K_tech Απρίλιος 30, 2012 #1801 Απρίλιος 30, 2012 Rainlendar 2.10 Beta 117* Changes:- On Mac it was possible to close the manager dialog while the file dialog was open which caused a crash.- The change fields dialog crashed if the type of the item was not changed.- The maxheight attribute didn't work correctly with recurring events.- Change the way "Double click action" works. It's now possible to disable the double clicking completely or show the menu always.- Added event handler for double click on a calendar day.- When creating new calendar the user credentials are automatically used from the previously created Google calendar or Toodledo task list.- All day events in schedule and month views need to be dragged to another day before the times are changed. This is to prevent accidental moving of multiday events.- Windows which are linked to upward growing windows are placed top of them when the window positions are rearranged.- Added a search widget to the Shadow4 widget addon.- If there is only a single valid calendar it is selected automatically when creating a new event or task.
K_tech Απρίλιος 30, 2012 #1802 Απρίλιος 30, 2012 Foobar2000 1.1.12 beta 4- Tuned ReplayGain scanner for fast multicore CPU / slow HDD scenarios.- Fixed Converter misbehavior on files with misplaced “cuesheet” tags.- Improved performance when playing MP3 files from internet HTTP sources.- Improved compatibility with Apple's HFS driver.
K_tech Απρίλιος 30, 2012 #1803 Απρίλιος 30, 2012 Total Commander 8.0 RC1- Added: SelectionFocus=1 or color: Draw focus differently when there are selected files in that panel. Add $4000000 to only show when on not selected item (32/64)- Fixed: Unpacking file from multi-volume ZIP: Don't ask for disk change if the file is in the last part, which contains the zip central directory (32/64)- Fixed: Files - Change attributes: Date field was not focused when checking option "Change date/time" with the keyboard shortcut (64)- Fixed: The program msdvev.exe was incorrectly detected as a self-extracting LHA archive (32/64)- Fixed: Do not re-read active panel (e.g. from background operation) during Ctrl+Tab operation, when user switches through folder tabs (32/64)- Fixed: Multi-rename tool: Text in "Rename mask: File name" box wasn't always selected when opening the dialog (32)- Fixed: Windows 8: Do not resolve links pointing to other volumes in the form "\\?\Volume{" (when double clicking on file, see fix 20.03.12 below) (32/64)- Added: AppendLnk ini option: New value 2 (now the default) sets the behaviour described below. Set to 0 for behaviour as in TC7.x (32/64)- Fixed: When creating *.lnk files, do not truncate directory names after first dot, e.g. directory.ext -> directory.ext.lnk (32/64)- Fixed: OPENBAR command: Support double quotes around parameter (.bar file), do not show "As administrator" (32/64)- Fixed: Handle OPENBAR command in button bar the same way as when specifying the .bar name directly (including "as menu" option and overlay) (32/64)- Fixed: Could no longer close Synchronize dirs after comparing two files (one in a RAR), changing both, and re-packing (32/64)- Fixed: While a MessageBox was open in Lister or Compare by Content, TAB didn't work in TC, and ESC in other Lister windows -> handle it manually (32)- Fixed: Lister: When searching repeatedly for the same string with Ctrl+F (not F3), directly consecutive patterns were skipped (32/64)- Fixed: Improved layout of multi-rename tool a bit (64)- Fixed: Synchronize dirs: Could no longer delete files from UAC-protected dirs to recycle bin (reason: deletion per folder) (32/64)- Fixed: Verify checksums: ESC closed the dialog without aborting the verification (64)- Fixed: Verify checksums: Crashed when user closed main TC and ignored warning about active comparison (64)- Fixed: Nag dialog: Some texts were now in bold by mistake (64)
K_tech Απρίλιος 30, 2012 #1804 Απρίλιος 30, 2012 Macrium Reflect 5.0.4522# New:* File & Folder Log clipboard copy- Users can now copy a CSV list of files either backed up or restored in the Macrium Reflect log view.* Log Image File Sizes- Backup file sizes are now included in the backup logs.* Backup Drive Selection- The drives/partitions selected in the main application window are now remembered between runs of Macrium Reflect.# Bug fixes:* Startup Issue- Macrium Reflect could hang at startup if the file system contained an NTFS MFT record with a attribute list > 64K in size. This has been resolved.* File & Folder Search- When cancelling a File and Folder search operation for restore, Macrium Reflect could generate a dump report. This has been resolved.* Licensing- When contacting the license server, Macrium Reflect could crash on button clicks. This has been resolved.* Email Attachment Images- Success/fail graphics were omitted from email log attachments. This has been resolved.* Toolbar/Status bar State- The state of the toolbars and status bar were not being saved between runs of Macrium Reflect. This has been resolved.* Installer issue- In rare cases, during an upgrade from existing v4 install, the Image Mounting service would prevent the install from completing. This has been resolved.* Fix Boot Problems Issue- An edge case where the Fix Boot Problems option under WinPE could reboot the machine when manually specifying an operating system path. This has been resolved.
