Καινούργιες εκδόσεις (Haya)
PGM
  • Replies 2,4k
Nmap 6.00
Nmap ("Network Mapper") is a free and open source (license) utility for network exploration or security auditing. Many systems and network administrators also find it useful for tasks such as network inventory, managing service upgrade schedules, and monitoring host or service uptime.
Nmap uses raw IP packets in novel ways to determine what hosts are available on the network, what services (application name and version) those hosts are offering, what operating systems (and OS versions) they are running, what type of packet filters/firewalls are in use, and dozens of other characteristics. It was designed to rapidly scan large networks, but works fine against single hosts.
VirtualBox 4.1.16.78094
# The following items were fixed and/or added:
* VMM: fixed a Guru Meditation VERR_ACCESS_DENIED with certain guests
* VMM: fixed a Guru Meditation VERR_PAGE_TABLE_NOT_PRESENT with Ubuntu 32-bit guests with nested paging enabled on AMD CPUs
* VMM: preserve segment limits and attributes when switching to unreal mode required for some legacy guests to work properly (VT-x without unrestricted guest execution only)
* VMM: fixed a VM hang after a resume from pause / savestate with SMP guests in rare cases
* 3D Support: several fixes for the Windows WDDM video driver crash
* NAT: fixed a crash on attempt to process ICMP datagram under some circumstances
* Host-only Networking: lifted the maximal number of interfaces to 128 on Linux and Mac OS X hosts (there is no such limitation for Solaris and Windows hosts)
* EFI: fixed wrong SEC/PEI Core entry point calculation
* VRDP: fixed a display update problem
* Main: set the proper VM state if savestate failed for some reason
* Main: more useful error message if a medium is inaccessible
* VBoxManage: fixed controlvm savestate if the VM is already paused
* Mac OS X hosts: addressed issues running on Mountain Lion Preview 3
* Linux hosts: Linux 3.4 compile fixes
* Linux hosts: fixed wrong help path in some rpm-based packages
* Guest Additions: fixed handling of custom environment variables during VBoxManage guestcontrol execute
* Windows Additions: fixed guest driver crash of VBoxSF in certain cases (4.1.10 regression)
* Windows Additions: don't load the WDDM driver if 3D support is not available for Windows 8 guests to keep the guest maintainable in that case (still better to miss some features than providing a blank screen)
* Solaris Additions: added support for X.org Server 1.11 and 1.12
Wireshark 1.6.8 (32-bit)
# The following bugs have been fixed:
* User-Password - PAP decoding passwords longer than 16 bytes.
* The MSISDN is not seen correctly in GTP packet.
* Wireshark doesn't calculate the right IPv4 destination using source routing options when bad options precede them.
* BOOTP dissector issue with DHCP option 82 - suboption 9.
* MPLS dissector in 1.6.7 and 1.7.1 misdecodes some MPLS CW packets.
* ANSI MAP infinite loop.
* HCIEVT infinite loop.
* Wireshark doesn't decode NFSv4.1 operations.
* LTP infinite loop.
* Wrong values in DNS CERT RR.
* Megaco parser problem with LF in header.
* OPC UA bytestring node id decoding is wrong.
# Updated Protocol Support
* ANSI MAP, ASF, BACapp, Bluetooth HCI, DHCP, DIAMETER, DNS, GTP, IEEE 802.11, IEEE 802.3, IPv4, LTP, Megaco, MPLS, NFS, OPC UA, RADIUS
# New and Updated Capture File Support
* 5View, CSIDS, pcap, pcap-ng
Eraser 6.0.10.2620
Updated Italian translation.
- Updated LZMA SDK for Bootstrapper to use the beta 9.22 SDK which is the only one available from 7-zip.
- Improved Recycle Bin support for non-NTFS drives on Windows.
- Fixed Scheduler display bug where tasks added using the Shell Context Menu could appear in the schedule as Not Queued even if it was configured to run automatically, if a task was already running.
- Disable all entropy mixing algorithms except SHA-1 so that Eraser can continue to function even when FIPS mode is enabled under Windows XP.
- Bug fix for CryptoAPI crash on startup under certain circumstances.
- Fixed persistence of non-default erasure methods for erasure targets.
- Allow users to exit from an invalid custom erasure method editor state if he clicks cancel or closes the dialog.
