jumaru99 Νοέμβριος 20, 2018 #421 Νοέμβριος 20, 2018 Assetto Corsa Competizione - HOTFIX 0.3.4 AVAILABLE NOW! Dear #ACCompetizione racers, thanks to your reports and feedback, we are pushing another hotfix right now. Please restart your Steam client to download it and check the changelog below! Note for server admins: please update the binaries! ______________ changelog v0.3.4 - Optimized netcode to prevent certain spikes, causing high pings for all clients - Fixed Chat Widget timestamp overflow and timezone - Lowered Chat position - Fixed nameplate visibility - Fixed possible memory leak for long replay recording - Increased fov and slightly increased maximum distance of the mirrors - Improved AI line at start straight to avoid incidents with cars exiting pitlane - Paul Ricard asphalt grip fine tuning - Fixed BMW M6 automatic clutch not holding idle at 2nd or higher gear - Improved (more permissive) Paul Ricard track limits at T2, T5 and outside of T11 1 1
Mesfigas1973 Νοέμβριος 20, 2018 #422 Νοέμβριος 20, 2018 το σπασανε και εχει bug τορα οταν πας να κανεις SAVE ρυθμισεις τιμονιερας δοκιμαστε το κολλαει στην φαση του save στο παραθυρο,
jumaru99 Νοέμβριος 28, 2018 #423 Νοέμβριος 28, 2018 Changelog v0.3.5 - Fixed setting the wrong Audio driver in some cases - Removed start sequence for the first player in the server - Fixed auto pitlimiter spam when gear was not allowed - Fixed wrong fuel amount during AI pitstops - Fixed lack of correct driver head motion in Bentley Continental GT3 - Changed local account data handling, improved delays caused by backend updates/restarts - Using Steam check to prevent unusable online profiles - Fixed issues causing Track Medals earned and laps posted to the Event Leaderboards not being saved - Fixed missing endurance kit joining a server - Fixed skidmarks when car is drifting - Fixed wrong tyre wear influence to rolling resistance - Reworked timetable logic - Added combined laptimes to the timetable - Fixed wrong car update during pitstop after replay - Fixed wrong car camera target after disconnection or coming back from replay - Fixed highlights not recording after a session restart - Fixed cars not removed when Multiplayer server connection is lost - Fixed possible server issue on linux emulators - Optimized account data storage/synchronization - Added Night + Rain preferences in Multiplayer server selection - Activated Night, Rain, Latency and Target Driver Count rankings in MP server selection - Added search box to MP server selection - Increased amount MP servers displayed - Reduced MP server bandwidth usage - Removed leaderboard/server list response delay - Standing widget: visual hint about disconnect state - Multiplayer chat keeps messages after opening the pause menu - Improved backend server efficiency on session/menu changes 2
Mesfigas1973 Νοέμβριος 28, 2018 #424 Νοέμβριος 28, 2018 Διορθωθηκε και το bug που δεν με αφηνε να σωσω τιποτα κια δεν μπορουσα καν να βγω απο την οθονη που σωζουμε τα σεταπ και ακομα save ρυθμισεων, ουφ
iseeklife Νοέμβριος 28, 2018 #425 Νοέμβριος 28, 2018 Παίδες το πήρα και εγώ . Απλά έχω μια ένσταση . Φρενάρει λίγο αργά . Πρέπει να σταματήσεις εντελώς σε κάποιες στροφές αλλιώς σε πετάει εκτός δρόμου . Στα υπόλοιπα racing που έχω δοκιμάσει , δεν είναι έτσι .
Mesfigas1973 Νοέμβριος 29, 2018 #426 Νοέμβριος 29, 2018 5 hours ago, iseeklife said: Παίδες το πήρα και εγώ . Απλά έχω μια ένσταση . Φρενάρει λίγο αργά . Πρέπει να σταματήσεις εντελώς σε κάποιες στροφές αλλιώς σε πετάει εκτός δρόμου . Στα υπόλοιπα racing που έχω δοκιμάσει , δεν είναι έτσι . οχι απλα απο οτι καταλαβενω εχει πολες ασυμβατοτητες με τιμονιερες και γενικοταρα το "Handling" του παιχνιδιου ειναι σε Beta-early access επιπεδο προσπαθησε να το σεταρεις σωστα και πες μας και τι τιμονιερα εχεις
GoMaR Νοέμβριος 29, 2018 #428 Νοέμβριος 29, 2018 10 hours ago, iseeklife said: Παίδες το πήρα και εγώ . Απλά έχω μια ένσταση . Φρενάρει λίγο αργά . Πρέπει να σταματήσεις εντελώς σε κάποιες στροφές αλλιώς σε πετάει εκτός δρόμου . Στα υπόλοιπα racing που έχω δοκιμάσει , δεν είναι έτσι . Μη λες τέτοια πράγματα εδώ.. Θα σου πουν ότι τα άλλα είναι λάθος Εγώ περιμένω τν τελική έκδοση γιατί είχε πολλά θέματα η πρώτη έκδοση.
liakjim Νοέμβριος 29, 2018 Author #429 Νοέμβριος 29, 2018 Παίδες το πήρα και εγώ . Απλά έχω μια ένσταση . Φρενάρει λίγο αργά . Πρέπει να σταματήσεις εντελώς σε κάποιες στροφές αλλιώς σε πετάει εκτός δρόμου . Στα υπόλοιπα racing που έχω δοκιμάσει , δεν είναι έτσι . Μήπως τα υπόλοιπα racing παιχνίδια πχ αναφέρεσαι είναι τύπου nfs, forza, dirt, wrc κτλ ?Αν όχι, τότε κοίτα τίποτα fov .Το ACC είναι πολλά κλικ πάνω από το AC σε physics οπότε ότι κάτι δεν κάνεις σωστά.Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk
iseeklife Νοέμβριος 29, 2018 #430 Νοέμβριος 29, 2018 πριν 11 ώρες, το μέλος liakjim έγραψε: Μήπως τα υπόλοιπα racing παιχνίδια πχ αναφέρεσαι είναι τύπου nfs, forza, dirt, wrc κτλ ? Αν όχι, τότε κοίτα τίποτα fov . Το ACC είναι πολλά κλικ πάνω από το AC σε physics οπότε ότι κάτι δεν κάνεις σωστά. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk Έχω εμπειρία πρόσφατη από f1 2017 και δυστυχώς από wrc . Στο παρελθόν είχα και από το προγούμενο ασσεττο . Ρυθμίσεις δεν έχω πειράξει .
liakjim Νοέμβριος 29, 2018 Author #431 Νοέμβριος 29, 2018 Οκ , τότε απλά συνήθισες στην αρκαδούρα του F1 2017!!! Δώστου λίγο χρόνο να προσαρμοστεί ο εγκέφαλός σου.
jumaru99 Δεκέμβριος 13, 2018 #433 Δεκέμβριος 13, 2018 0.4.0 - New Ferrari 488 GT3 - New Hungaroring circuit - Preview: Race weekends in Multiplayer - Added version 1 of the Broadcasting SDK (including test/example application) - Fixed look around in chase camera - Added Lock to Horizon option for Cockpit cameras (Alt+H to toggle, Shift+H and Ctrl+H to increment/decrement partial effect) - Added Confirm popup for NextSession, Restart, Pits and Quit button in ingame menu - Mirror options are now split in two: "Quality" and "View distance" - Added Fuel indicator in car HUD - Added Laps information for Hotstint online leaderboards on "Special events" page - Corrected brake heat influence on core tyre temps - Adjustments in cars inertia - Adjustments in tyre model and tyre flex, should result in better kerb behaviour - Added TC2 (TC initial cut) feature of F488. Physics, Controls, Setup - Fixed Tyres IMO (Inside Mid Outside) HUD visualisation - Fixed Ferrari 488 AI stopping without fuel in long races - Fixed wrong car systems during replay - Added lap tag in the replay HUD - Fixed cumulative automatic highlights endtime - Instant replay support for Broadcast app - Fixed focused car when entering or leaving replay - Fixed wrong time session start after a restart/next session - Fixed potential exterior camera issues for multiplayer - Fixed potential wrong near plane during starting sequence - Fixed proximity indicator according to the focused car - Added new skins for featured cars - Car dash luminosity readjusted for new exposure values - New Total (TO) rating representing strength and completeness (visible in the Rating Profile) - New driver category (visible in the Rating Profile) - CarControl Rating adjustments: alien performance now will still have overdrive, but less significant - CarControl Rating adjustments: very good driving performance will show values of CC 95+ - TR/CN/CC: Fixed false-positive detection of "way too hard" for bends and kinks - Hotstint now shows laps in the menu leaderboard - Hotstint gaps now correctly display lap gaps / time gap within the same lap - Added backend connection state indicator to relevant menu pages - Added HUD page for broadcasting - Added HUD page with the current timetables - Holding TAB will temporarily show the timetables HUD page - Prevent Ambient sound to play during in game menu - Improved camera fading when switching cameras 1
akis_z80 Δεκέμβριος 13, 2018 #434 Δεκέμβριος 13, 2018 Περιμένω και εγώ την τελική έκδοση, αν και ακόμα δεν ξεπέρασα την αρχική ψυχρολουσία. VR unplayable, στο τιμόνι δε νιώθω τίποτα (έκανα αρκετό tweaking). Το αν από πίσω τρέχουν τα πιο εξελιγμένα physics του κόσμου με αφήνει αδιάφορο. Δυστυχώς με το σώμα δε μπορώ να νιώσω τι κάνει το αυτοκίνητο, οπότε το μόνο που μένει είναι να κοιτάω την οθόνη κ να αντιδρώ ανάλογα.. thanks δε θα πάρω. 1 1
fatalara Δεκέμβριος 13, 2018 #435 Δεκέμβριος 13, 2018 (edited) πριν 43 λεπτά, το μέλος akis_z80 έγραψε: Περιμένω και εγώ την τελική έκδοση, αν και ακόμα δεν ξεπέρασα την αρχική ψυχρολουσία. VR unplayable, στο τιμόνι δε νιώθω τίποτα (έκανα αρκετό tweaking). Το αν από πίσω τρέχουν τα πιο εξελιγμένα physics του κόσμου με αφήνει αδιάφορο. Δυστυχώς με το σώμα δε μπορώ να νιώσω τι κάνει το αυτοκίνητο, οπότε το μόνο που μένει είναι να κοιτάω την οθόνη κ να αντιδρώ ανάλογα.. thanks δε θα πάρω. Δεν εισαι μονος. Το VR παντως θα παραμεινει unplayble αποτι ακουω. Ειναι θεμα με το AA της unreal γιαυτο ειναι ολα θολα. Υπαρχει το ιδιο προβλημα και σε οθονες μικρης αναλυσης αλλα ακομα και στη δικια μου δεν ειναι καθαρη η εικονα. Έγινε επεξεργασία Δεκέμβριος 13, 2018 από fatalara
iseeklife Δεκέμβριος 14, 2018 #436 Δεκέμβριος 14, 2018 το έβαλα και στο κύριο πισι μου που έλειπε για αναβάθμιση . Το ίδιο και εκεί. Τ α φρένα είναι πολύ αργά . Κατεβαίνουν τα χιλιόμετρα 10 ανά δευτερόλεπτο περίπου . Και εάν δεν στρίψεις με 50 40 χιλιόμετρα σε πετάει . Είδα βιντεάκια στην πραγματικότητα, φορμουλα1 και κατεβαίνουν τα χιλιόμετρα πολύ διαφορετικά . σε τρια έχουν κατέβει από τα 320 στα 80 και στρίβουν περίπου με 70 80 χιλιόμετρα . Δεν είναι το ίδιο με τα GTcars αλλά έχουμε ένα μέτρο σύγκρισης.
liakjim Δεκέμβριος 14, 2018 Author #437 Δεκέμβριος 14, 2018 Δεν είναι το ίδιο με τα GTcars αλλά έχουμε ένα μέτρο σύγκρισης. Κανένα μέτρο σύγκρισης.Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk
GoMaR Δεκέμβριος 14, 2018 #438 Δεκέμβριος 14, 2018 Το ξαναλεω γιατι και εγω περιμενω την τελικη εκδοση. Η αρχικη εντυπωση ηταν οτι το αμαξι σε καθε στροφη ειχε τελειως διαφορετικη συμπεριφορα. Εκανε αλλο απο αυτο που περιμενες και σε καθε στροφη ενιωθες, θα με πεταξει η οχι; Αλλες φορες ναι αλλες φορες οχι. Τωρα για τα φρενα, εισαι λιγο υπερβολικος αλλα γενικα ναι, εχει πολυυυυ δρομο ακομα το παιχνιδι. Αν και για μενα θα τους ξανα στηριξω οταν θα βγαλουν το επομενο AC με κανονικα αμαξια. Αλλα παμε σε 2-3 χρονακια ετσι οπως το παει η εταιρια. 1
Aris Teidis Δεκέμβριος 14, 2018 #439 Δεκέμβριος 14, 2018 Το έτρεξα χτες (DD+Oculus) μετά από πολύ καιρό και ένοιωσα κάποια πρόοδο οπότε αναπτερώθηκαν οι ελπίδες μου! Τα λέμε πάλι σε κανα δυο μήνες, χαχα 2
jumaru99 Δεκέμβριος 14, 2018 #440 Δεκέμβριος 14, 2018 Σε κάθε build το παιχνίδι αλλάζει. Πολλές φορές και σε patch. Δεν θα πω βελτιώνεται γιατί ο καθένας έχει την άποψή του και για ένα προϊόν που δεν είναι ολοκληρωμένο κρατάμε μικρό καλάθι για το πως θα εξελιχθεί. Δεν ξέρω αν οι απόψεις που εκφράζονται κατά καιρούς αντιστοιχούν στο εκάστοτε παρόν build ή είναι απόψεις που σχηματίστηκαν σε προηγούμενη δοκιμή. Η Lamborghini πχ καμία σχέση με αυτή του πρώτου build. Προσωπικά βλέπω πράγματα να αλλάζουν κι όχι στασιμότητα. Μακάρι το τελικό προϊόν να είναι σε ένα στάδιο ίδιο ή καλύτερο του προκατόχου του. Δεν νομίζω να τους παίρνει να είναι off. Το περιμένουν αρκετοί στη γωνία ήδη να το κατακεραυνώσουν(απ' όσους δεν έχουν αρχίσει ήδη). 1
