NVIDIA GeForce RTX 3070 Ti (SUPER) and RTX 3070 rumored to feature GA104 GPU
  Παράθεση
RTX 3070 Series
According to kopite7kimi’s latest tweet, the RTX 3070 Series (Ti/SUPER etc), would use GA104 GPU with the high-end variants using the ‘400’ GPU model. What this means is that the 3070 Ti/SUPER would feature the full silicon with all CUDA cores enabled. These rumors would be in line with speculation regarding RTX 3080 series using the GA102 GPU instead. The whole lineup would simply move one GPU-tier higher than normally.
Expand
  Παράθεση
RTX 3080 Series to use bigger GPU and wider memory bus
The most interesting rumor so far is certainly the claim that GeForce RTX 3080 would use a GA102 GPU instead of GA104. This goes contrary to the path NVIDIA took with the last 3 generations. The xx80 models have been sticking to xx104 GPUs for quite a while, with the last ‘big GPU’ reference model being the GTX 780.
But the reason for this change could actually be quite simple: NVIDIA wants to put more memory on the xx80 series (RTX 3080) and the choice was either to use 16GB 256-bit or 10GB 320-bit. The capacity does not really have to that be much bigger, because the bandwidth will increase anyway. However, NVIDIA has not upgraded the frame buffer size for their xx80 models ever since GTX 1080 came out. Thus, it is simply expected at this point. Using the board for Ampere GA102 GPU (PG133) designed for a 384-bit bus unlocks more memory options such as 11GB 352-bit or 10GB 320-bit.
Expand
  On 7/7/2020 at 5:04 ΜΜ, το μέλος DEADLAZARUS έγραψε:
Τα βλέπω τα σάπια: 3070/3070ti/3070super/3070superduper/3070 1/2 κτλ κτλ...
Expand
Αν βγούνε όλα μαζί, κανένα πρόβλημα και ας πάνε τα σκαλοπάτια ανα 50 ευρώ αντί για 100 που είναι τώρα.
Ας δώσουν επιδόσεις και την απόδοση (=fps/watt) μπορεί να την κρατήσουν ίδια και υψηλότερη. Άλλωστε τι γκρινιάζουμε; Οι περισσότεροι από μας προτείνουμε στους άλλους το πολύ 500αρια τροφοδοτικά και οι ίδιοι αγοράζουμε 700+. Ε, όλα αυτά τα 850-1200w psu που κυκλοφορούν στις υπογραφές, ώρα να δουλέψουν και λίγο :)
αυτοι ειναι ικανοι να πουν οτι τα "παλια" τροφοδοτικα δεν κανουν και θα θελουμε καινουργια.....................
ρε ολα τα λεφτα στον Δουκα και να πανε να μπιπ.........
  • Like 3
Κι όμως είναι αλήθεια:
WWW.TECHPOWERUP.COM
Over the past few days, we've heard chatter about a new 12-pin PCIe power connector for graphics cards being introduced, particularly from Chinese...
  Παράθεση
Looking at the keying, we can see that it will not be possible to connect two classic six-pins to it. For example pin 1 is square on the PCIe 6-pin, but on NVIDIA's 12-pin is has one corner angled. It also won't be possible to use weird combinations like 8-pin + EPS 4 pin, or similar—NVIDIA made sure people won't be able to connect their cables the wrong way.
On topic of the connector's proliferation, in addition to PSU manufacturers launching new generations of products with 12-pin connectors, most prominent manufacturers are expected to release aftermarket modular cables that can plug in to their existing PSUs. Graphics card vendors will include ketchup-and-mustard adapters that convert 2x 8-pin to 1x 12-pin; while most case/power manufacturers will release fancy aftermarket adapters with better aesthetics.
Expand
  On 15/7/2020 at 7:36 ΜΜ, το μέλος alexcrx έγραψε:
Expand
Ο Δούκας; Ποιός Δούκας;
https://www.iefimerida.gr/sites/default/files/styles/horizontal_rectangle/public/2019-11/doukas-sevastos.jpg?itok=vugvWMK2
  • Haha 1
Μητρική θα βγάλουν ή κάρτα γραφικών; Ήρεμα ρωτάω.
Δώρο ο υποσταθμός της ΔΕΗ.
  • Haha 1
  On 16/7/2020 at 11:19 ΠΜ, το μέλος Trexx έγραψε:
Expand
μια χαρα
Αν και πιστεύω στις 3090, 3080Τι, 3080 θα είναι αυτό το 12πινο πάνω οπου για μένα είναι αδιάφορη κάθε κάρτα γραφικών άνω των 450 ευρώ για απλά περισσότερα καρέ σε κονσολογραφικα με τις "2080S" RDNA2 πάνω
Έγινε επεξεργασία από SpirosKGR
Αν διάβασα καλά θα είναι σε όλες με tdp >225w, άρα θα είναι αρκετές απ ότι φαίνεται.
  • 4 weeks later...
WCCFTECH.COM
NVIDIA is planning to launch the next generation of its GPUs in September and one of our sources just gave us an overview of the Ampere graphics...
NVIDIA Ampere GPUs Partial Specs And Launch Dates
Board ID Replacement Class vRAM Bus Width Launch Schedule
PG132-10 2080 Ti 24 GB 384 bit 2H Sept.
PG132-20 2080 Super 20 GB 320 bit 1H Oct.
PG132-30 2080 Super 10 GB 320 bit Mid. Sept.
PG142-0 2070 Super 16 GB TBD TBD
PG142-10 2070 Super 8 GB 256 bit 2H Sept.
PG190-10 2060 Super 8 GB 256 bit TBD
Τελικα η 3090 με την 3080ti τι διαφορες θα εχουν? Γιατι αν μιλαμε για 10% με 50% price premium τοτε δεν εχει νοημα η 90.
