Στα APU περιμενα να κάνει το μπαμ, στην HEDT το κάνει και στα server.
Είδα πάντως αναφορές και στα mobile APU με ζεν που φαινομενικά θα τα πάνε περίφημα.
https://www.notebookcheck.net/Zotac-unveils-Magnus-ER51060-and-MA551-mini-PCs-with-Ryzen-CPUs.223594.0.html
  Παράθεση
The first is the Magnus ER51060 and ER51070 with removable desktop GTX 1060 and 1070 Mini GPUs, respectively. The manufacturer has not yet specified the exact Ryzen CPU for these mini PCs other than the 65 W TDP, so we can at least deduce a CPU option from as low as the Ryzen 3 1100 up to the Ryzen 7 1700. Press images reveal a design not unlike the existing Magnus EN980 with its honeycomb top, 5x USB 3.0 ports, 2x Gigabit RJ-45, USB Type-C, SD reader, and at least five different video-out ports.
The second is the smaller Magnus MA551 with similar 65 W Ryzen processor options. Unlike the ER series above, however, the MA551 caters mainly to multimedia users and will include Thunderbolt 3 support. Ports include 4x USB ports, 1x USB Type-C, 3x video-out ports, SD reader, and Gigabit RJ-45.
Expand
  Παράθεση
What's Next For Memory
AGESA 1.0.0.6 officially adds 26 new parameters that can improve the compatibility and reliability of DRAM, especially for memory that does not follow the industry-standard JEDEC specifications (e.g. faster than 2667, manual overclocking, or XMP2 profiles).
The following table spells out all the new parameters, and provides a few words on what they do. Keeping in mind that this is overclocking territory, manual or automated control of these parameters should nevertheless make it a little more straightforward to use DDR4-3200 modules—or faster if you have the talent!1
Added dividers for memory clocks up to DDR4-4000 without refclk adjustment. Please note that values greater than DDR4-2667 is overclocking. Your mileage may vary (as noted by our big overclocking wartning at the end of this blog).
Expand
https://community.amd.com/community/gaming/blog/2017/05/25/community-update-4-lets-talk-dram
Έγινε επεξεργασία από adpanos
Έμεινε μόλις μια εβδομάδα πριν την ανακοίνωση των Threadripper CPUs με 16C/32T και η Intel φαίνεται ότι παίζει τα ρέστα της, για να αποφύγει την συντριβή.
Στο τελευταίο leak από Sisoft Sandra, φαίνεται ότι ανεβάζει πολύ τα ρολόγια για τον Skylake-X Core i9 7900X με 10C/20T και από base/turbo clock των 3.3GHz/4.3GHz, πάει σε 4.0GHz/4.5GHz, φτάνοντας φυσικά το TDP στο θεό και συγκεκριμένα στα 175W.
Αν αυτό δεν είναι ο ορισμός του πανικού, τότε πείτε μου εσείς τι είναι.
https://hothardware.com/news/intel-10-core-skylake-x-core-i9-7900x-leak-4ghz-base-45ghz-turbo
  On 26/5/2017 at 8:14 ΠΜ, το μέλος NikosD έγραψε:
Expand
E....
  On 25/5/2017 at 10:07 ΠΜ, το μέλος NikosD έγραψε:
Θεωρείς πραγματικά ότι στο thread του VEGA Threadripper που δεν έχει κυκλοφορήσει ακόμα, μας ενδιαφέρει το Volta Skylake-X Core i9 7900X με 10C/20T που είναι για το 2018 ανταγωνιστής του;
Μόνο σαν προσπάθεια να κοπεί η φορά του VEGA Threadripper το βλέπω αυτό.
Expand
Έγινε επεξεργασία από yanni
Οι μεγάλες συχνότητες δεν είναι απαραίτητα κακές - οι περισσότερες εφαρμογές κλιμακώνονται εξαιρετικά με τη συχνότητα. Επίσης τα 175W μπορεί να φαντάζουν πολλά, αλλά και οι 10 πυρήνες σε τέτοια συχνότητα δεν είναι αμελητέο επίτευγμα..
Δεν έχω ιδιαίτερη προσήλωση σε καμία εταιρεία, αλλά είναι λίγο νωρίς να λέμε για "συντριβή" και "πανικό". Ας δούμε πιο πολλά και για τους Threadripper και θα κάνουμε μετά μία νηφάλια σύγκριση. Εικάζω άλλωστε ότι θα βρεθούν πλεονεκτήματα και μειονεκτήματα και στις δύο οικογένειες :)
  • Like 3
  On 26/5/2017 at 5:22 ΠΜ, το μέλος adpanos έγραψε:
Expand
Μέσω extra controller. Φαντάζομαι για εξωτερική κάρτα γραφικών.
Ναι, τι δεν είναι ξεκάθαρο ;
Μιλάμε για δύο προϊόντα που θα ανακοινωθούν σε λίγες εβδομάδες και θα "σφαχτούν" σε λίγους μήνες.
Το Volta, όπως σου έγραψα, είναι προϊόν του 2018 και μάλλον θα παλέψει και με το Navi, όχι μόνο με το VEGA.
Επίσης, σε καμία περίπτωση ο Skylake-X των 10C/20T δεν μπορεί να αγγίξει τον Threadripper των 16C/32T στο productivity που απευθύνονται τα δύο CPUs (δεν μιλάμε καθόλου για single-thread performance εδώ), οπότε είναι πάλι άστοχη η σύγκριση που κάνεις σε σχέση με το αν μπορεί να φρενάρει τον Threadripper.
Θεωρείς πραγματικά ότι η απέλπιδα προσπάθεια της Intel να φτάσει τον Threrdripper με τα ρολόγια του Skylake-X στο θεό, θα έχει κάποιο αποτέλεσμα ;
Σε κάθε περίπτωση θα ξέρουμε σε κανα-δυο μήνες και για τους δύο (Threadripper vs Skylake-X) και όχι σε κανά χρόνο όπως με το VEGA vs Volta/Navi.
Κάτι έχεις μπερδέψει...
Έχω μια υποψία ότι το νόημα της παράθεσης ήταν ότι το τρέχον θέμα δεν είναι για τους i9 :)
  • Like 3
  On 26/5/2017 at 9:17 ΠΜ, το μέλος minast έγραψε:
Expand
Μα και αυτοί στους ZEN συγκαταλέγονται.
Κάνω λάθος;
Δεν λέει RYZEN το θέμα, που μάλλον και οι threadripper ryzen θα λέγονται, αλλά μιλάει για ZEN γενικά.
Ο 10c/20t στα 175watt θυμίζει ανάλογη προσπάθεια της AMD με τους FX 9xxx.
Βέβαια την μόδα αυτή προβλέπω να την ακολουθεί και η AMD ..... σαν απάντηση με κανένα 4-4.1ghz  16/32.
Η παράθεση, όπως εξήγησα, ήταν χωρίς νόημα γιατί συγκρίνει μήλα με πορτοκάλια.
Φυσικά και στο νήμα του Zen θα μιλήσεις για τους Core i9 αφού βγαίνουν μαζί και είναι οι άμεσοι ανταγωνιστές του Threadripper Ryzen 9.
Το σφάλμα θα ήταν να μιλάς για τους επόμενους Core i9 που θα βγουν το 2018 και να τους συγκρίνεις με τους τωρινούς Ryzen 9 που βγαίνουν σε ένα μήνα.
Παιδιά sorry αλλά δεν επανέρχομαι στο θέμα.
Δεν μπορώ να το κάνω πιο φραγκοδιφραγκα.
  On 26/5/2017 at 10:03 ΠΜ, το μέλος adpanos έγραψε:
Κάνω λάθος;
Expand
Δεν είμαι σίγουρος αν το λες σοβαρά ή σαρκαστικά. Η Intel συμπεριέλαβε τους μελλοντικούς i9 της στους ΖΕΝ; ;) Τέλος πάντων, γενικά αυτό το θέμα έχει μια ανοχή σε συζήτηση Intel vs AMD, ακόμη κι αν η σύνδεση είναι λίγο χαλαρή, οπότε δε χάθηκε ο κόσμος.
Στην ουσία όμως, ας προσπαθούμε να είμαστε αντικειμενικοί. Για αρχή, τα engineering samples των Ryzen επίσης είχαν σημαντικά χαμηλότερες συχνότητες. Δεν ήταν ένδειξη πανικού ότι η AMD αύξησε τις συχνότητες στα μοντέλα παραγωγής. Το ίδιο ισχύει για την Intel. Η αυξημένη συχνότητα λειτουργίας σε σχέση με τα δείγματα προ-παραγωγής είναι αναμενόμενη, ειδικά ακριβώς πριν την κυκλοφορία ενός νέου επεξεργαστή.
Επίσης, τα 175W δεν είναι "στο θεό", όπως εγράφη. Οι κορυφαίοι Threadripper έχουν ανακοινωθεί στο 90% του TDP (155W) και εικάζω ότι στην πράξη οι καταναλώσεις τους θα είναι παρόμοιες. Νομίζω είναι σωστή κίνηση επιχειρηματικά να ανεβάσουν τη συχνότητα των i9 πέρα από την ιδανική καμπύλη τους, γιατί το κοινό που επιλέγει τους HEDT σπάνια κοιτά τον λογαριασμό του ρεύματος. Δεν ξέρω αν έτσι θα κρατήσουν τα σκήπτρα της απόδοσης, αλλά η σκέψη είναι σίγουρα λογική.
  On 26/5/2017 at 10:25 ΠΜ, το μέλος acct έγραψε:
Expand
Για τους threadripper μιλάω όχι για τους CORE.
Zen δεν είναι αυτοι.?
Οι 10/20 R9 θα είναι στα 125watt TDP το ίδιο και μερικοί 12/24
Οι μεγάλοι 12/24 θα είναι στα 140watt TDP όπως και οι μικροί 14/28
Οι μεγάλοι 14/28 θα είναι στα 155watt όπως και όλοι οι 16/32
  On 26/5/2017 at 10:27 ΠΜ, το μέλος adpanos έγραψε:
Expand
Η αναφορά από τον @NikosD που προκάλεσε τη συζήτηση ήταν η παρακάτω:
Expand
Μιλά μόνο για τα φημολογούμενα χαρακτηριστικά των Intel Core i9, που προορίζονται ως οι ανταγωνιστές των Threadripper. Όπως και να 'χει, κοντός ψαλμός. Όπου να 'ναι θα δούμε στην πράξη και τις δύο σειρές.
Εγώ πάλι θα συμφωνήσω με την σύγκριση των Intel Skylake-X με τους τελευταίους AMD FX.
Όταν είσαι 2ος στους 2, όταν είσαι πίσω σε επιδόσεις και ειδικά όταν είσαι η Intel που είχες συνηθίσει την πρωτιά για περίπου 15 χρόνια στο desktop και στο HEDT, τότε σε κατάσταση πανικού θα κάνεις ό,τι χρειαστεί ή ό,τι μπορείς για να ξαναβρεθείς στην πρώτη θέση.
Δεν ξέρω μην δούμε και κάνα 12C/24T στα 200W (!), οπότε πραγματικά θα στενάχωρηθώ για αυτή την κατάντια, που θα θυμίζει AMD στα χειρότερα της.
Γιατι είναι γεγονός ότι σε λιγότερο από μια εβδομάδα, θα γίνουμε όλοι μάρτυρες αυτής της ιστορικής στιγμής αποκαθήλωσης της Intel από τον θρόνο της.
Η AMD ετοιμάζεται να ξαναγράψει ιστορία.
  On 26/5/2017 at 10:37 ΠΜ, το μέλος NikosD έγραψε:
Expand
Καλά δεν εκμεταλλεύονται 16/32 όλες οι multi εφαρμογές, ούτε σκαλαρουν καλά πάνω από ένα αριθμό πυρήνων.
Σε αυτά έχει νόημα ένα cpu λιγότερων πυρήνων υψηλών χρονισμων σε σχέση με ένα περισσότερων και χαμηλότερων.
Νομίζω όμως πως και η AMD θα ανεβάσει ρολόγια σε κάποια μοντέλα όσο την παίρνει.
Αναλόγως για ποια workloads μιλάμε.
Οι Xeon ας πούμε φτάνουν 24C/48T και στις νέες γενιές θα πάμε και 28C/56T με πολύ χαμηλά ρολόγια.
Οι AMD EPYC πάμε στα 32C/64T και σε ένα χρόνο ανακοινώθηκε ότι πάμε σε EPYC 48C/96T.
Η κατηγορία του HEDT είναι πιο κοντά στα workloads που τρέχουν οι Xeon και οι EPYC, παρά οι Core i7 και Core i5
  On 26/5/2017 at 11:10 ΠΜ, το μέλος NikosD έγραψε:
Expand
Οι μισοί που θα πάρουν hdet, θα την πάρουν για την υποστήριξη σε ram και τα περισσότερα lanes. Όχι μόνο για τα workloads τους.
Ναι, εκεί δεν το συζητάμε.
Έπιασε το qual channel που προσφέρει η Intel και δίνει και παραπάνω PCI-e lanes.
Αλλά κακά τα ψέμματα, αν θες να χτυπήσεις επιδόσεις απέναντι στην Intel και να της κλέψεις την πρωτιά, χρειάζεσαι σίγουρα παραπάνω cores και καλό ρολόι.
Τα πέτυχε και τα δύο νομίζω (Κυριακή κοντή γιορτή)
