hayabusa Απρίλιος 7, 2012 #1703 Απρίλιος 7, 2012 FastPictureViewer Pro (32-Bit) 1.8.245FastPictureViewer Pro (64-bit) 1.8.245
K_tech Απρίλιος 8, 2012 #1705 Απρίλιος 8, 2012 AIMP 3.00.985- Localizations were updated- Fixed: Player isn't able to use WASAPI for outputting on Windows 8- Fixed: Player does not play short files completely- Fixed: Small scratches can be heard on jumping from one track to another when equalizer is switched on- Fixed: Incorrect information about bitrate is displayed for some radio stations- Fixed: Windows Explorer does not display data from tags of file in WMA Lossless format after they've been edited by AIMP- Fixed: DropWheel window is painted incorrectly in AIMP2 skins- Fixed: File mark does not display in playlist when AIMP2 skin is used- Fixed: Incorrect information about file format is displayed in Quick Tag Editor in some cases- Fixed: Incorrect information about bitrate and duration is displayed for some files in OGG format- Fixed: Files are added in backward order when they are adding via "Find new files" dialog- Fixed: Some problems with TrayControl behavior- Fixed: Player starts playback of switched off tracks when jumping to another playlist via hotkeys- Fixed: Small bugs and defects
K_tech Απρίλιος 8, 2012 #1706 Απρίλιος 8, 2012 UltraDefrag 5.0.4 (32-bit)- dirty volumes needing CHKDSK repair were returned to the drives list with a special mark in their status field- taskbar icon overlay indicating that a job is running was added for Windows 7 and more recent Windows editions; it can be turned on/off by show_taskbar_icon_overlay GUI option- menu item to manually check for updates added- i18n support was added to file fragmentation reports- the following translations were updated: Korean, French (FR), Spanish (AR), Croatian, Spanish (MEX), Wáray-Wáray- menu icons for high DPI screens were added- Internals: WgxSetTaskbarIconOverlay, WgxRemoveTaskbarIconOverlay, WgxLoadIcon and WgxGetTextDimensions routines added to wgx library- WgxGetResourceString behavior changed- math.lshift function added to Lua library- incremental compilation enabled- MS Visual Studio 6.0 development environment support dropped
vgiozo Απρίλιος 8, 2012 #1707 Απρίλιος 8, 2012 Πρόσφατα βρήκα ένα ωραίο προγραμματάκι, μια βελτιστοποιημένη έκδοση του Firefox για 64μπιτα συστήματα...λέγεται WaterfoxΤο δουλεύω με ξεχωριστό προφίλ δίπλα στον Firefox και αποδεικνύεται πολύ αποδοτικός...η εναλλακτική στον Firefox είναι λοιπόν μια βελτιστοποιημένη για 64bit και windows έκδοση του ίδιου πλοηγητή...Όλα τα addons είναι συμβατά καθώς και τα περισσότερα plugins (δεν έχω βρει κάποιο που δεν δουλεύει μέχρι στιγμής)Δηλώνω φαν...δοκιμάστε το όσοι έχετε 64bit λειτουργικό Windows...What is Waterfox? Waterfox is a high performance browser based on the Mozilla Firefox source code. Made specifically for 64-Bit systems, Waterfox has one thing in mind: speed.Why should I use a 64-Bit version of Firefox? 64-Bit computing is the future! Any 64-Bit user will notice an instant increase in performance, but that is not the only advantage such as multi-tasking and improved stress handling.If there are any bugs, where should I report them? Unfortunately, since this is a 3rd party build you cannot report any bugs and you’ll just have to hope that they get fixed in the next update by Mozilla.Is my experience limited if I use a 64-Bit version of Firefox? The major plugins such as Adobe Flash, Sun Java, Microsoft Silverlight all have supported 64-Bit binaries available.How does it compare to 32-Bit Firefox? In benchmarks, the 64-Bit variant of Firefox out-performs the 32-Bit variant. Also because this variant is being built specifically for Windows, there might be further performance increases.Were there any optimisations made? Yes, Waterfox was compiled with SSE2, the AMD Core Math Library and the following optimisation flags: /O2 /GR- /GS- /GADo all my Add-Ons work? Yes! Add-Ons work on any version of Firefox, on any platform.I get a msvcr100.dll is missing error. You must have the Visual C++ Redistributable file linked in the download page installed.How do I fix the blurry font? Type about:config in the address bar. In the filter at the top type gfx.direct2d.disabled. Change it from false to true.Waterfox uses the same profile that Firefox does. If you uninstall Waterfox make sure you don't have the remove personal data box ticked!
hayabusa Απρίλιος 9, 2012 #1709 Απρίλιος 9, 2012 Free YouTube Download 3.1.23Free YouTube to MP3 Converter 3.11.18Free Video Flip and Rotate 2.0.3
hayabusa Απρίλιος 9, 2012 #1712 Απρίλιος 9, 2012 Flash Player 11.3.300.214 Beta 1 (IE)Flash Player 11.3.300.214 Beta 1 (Non-IE)
