K_tech Απρίλιος 19, 2012 #1761 Απρίλιος 19, 2012 ACDSee 14.2.157# This update adds support for RAW file formats of the following cameras:* Canon Powershot S100* Nikon 1J1* Nikon 1V1* Sony Alpha NEX-7* Panasonic DMC-GX1K* Samsung NX200* Ricoh GR Digital IV# Enhancements* EXIF Make and Camera Model fields can now be modified.* Alternative product registration mechanism available.* When assigning categories, the category tree no longer scrolls.
K_tech Απρίλιος 20, 2012 #1764 Απρίλιος 20, 2012 GOM Player 2.1.40.5106- Disable Splash Screen Function (window that appears when closing the player) added.- Improved the Gretech MP4 Source Filter.- Altered default screen size settings.- Improved playback for extremely large files (AVI, MKV, WMV, ASF, MP4, OGG, TS)- Added the LAV Audio Decoder to the Disabled Filters List- Corrected the Gretech FLV Source Filter- Improved the Gretech AVI Source Filter- Product information added to the Windows Control Panel- Impoved the Playback Window size adjustment feature- Adjusted the default AC3 options- Miscellaneous minor changes to phrasing, etc.
K_tech Απρίλιος 20, 2012 #1765 Απρίλιος 20, 2012 Maxthon 3.3.7.2000# Fixes* Main Frame- No response to the newly registers login sometimes.- Failed to unlock the locked tabs* Webkit Core- Certain page elements could be dragged&dropped accidentally into search.- No response when clicking download buttons in certain pages.- The download dialog message prompted improperly- The right click menu displayed incompletely- A CSS support problem.
K_tech Απρίλιος 24, 2012 #1777 Απρίλιος 24, 2012 TeamSpeak Client 3.0.6 (32-bit)- Added temporary server passwords, see contextmenu on server. Temporary passwords are valid for a specified period of time and work in addition to the permanent server password. The server requires a permanent passwords set, else temporary passwords have no effect. Needs server 3.0.3 or above.- Plugin API updated to 16- Added context menu "Paste & Send" in chat line.- The away message is now shown beside nickname.- Added multiselection for "Permissions > Channel Groups > Clients", the DEL key works too.- Added ban reason sorting.- Added line markers for each chat line. Can be disabled via chat display context menu (default is enabled).- Added ability to delete other clients avatar if b_client_avatar_delete_other is set. Requires server 3.0.3 or above.- Removed the confusing soundpack "None".- Added animated gif support for avatar and channel description. Can be toggled in Settings->Options->Design (default is enabled).- Added new permission b_client_request_talker, this allows clients to request talk power. Requires server 3.0.3 or above.- Added news browser, meant to point users to new features in the client.- Added name of the user who granted talk power to the message: "Talk power granted by X".- Utilities (update, error_report and package_installer) are now dynamically translatable.- Plugin API changes: Added setPluginMenuEnabled, requestClientIDs, onClientIDsEvent, onClientIDsFinishedEvent. Removed pluginEvent and getAPIVersion. Removed plugin_events.h header.- Added plugin hotkeys, see test plugin for details- Added version string to uninstall registry entries for display in Windows deinstall system control panel.- Phonetic name can now be pre- defined per identiy but still be overwritten in every bookmark.- ts3server:// links can now be entered into the Connect dialog. Values from this link will overwrite existing values from the dialog.- Collected URLs are now saved in binary file instead of ini, much faster.- Display server/channel group icons in group list of permissions window.- All clients list can now also be searched by client unique identifier.- Fixed contextmenu in chat on ts3server links- Fixed opening the privilege key dialog without having the permission to see the key list and also then, all created keys will be shown until the dialog has been closed or list has been reloaded.- Minor UI overhaul of privilege key list and add dialog.- Fixed adding a custom ban even without the permission to list. When adding a ban a dialog will show if the ban could be inserted.- Empty ban list no longer shows "Insufficient permissions to view bans"- Fixed opening URLs with different char encoding e.g. ISO 8859-1 (Latin-1) having '%F6' instead of 'ö' in filename.- Fixed opening text chat from a received poke on correct server.- Fixed no colors in multiline messages.- Fixed invitation if privilege key contains a plus sign.- Fixed special HTML characters (<, > etc) getting lost in chat history- Fixed special HTML characters in client description- Clear old server log when connecting to a new server in the server log view- Changed behaviour of the last tabs close button.- Fixed broken avatar template values.- Fixed poke message size limit when message includes URL(s).- Fixed writing and reading chatlog history. Please backup or delete old chat logs to start clean or you might feel some strange delay.- Fixed bookmarks manager reporting unsaved changes.- Fixed copying nicknames from chat if they contain whitespaces.- Removed some repetitive settings from options dialog which are also accessible via contextmenus in the client mainwindow.- Adjusted client for anti-flood settings fix for server version 3.0.3.- Fixed an assert with animated images.- Removed animation of group icons.- Sorting of server- and channelgroups should behave the same even with identical sortID everywhere in the client.- Added Delete keyboard shortcut to subscriptions dialog to remove entries- Volume control plugin overhaul- Fixed possibly invalid grant value displayed in permission overhaul- Removed "Export to PDF" in permission overhaul- Cleaned up client, channel and server info templates. Added list of all replacable variables to templates so user can easily restore the removed information with own templates.- Removed clientID column from all-clients list- Fixed banners not reloading anymore when the image was not available.- Fixed bookmark drag&drop issues on Mac.- Fixed crash when trying to send an offline message via fake link.- Fixed copy and paste when text contains an image object.- Fixed saving first-start-bookmark for not using hotkeys on a temporary uuid.- Fixed hotkey toggle/activate/deactivate plugin.- Fixed minor issues using animated gifs.- Added workaround for G35 sound driver issue (voice only on right site)TeamSpeak Server 3.0.5 (32-bit)- MySQL users, please alter your table server_properties and extend the "value" field from varchar(255) to varchar(2048)- privilegekeylist no longer shows groups which does not match i_group_needed_member_add_power and/or i_group_member_add_power- added possibility to give a channel password when creating a temporary server password (check docs for details)- the following actions will reset client idletime:> logview, clientdblist, complainlist, complainadd, talkower grant and revoke- clientlist can also show ips (paramter -ip)- fixed an issue were channel properties saved two times on create or edit- fixed an issue were clientdbdelete did not delete avatar files correctly- fixed invalid ident names for virtualserver_antiflood_points_needed_command_block and virtualserver_antiflood_points_needed_ip_block (breaks client-side serveredit below version 3.0.6)
K_tech Απρίλιος 24, 2012 #1778 Απρίλιος 24, 2012 K-Lite Codec Pack 8.70 (Full)* Updated Media Player Classic Home Cinema to version 1.6.2.4485* Updated ffdshow to version 1.2.4436* Updated LAV Filters to version 0.50.1 build 2012-04-22* Removed obsolete WavPack, Musepack, and AMR decoders. These formats arenow decoded using LAV Filters.* Updated Codec Tweak Tool to version 5.3.2* Updated MediaInfo Lite to version 0.7.56* Updated GraphStudioNext to verion 0.4.9.1* Updated Icaros to version 2.0.0K-Lite Mega Codec Pack 8.70* Updated Media Player Classic Home Cinema to version 1.6.2.4485* Removed MPC-HC 1.2.1008.0* Updated ffdshow to version 1.2.4436* Updated LAV Filters to version 0.50.1 build 2012-04-22* Removed obsolete WavPack, Musepack, and AMR decoders. These formats are now decoded using LAV Filters.* Updated x264VFW to revision 2184* Updated Codec Tweak Tool to version 5.3.2* Updated MediaInfo Lite to version 0.7.56* Updated GraphStudioNext to verion 0.4.9.1* Updated Icaros to version 2.0.0
