K_tech Απρίλιος 11, 2012 #1723 Απρίλιος 11, 2012 Adobe Reader 10.1.3# Improvements* Application Security- New Security Ratings- Protected Mode and Protected View* Apple browser support* Acrobat.com services integration (SaaS)- Signatures and Adobe EchoSign- Export PDF* Printing# Bug fixes* Stability* PDF Conversion* Miscellaneous
K_tech Απρίλιος 11, 2012 #1725 Απρίλιος 11, 2012 PeaZip 4.4.0# FILE MANAGER* Added keyboard shortcuts- Ctrl+Alt+F3 (web search form) and Shift+Alt+F3 (web search on peazip.org)- Ctrl+F5 (open path) Shift+F5 (open archive)- (Windows) New quick window docking menu: send PeaZip to the four sides and angles of the desktop with Ctrl+Alt+arrow* (Windows) Added "Properties" dialog in context menu* Added switches> -add2multiseparate: start a single instance, add multiple input to archive, each to separate archive> -add2multisplit (replaces add2split): start a single instance, add multiple input to file split (consolidate in tar if it is not a single file)> -ext2browseasarchive: force opening the file as archive* (Windows) Added "Check for updates" feature in help group* Fixed display the application in foreground when started* (Windows) Improved startup times in slow network environment- By default, does not get mapped network drives information- If set to get information, in case of failure the switch is ignored for the session, and then tried again in next sessions* Improved "Save job definition"- Featured as context menu in archiving and extraction interfaces- (Windows) by default saves as .bat file with default system's character encoding, so the script can be directly executed- It is now possible to save job definition for extracting multiple files at once- It is now possible to save job definition for archiving each input item to separate archives- Job definition scripts are saved by default in PeaZip's applications data path (user specific for installable version)* Improved file split/join features- (Windows) Split file featured by default in system context menu- Split is by default a favourite format (Add button's context menu, Archive interface)- Re-introduced file split/join entries in File tools submenu- Selecting Split format automatically switches volume size to Custom- Fixed a graphic glitch in displaying file split buttons- No checksum by default, consistently with default behavior of other file split utilities* Improved file/archive manager- Improved context menu, now divided in 3 functional areas> Archive management (top) add, extract, test, password...> Navigation (middle) navigation and organization features (browser mode, sorting, select)> File management (bottom) open with, rename, delete, properties...- Improved status area> Status area displays a quick switch button between views (same as Alt+8)> Status bar and Details bar displays basic controls to customize browser type and size> Improved Details view- Improved toolbar area, buttons are auto sized for optimal placement- Improved navigation bar> More prominence given to Open path, Open archive, and Search and drag here, moved in a top level branch expaneded by default> Application menu opens selected objects with chosen application, launches the application if nothing is selected> Added quick jump context menu to navigation bar (same popup menu as for the root of breadcrumb in the address bar)- Improved Web search adding search in Google+ and SourceForge# WINDOWS INSTALLER* (Windows 7+) Added option to use non-cascaded menu as alternative to default cascaded menus (flag Custom during installation, or run System integration wizard)* Added -ext2browseasarchive "Open as archive" action for any file type* Added "Extract archives" to any file type when the menu is cascaded, as quick shortcut to open extraction interface (accepts dropping files) or fallback if an archive type is not associated with PeaZip for any reason* Removed emergency Start menu link "Reset PeaZip", moved as .bat in PeaZip's /res folder* SendTo menu by default features Add, Extract, Open as archive, and Browse path with PeaZip entries
K_tech Απρίλιος 11, 2012 #1726 Απρίλιος 11, 2012 Google Chrome 20.0.1096.1 Dev* Updated V8 - 3.10.0.5* file: downloads allowed again.* Enable the Chrome To Mobile page action for users with compatible registered devices * Fixed issues
K_tech Απρίλιος 12, 2012 #1730 Απρίλιος 12, 2012 DAEMON Tools Lite 4.45.4# New:- Enhanced privacy of connection with MountSpace.com;- SPTD 1.81 (Windows 8 beta support);- SPTD: attached devices read speed improvement;- Setup improvements.# Bugs fixed:- File associations inheriting after update or reinstallation;- Automount settings resetting after unsuccessful automounting on startup;- Minor fixes.
K_tech Απρίλιος 13, 2012 #1735 Απρίλιος 13, 2012 Maxthon 3.3.7.1000# New Feature:* Updated JavaScript engine.# Fixes:* Main Frame- Side Bar and Status Bar could be dragged if the browser window was maximized.- Quick App exited improperly.- Sequence problem of the icons in Side Bar.- Incorrect task number displayed in Download Manager.- Tab "close" button display problem.* Webkit Core- Fixed one Inertia-Clickjacking security breach.- Several stability problems related to Webkit Core.- The username displayed as messy code in kyohk.net.- Night Mode did not work in some sites.- Some page loading problems.- Two scroll bar problems.* Extension Interface of IE Core- Interface problem in Retro Mode.* RSS- Data import problem.
K_tech Απρίλιος 14, 2012 #1739 Απρίλιος 14, 2012 Skype 5.9.0.114* Screen sharing - Red contours shared window had defects when moving the window around- It was not possible to initiate screen sharing session when user was in invisible state* Video- Webcam in use message was not displayed properly* Profile- It was not possible to change on your own profile your phone numbers country code* Generic- Skype crashed when pressing "esc" while editing contacts phone number* Video- Video preview did not close after switching the video off* Calling- Add people to call did not list contacts from other contact list than currently active* Accessibility- When receiving multiple files at once the file* Options- Seldom expanding options sub menus did not work* Group conversations- Sometimes instead of contacts full name a Skype name was shown instead on group calls* Generic- On two monitor setup when switching from default mode to compact mode Skype was put to secondary monitor* Localization- Localization to all languages updated
K_tech Απρίλιος 14, 2012 #1740 Απρίλιος 14, 2012 Flash Player 11.2.202.233 (IE)Flash Player 11.2.202.233 (Non-IE)
