Έκανα το αντίστοιχο με τα ποντίκι στη usb και δεν παρατήρησα ουσιαστική διαφορά.
