Δημοσιεύτηκε (edited)
Jump straight into combat in this official standalone FREE total conversion of Arma 3.
Master your craft to rank up and become (in)famous on the battlefield.
Argo is a hardcore tactical first-person shooter, in which players take on the role of a mercenary, and fight across various unrestricted locations on the
62 km² Malden terrain. The game features three competitive 5-vs-5 game modes, plus a cooperative sandbox game mode with randomized objectives.
Argo is now available as a FREE game on Steam.
https://www.projectargo.net
Έγινε επεξεργασία από Proteas
Update 1.00
Παράθεση
Known Issues:
Steam overlay does not work on 64bit if Fraps runs as well.
If player leaves a mission during respawn screen in place, he won't be able to select or even see spawn points in respawn screen next time he joins any game.
But player is still able to respawn himself and everything else works as it should.
Bugfixes:
Fixed: Stances indicator missing on Normal difficulty.
Fixed: Reward breakdown showing script error when player reaches level 24 or 25.
Fixed: Editor - Error when loading a saved game inside mission scenario.
Fixed: Combat Patrol - Exiltrate task not assigned/displayed if primary objective was failed.
Fixed: Link (Easy) - Broken node indicator after round ending in draw.
Fixed: Teammates missing in map on Easy difficulty.
Fixed: Remove second redundant difficulty choice from QuickPlay for Combat Patrol.
Fixed: Part of text about the reset of skill tree in Russian language missing.
Fixed: Spectator - Double digit value of levels displayed incorrectly.
Fixed: Issue where players would not receive any xp/in-game currency after match.
  • 3 weeks later...
Εχω κολλησει ασχημα με το game αυτο!
Εχει και καποια προβληματακια βεβαια ,κυριως με την αποδοση αφιυ εχει την μηχανη του arma 3 που δεν ειναι και η πιο γρηγορη
Με καποιες ρυθμισεις στα γραφικα παιζει πολυ καλα χωρις κολληματα , ενα μικρο lag υπαρχει πολλες φορες αλλα δεν προβληματιζει τοσο
Με το pc μου cpu 8 ετιας ,με gtx 660 και ssd ,8 gb ram παει πολυ πολυ καλα με  ελαχιστο lag οπως ειπα που περισοτερο εχει να κανει με την συνδεση
Εκεινο που ειναι must για μενα ειναι το mode "LINK "  που πρεπει να καταλαβεις  link points και ενα main node για να κερδισεις την μαχη καθε φορα
Ειναι πιο γρηγορες μαχες απο  οτι τα αλλα  modes με περισοτερη αδρεναλινη αφου εχει respown μεχρι το τελος αλλα δεν βαρας απλα τους αλλους αλλα εχει και στρατηγικο στοχο να καταλαβεις τα δικα σου αλλα και τα εχθρικα link points ωστε να εμποδισεις τον εχθρο να καταλαβει περισοτερα σημεια απο οτι η ομαδα σου
Επισης εχει easy mode οπου βλεπεις ποιοι ειναι οι συμμαχοι σου και βαρας μονο οσους δεν εχουν το σημαδακια αυτο ή στο normal mode με extra poins αλλα δεν ξεχωριζεις τους εχθρους απο τους φιλους παρα μονο απο την στολη τους ,γιαυτο στην αρχη το frendly fire εκει παει συννεφο μεχρι να εξοικιωθεις με την εμφανιση στις στολες
Φυσικα υπαρχουν αναβαθμισεις στα οπλα και στον εξοπλισμο και την εμφανιση του παικτη που εχουμε
Εκεινο που μου αρεσει 1000% ειναι το ελληνικο τοπιο που γινονται οι μαχες, ειτε σε βουνο ειτε σε οικισμους με καποια σπιτια ,ολα σε Ελληνικο τοπιο
οπως και το Arma 3 που οι μαχες γινονται στην Λημνο
  • 1 month later...
