K_tech Απρίλιος 14, 2012 #1741 Απρίλιος 14, 2012 Macrium Reflect 5.0.4432# Bug fixes:* Installer:- When updating Reflect, if the installer is used instead of the normal patch procedure, email settings will be lost. This has been resolved.* Email attachments:- Byte order marker being rendered in emailed log attachments in some email clients. This has been resolved.* Image to DVD:- In some Vista/Win7 installs omaging to DVD could cause an 'Invalid (not writeable)' error. This has been resolved.* VSS:- VSS snapshot creation could fail if a VSS writer component is configured to use a volume that no-longer exists on the system. This has been resolved.* Unattended System restore:- Restore with auto reboot into the rescue environment could fail if the local drives were re-sequenced by Windows PE. This has been resolved.* Rescue environment:- Hitting escape after clicking the taskbar may result in it being hidden. This has been resolved.* Rescue environment:- The list of existing images was not always populated when booted into WinPE recovery. This has been resolved.* File and folder backup incremental and differential speed isssue:- An issue where the NTFS permissions setting in full backups was not being honoured in incremental backups. This has been resolved.
K_tech Απρίλιος 19, 2012 #1760 Απρίλιος 19, 2012 FrostWire 5.3.5* Drag and drop files and folders to your Android device running FrostWire.* You can upload files to 3 different devices at the same time.* Fixes glitch where the file explorer would reset the split pane position.* Removes flickering on album arts when resizing library explorer* When the FrostWire window is resized to be very small the search filters no longer overlap the "Open" and "Send to" buttons.* Search box on the Library is now on the upper left and offers contextual hint.* Search boxes everywhere now have a clear button.* Playlists are now sorted alphabetically.* Option panes UI upgrades.* Better suggestion for a playlist name when a folder is dropped on "New Playlist".* German translation updated.* French translation updated.* Norwegian translation updated.* Dutch translation updated.* Japanese translation updated.* Filipino translation updated.* Chinese (Hong Kong) translation updated.* Chinese (Taiwan) translation updated.* Chinese (Mainland) translation updated.* Turkish translation updated.* Portuguese (Brazilian) updated.* Korean translation updated.* Italian translation updated.* Hindi translation updated
