Aνέκδοτα και όχι μόνο...
jax7480
Λέει ο άνδρας στην γυναίκα του:
- Βαλε το παλτό σου, αγάπη μου, θα πάω στο μπαρ.
- Θα με πάρεις μαζί για ένα ποτό; απαντάει χαρούμενα η γυναίκα.
- Μην λες βλακείες, της απαντάει... Θα κλείσω το καλοριφέρ !!!
:laughing: :laughing:
  • Replies 7k
Αρχική απάντηση από astrolabos [Σήμερα, στις 15:03]
καλο! :kiss::upside::hehe: :hehe: :hehe::rofl:
Αρχική απάντηση από astrolabos [Χθες, στις 15:03]
Πολύ gentle-man ο τύπος :hehe:
"Hello?"
"Hi honey. This is Daddy. Is Mommy near the phone"
"No Daddy. She's upstairs in the bedroom with Uncle Paul."
After a brief pause, Daddy says,
"But honey, you haven't got an Uncle Paul."
" Oh yes I do, and he's upstairs in the room with Mommy, right now ."
Brief Pause.
"Uh, okay then, this is what I want you to do. Put the phone down on the table,
run upstairs and knock on the bedroom door and shout to Mommy that Daddy's car
just pulled into the driveway."
"Okay Daddy, just a minute."
A few minutes later the little girl comes back to the phone.
"I did it Daddy."
"And what happened honey?" he asked.
" Well, Mommy got all scared, jumped out of bed with no clothes on and ran around screaming. Then she tripped over the rug, hit her head on the dresser and now she isn't moving at all!"
"Oh my God!!! What about your Uncle Paul?"
"He jumped out of the bed with no clothes on, too. He was all scared and he jumped out of the back window and into the swimming pool.
But I guess he didn't know that you took out the water last week to clean it.
He hit the bottom of the pool and I think he's dead."
***Long Pause***
***Longer Pause***
***Even Longer Pause***
Then Daddy says,
"Swimming pool? . . . Is this 486-5731?"
:rofl:
Αρχική απάντηση από jpavly [Σήμερα, στις 16:28]
"Hello?"
Brief Pause.
"I did it Daddy."
***Long Pause***
***Longer Pause***
Then Daddy says,
:rofl:
Το ιδιο το ξερω σε ελληνικη εκδοση:
Τηλεφωνει ενας πλουσιος σπιτι του και το σηκωνει ο μπατλερ:
-Που ειναι η γυναικα μου;
-Ειναι στο κρεβατι με αλλον αντρα
-Παρε το οπλο και σκοτωσε τους και τους δυο!!
(Μετα απο λιγα λεπτα)
-Ενταξει κυριε,το εκανα και πεταξα το οπλο στην πισινα
-Στην πισινα?? Ωχ συγνωμη λαθος νουμερο πηρα!!
[18:04] * AnimeGR has joined #gamers
[18:04] * ChanServ sets mode: +o AnimeGR
[18:04] <john2> einai toso grothoi ekei sthn Ubisoft pou oute kan kseroun oti oi Core2Duo den einai xronismenoi se ypshla Ghz k to auto-config tou Rainbow Six: Las Vegas mou vgazei minimum thn CPU
[18:04] <john2> ELEOOOOOOOOOOOOS NUBIDES
[18:05] <AnimeGR> axaxaxaxaxa
[18:05] <AnimeGR> mipws anagnwrizei to midi case?
[18:05] <john2> XaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXaXa
[18:05] <GruntGR> AHAHAHAHAHAHAHA
[18:06] <GruntGR> pou na ihes 6300 :p
[18:06] <GruntGR> 8a isouna katw apta 2ghz kai den 8a ekane run
[18:06] <john2> den les pou ton exw overclocked. To minimum leei 3Ghz
[18:06] <GruntGR> ?
[18:06] <GruntGR> AAHAAHAHAHAHAHAHAAHAHA
[18:06] <john2> ama leme oti tous aksizei fola kati kseroume
[18:06] <AnimeGR> AXaxaxaxaxaxaxaxaa
Γιατί κάποτε στην κορυφή του χριστουγεννιάτικου δέντρου αντί για αστέρι έχει άγγελο;
Όπως κάθε χρονιά, στο χωριό του Αι-Βασίλη φτιάχνουν τα παιχνίδια και τα στολίδια για τα Χριστούγεννα. Ο Αι-Βασίλης έχει στις εντολές του ξωτικά και αγγέλους.
20 μέρες πριν τα Χριστούγεννα μαζεύει ο ΑιΒασίλης τα ξωτικά και τους αγγέλους για να αρχίσουν τις δουλειές.
-"Έχουμε 6 μηχανές, με 8 ώρες δουλειά την μέρα προλαβαίνουμε μια χαρά".
Στέλνει έναν άγγελο να βρει και να κόψει το καλύτερο έλατο, άλλον να κόψει ξύλα για το τζάκι, άλλον να καθαρίζει τα χιόνια και έχει τα ξωτικά να δουλεύουν στις μηχανές.
3 μέρες μετά που ξεκίνησαν να δουλεύουν χαλάει η μια μηχανή. Λέει ο ΑιΒασίλης στα ξωτικά, "Τώρα πρέπει να δουλέψουμε παραπάνω, 10 ώρες την ημέρα αντί 8"
4 μέρες μετά χαλάει και δεύτερη μηχανή. " 12 ώρες την μέρα, σφιχτείτε λίγο αλλά θα τα καταφέρουμε"
5 μέρες μετά μένουν με τις μισές μηχανές... "14 ώρες την μέρα, δεν υπάρχει άλλη λύση"
6 μέρες μετά χαλάνε 2 από τις 3 μηχανές που μείνανε...
Να δουλεύουν όλη μέρα τα ξωτικά, να έχει πάθει 2 εγκεφαλικά και 3 εμφράγματα ο ΑιΒασίλης...
Και σκάει μύτη ο άγγελος με το έλατο:
-"’γιε Βασίλη, πού να το βάλω το δέντρο;"
Αρχική απάντηση από Nognir
Αρκάς :-)
Ε ρε και να κατσει κανας τετοιος σε ερασιτεχνικο στην Ελλαδα:D θα ξεπουλησουν οι μαναβηδες:rofl:
