GFFermari Μάϊος 20, 2021 #241 Μάϊος 20, 2021 First details revealed for AMD Super Resolution, will be using AI neural networks WWW.DSOGAMING.COM According to a patent that was filled by the red team, AMD Super Resolution will be using AI neural networks in order to improve the image. Quote In its patent, AMD explains that the conventional super-resolution techniques are not that great. According to the red team, these solutions result in blurry and/or corrupted images. Thus, AMD promises to provide devices and methods for efficiently super-resolving an image, which preserves the original information of the image while upscaling the image and improving fidelity. The devices and methods utilize linear and non-linear up-sampling in a wholly learned environment. The AI neural network which AMD calls “GSR” will efficiently super resolve images in a convolutional and generalizable manner. The GSR architecture will render games at lower resolutions and upscale them to higher resolutions. Similar to DLSS, it aims to create high-quality image approximations and achieve high framerates. 1
DEADLAZARUS Ιούνιος 17, 2021 #242 Ιούνιος 17, 2021 AMD Radeon RX 6900 XT LC Specs Confirmed: 12% Higher Core and Memory Clocks, 10% Higher Power WWW.TECHPOWERUP.COM A leaked SKU sheet posted to Twitter by VideoCardz confirmed that AMD is indeed positioning the Radeon RX 6900 XT Liquid Cooled (LC) as a SKU separate from the RX 6900 XT. The finalized specs...
minast Ιούλιος 7, 2021 #243 Ιούλιος 7, 2021 Μήπως πλησιάζει η ώρα που θα πάρουμε GPU? Οι τιμές είναι στο καλύτερο σημείο τους από τον Γενάρη, και ελπίζουμε ότι θα πέσουν κι άλλο: GPU prices in Germany are now the lowest since February - VideoCardz.com VIDEOCARDZ.COM A sharp decline in GPU pricing in just 2 weeks According to a report by 3DCenter, NVIDIA Ampere and AMD RDNA2 GPUs have now reached a pricing level from February. The report is based on the...
icy20 Ιούλιος 7, 2021 #247 Ιούλιος 7, 2021 Υπαρχουν καρτες ποιος ειπε οτι δεν υπαρχουν και σχεδον σε τιμες msrp καποιες...
tommybertsen Ιούλιος 7, 2021 #248 Ιούλιος 7, 2021 Και κρατάς την πληροφορία για σένα; Δηλαδή βλέπεις πουθενά κάποια 1660 Super ας πούμε ή μιλάμε μόνο για 3080 και άνω;
ARMAGEDDON Ιούλιος 7, 2021 Author #249 Ιούλιος 7, 2021 (edited) 1 hour ago, icy20 said: Υπαρχουν καρτες ποιος ειπε οτι δεν υπαρχουν και σχεδον σε τιμες msrp καποιες... μπα με πιο λίγα λεφτά πήρα OLED 55 από ότι κάρτα ! XBOX series X + OLED 55" 1500 EURO <--- FLEX @icy20 σου έρχομαι απο κονσόλα στο BF , CHECK THIS OUT Οι cheaters έρχονται και στις κονσόλες, μέσω ενός νέου software WWW.GAMEWORLD.GR Το cheating στις κονσόλες PS5 και Xbox Series X μπορεί να μεγαλώσει, λόγω ενός Machine-Learning Tool. Έγινε επεξεργασία Ιούλιος 7, 2021 από ARMAGEDDON 1
icy20 Ιούλιος 8, 2021 #250 Ιούλιος 8, 2021 5 hours ago, tommybertsen said: Και κρατάς την πληροφορία για σένα; Δηλαδή βλέπεις πουθενά κάποια 1660 Super ας πούμε ή μιλάμε μόνο για 3080 και άνω; Οχι για μεγαλες καρτες λεω μονο 1
tommybertsen Ιούλιος 8, 2021 #251 Ιούλιος 8, 2021 πριν 4 ώρες, το μέλος icy20 έγραψε: Οχι για μεγαλες καρτες λεω μονο Θεωρώ πως η σειρά 3000 έχει "τελειώσει" , με την έννοια ότι από τη στιγμή που βγήκε, η διαθεσιμότητα ήταν τόσο προβληματική που την έχουν ελάχιστοι (εξαιρετικά λιγότεροι από όσοι θα την είχαν πό κανονικές συνθήκες δηλαδή). Τα ίδια για την AMD σειρά, αν και ίσως εκεί να είναι ένα κλικ πιο καλά; Δεν ξέρω. Ελπίζω στην 4000 or whatever, να διατηρηθούν ΕΣΤΩ αυτές οι τιμές (αν και προβλέπω κι άλλη άνοδο). ΤΟ ίδιο και στην σειρά 7ΧΧΧ από AMD και να μπει και η Intel στο παιχνίδι έστω στο mid range κομμάτι (που με ενδιαφέρει για την Όλγα γιατί δύσκολα είμαστε με την RX 460 - αν και με έχει εντυπωσιάσει το FSR, για να πω την αλήθεια)
Cyber_Cookie Ιούλιος 8, 2021 #252 Ιούλιος 8, 2021 πριν 7 ώρες, το μέλος icy20 έγραψε: Οχι για μεγαλες καρτες λεω μονο Κοντά σε MSRP? Που ρε θείο? Στείλε ινμποχ. 1
GFFermari Ιούλιος 8, 2021 #253 Ιούλιος 8, 2021 Ναι μπορείς να βρεις 6900 κ 3090 κοντά στο msrp. So what? Οι κάρτες αυτές είναι ήδη πεταμένα λεφτά στο msrp τους, ποσό μάλλον με 200-300£ πάνω. Ok, εγώ είμαι ανώμαλος θα πάρω 3080Ti, 3090 στο msrp τους αλλά οι πραγματικές κάρτες (3060, 3070, 3080) δεν υπάρχουν.
Cyber_Cookie Ιούλιος 8, 2021 #254 Ιούλιος 8, 2021 πριν 5 λεπτά, το μέλος GFFermari έγραψε: Ναι μπορείς να βρεις 6900 κ 3090 κοντά στο msrp. So what? Edit: και 3090 στο 1,5κ. Εγώ βλέπω 6900 στα 2+ και 3090 στα 2,5+ Αν έχετε λινκ με +50% msrp στείλτε να πάρω κανα δυο να χω.
GFFermari Ιούλιος 8, 2021 #255 Ιούλιος 8, 2021 1800£ είχε η 3090 FE στο Αμαζον ουκ. Χθες ανέβηκε στα 2200. 1-2 βδομαδες ήταν στη τιμή αυτή.
DEADLAZARUS Ιούλιος 9, 2021 #256 Ιούλιος 9, 2021 AMD Radeon RX 6600 XT Arrives this August WWW.TECHPOWERUP.COM AMD is allegedly preparing for an August 2021 debut of its Radeon RX 6600 XT graphics card in the retail... Mid range κάρτες στα 500 ευρώ;
DEADLAZARUS Ιούλιος 30, 2021 #257 Ιούλιος 30, 2021 AMD Announces Radeon RX 6600 XT Graphics Card WWW.TECHPOWERUP.COM AMD today announced the new Radeon RX 6600 XT graphics card, its latest entrant to the RX 6000 series, based... 1
tommybertsen Ιούλιος 30, 2021 #259 Ιούλιος 30, 2021 Αδιανόητη τιμή για - θεωρητικά - budget mid to low end κάρτα. nVidia, βγες από την κόκκινη Που είναι ο μπάτζετ, που είναι ο πουτσίνι 3 4
Efialtis Ιούλιος 30, 2021 #260 Ιούλιος 30, 2021 Με την vega και retro gaming μέχρι να βγουν στην αγορά μεταχειρισμένων οι τωρινές γενιες ή αλλάξουν μυαλά οι εταιρίες και/ή οι αγοραστές αποφασίσουν να μην δέχονται άλλη κοροϊδία.
