DVD Decrypter - Πάπαλα!
spc
  • Replies 66
Καλή φάση!!! :)
Ας ελπίσουμε οτι θα δουμε και καποια αναβαθιση συντομα, οχι τιποτα σπουδαιο, ετσι για την τιμη των οπλων...
  • 3 weeks later...
ImgBurn carries on from where DVD Decrypter left off! (Well, for the burning part anyway!)
ImgBurn can write most types of CD / DVD images and it supports all the latest writers (including booktype / bitsetting on many of the major ones - i.e. BenQ, LiteOn, NEC, Plextor, Sony). You can even use ImgBurn to erase / format your rewritable media!
ImgBurn will try its very best to burn your DVD-Video double layer images using the layer break you've specified in the IFO files, but it can also calculate the best place for you, to save you the trouble.
Advanced functionality can be found in context menus that appear when you right click on various bits of the user interface. Can you find them all??!!
Απο τον author του DVD Decrypter
http://www.imgburn.com/index.php?act=news
