spc Νοέμβριος 8, 2005 #141 Νοέμβριος 8, 2005 ffdshow (αν δεν έπαιρνα βρε vgiozo την δόση μου από realtek αυτή την εβδομάδα θα πάθαινα κάτι )
vgiozo Νοέμβριος 8, 2005 #142 Νοέμβριος 8, 2005 Mε πρόλαβαν τη προηγούμενη φορά και τό 'χα απωθημένο...Πραγματικά πάντως, πώς κι έχουν τόσο συχνές ενημέρωσεις σε οδηγούς;; Βελτιστοποιήσεις, διορθώσεις;;Με είχαν σώσει με το λαπτοπάκι οι οδηγοί της Ρεαλτεκ, γιατί στο Battlefield μου έβγαζαν μόνιμο θόρυβο της Νβιντια...αλλά γενικάμου τρέχουν καλύτερα οι Realtec...
vgiozo Νοέμβριος 9, 2005 #143 Νοέμβριος 9, 2005 WavPack 4.30WavPack is a completely open audio compression format providing lossless, high-quality lossy, and a unique hybrid compression mode. Although the technology is loosely based on previous versions of WavPack, the new version 4 format has been designed from the ground up to offer unparalleled performance and functionality.In the default lossless mode WavPack acts just like a WinZip compressor for audio files. However, unlike MP3 or WMA encoding which can affect the sound quality, not a single bit of the original information is lost and so there's no chance of degradation. This makes lossless mode ideal for archiving audio material or any other situation where quality is paramount. The compression ratio depends on the source material, but generally is between 30% and 70%.The hybrid mode provides all the advantages of lossless compression with an additional bonus. Instead of creating a single file, this mode creates both a relatively small, high-quality lossy file that can be used all by itself, and a "correction" file that (when combined with the lossy file) provides full lossless restoration. For some users this means never having to choose between lossless and lossy compression!WavPack frontend 2.0: You really need this graphical user interface for command-line encoder and decoder. If you get an error when you try to run the frontend, you need one of the following files (the error message indicates which one): Visual Basic 6 Runtime files, mscomctl.ocx or tabctl32.ocxCoreWavPack: is a set of DirectShow filters to support the WavPack Audio Codec that allows playing WavPack files (.wv .wvc) in any DirectShow based media player
vgiozo Νοέμβριος 10, 2005 #144 Νοέμβριος 10, 2005 * K-Lite Mega Codec Pack 1.41* K-Lite Codec Pack 2.61 Full/Standard/BasicChanges from K-Lite Codec Pack 2.60 FULL to K-Lite Codec Pack 2.61 FULL :- In the previous version the uninstallation could freeze on Windows 9x systems if ffdshow was installed. The current uninstaller has a workaround for that problem. Install this version on top of version 2.60 to replace the uninstaller.- Because of the problems with ffdshow on Windows 9x systems, the installer will no longer allow ffdshow to be installed on those systems. ffdshow be available again on Windows 9x systems in a future version when the ffdshow developers have fixed the current problems with running ffdshow on Windows 9x systems.- Minor changeshttp://www.codecguide.com/Αφού εξέδωσαν το πακέτο πάλι θα μπορούσαν να ενσωματώσουν και το καινούριο ffdshow MPEG-4 Video Decoder 2005-11-09http://www.free-codecs.com/FFDShow_download.htm
vgiozo Νοέμβριος 10, 2005 #145 Νοέμβριος 10, 2005 SetPoint 2.46 Version: 2.46 Posted: 10/17/2005http://www.logitech.com/index.cfm/downloads/software/FR/EN,CRID=1796,contentid=9697,OSID=1(H σελίδα δείχνει στο LX300, αλλά το λογισμικό είναι κοινό για όλα τα προϊοντα αν δεν κάνω λάθος)
helloween Νοέμβριος 10, 2005 #146 Νοέμβριος 10, 2005 Visual Studio 2005 Express Editions Free Downloadhttp://www.9down.com/modules.php?name=News&file=article&sid=5756
helloween Νοέμβριος 10, 2005 #147 Νοέμβριος 10, 2005 Security Updates for IE7 and Vista Beta 1http://www.neowin.net/comments.php?id=31361&category=main
vgiozo Νοέμβριος 11, 2005 #148 Νοέμβριος 11, 2005 Πυρετός ενημερώσεων...πάω να κατεβάσω την προηγούμενη έκδοση και βλέπω καινούρια...New versions are out:* K-Lite Mega Codec Pack 1.42* K-Lite Codec Pack 2.62 Full/StandardAnd a beta version:QuickTime AlternativeChangelog 2.61 -> 2.62:- Updated ffdshow to build 2005-11-09- ffdshow works on Windows 9x again- Updated MP4 splitter to build 2005-11-10- Updated Matroska splitter to build 2005-11-10- Added Ogg splitter (made by Haali) build 2005-11-10- Removed Ogg splitter (made by Gabest)http://www.codecguide.com/Καλύτερα έτσι πάντως, αφού συνέπεσε η διάθεση της προηγουμενης έκδοσης με την διάθεση νέων εκδόσεων haali media splitter, ffdshow...αν και καινούρια η έκδοση 2,60 θα ήταν "παλιά"...
helloween Νοέμβριος 11, 2005 #149 Νοέμβριος 11, 2005 Catalyst 5.11https://support.ati.com/ics/support/default.asp?deptID=894
vgiozo Νοέμβριος 12, 2005 #150 Νοέμβριος 12, 2005 Firefox 1.5 Release Candidate 2http://www.mozilla.org/projects/firefox/
rip_noob Νοέμβριος 13, 2005 #151 Νοέμβριος 13, 2005 Unlocker 1.7.5 Ενα απο τα αγαπημενα μου προγραμματα Αμα εχετε προβλημα στο να διαγραψετε καποιο αρχειο και λεει πως χρησιμοποιειται ηδη οπως την εικονα τοτε το unlocker ειναι η καλυτερη λυση. Μικρο στο μεγεθος και δωρεαν. http://ccollomb.free.fr/unlocker/
helloween Νοέμβριος 14, 2005 #152 Νοέμβριος 14, 2005 Daemon Tools 4.0 has been released.http://iexbeta.com/
FrOsT Νοέμβριος 14, 2005 #153 Νοέμβριος 14, 2005 ForceWave 81.94-Adds support for GeForce 7800 GTX 512 and GeForce 6800 GS -Improved performance for Quake 4 -Improved performance and compatibility for Call of Duty 2 -Mixed vendor support for NVIDIA SLI. -TV-Out/HD-out support for NVIDIA SLI. -Added support for VSync on Direct3D games when running NVIDIA SLI. -Performance enhancements for dual-core CPUs. -PureVideo high definition MPEG-2 de-interlacing support. -Usability enhancements when connecting to an HDTV. -Microsoft
vgiozo Νοέμβριος 15, 2005 #154 Νοέμβριος 15, 2005 New versions are out:* K-Lite Mega Codec Pack 1.43* K-Lite Codec Pack 2.63 Full/Standard* QuickTime Alternative 1.54* QuickTime Alternative 1.66http://www.codecguide.com/Haali Media Splitter14/11/2005 [General] Fixed creating shortcut in installer, a few other minor improvements.http://haali.cs.msu.ru/mkv/O Haali media splitter στο Klite codec pack είναι μια ημέρα παλαιότερος...προβλεπω αύριο μεθαύριο πάλι νέα έκδοση Κ-Λιτε...οπότε περιμένετε...
vgiozo Νοέμβριος 18, 2005 #155 Νοέμβριος 18, 2005 Windows Genuine Advantage Plug-in installationA Plug-in is a helper program that can be downloaded and installed to extend the functionality of a Mozilla-based Web browser. You may download and install the Windows Genuine Advantage Plug-in in order to use this web site for validation of your copy of Windows.http://www.microsoft.com/genuine/downloads/InstallPlugin.aspx?displaylang=en&sGuid=f87510e2-b622-4755-b8d1-a7773e82fa2c
helloween Νοέμβριος 18, 2005 #156 Νοέμβριος 18, 2005 Firefox 1.5 RC 3http://www.mozilla.org/projects/firefox/
helloween Νοέμβριος 18, 2005 #157 Νοέμβριος 18, 2005 Slysoft AnyDVD v5.5.4.1http://www.9down.com/modules.php?name=News&file=article&sid=5787
vgiozo Νοέμβριος 19, 2005 #159 Νοέμβριος 19, 2005 Winamp TV is a plugin for Winamp that lets you control your TV tuner card from within the multimedia playerhttp://www.free-codecs.com/download/Winamp_TV.htm
vgiozo Νοέμβριος 20, 2005 #160 Νοέμβριος 20, 2005 FFDSHOW 2005-11-20 SSE2http://mirror02.x264.nl/x264/ffdshow-20051120-gcc4.0.2-sse-x264.nl.exe"the FFDSHOW consumes way less CPU power than original DivX or XviD codecs, even with maximum post-processing. At the same time the post-processing seems to give excellent quality results and allows more configuring than the original DivX codec. It can even automaticly reduce post-processing if your CPU is getting overloaded. The noise filter adds a kind of a rasterising effect to the picture - might be useful in some cases."
