Καινούργιες εκδόσεις (Haya)
PGM
iCall 7.1.521
iCall is software that enables you to make completely free PC-to-phone and PC-to-PC calls. iCall includes features such as free customizable voicemail, incoming numbers, call forwarding, toll free numbers, caller ID, free directory service and dirt cheap international calling. iCall sounds better than a traditional telephone, features an extremely intuitive interface, and works with virtually any network configuration.
  • Replies 2,4k
Total Commander 7.57a
- Fixed: Icon thread (used to load icons and calculate dir size in background) may stop when adding files to background transfer manager
- Fixed: When packing each selected file/folder to a separate archive, the selection was no longer cleared after packing
- Fixed: Updated Chinese translation
- Added: Log function for icon thread: wincmd.ini [Configuration] DebugIconThread=1 to allow test why icon extraction or dir size calculation hangs (=2 for more details)
- Fixed: Use old function to check for infinite loops in Alt+Shift+Enter function (count directories), it may be responsible for the failing of the function
- Fixed: Selecting text with the mouse in compare by content no longer worked
FrostWire 5.3.3
* Noticeable improvements in CPU performance.
* Noticeable improvements in search result quality.
* Updated TPB search to support magnet link search results.
* Added UT_METADATA extension to Vuze Core for improved magnet link support.
* Upgraded Lucene library to v3.5.0.
* Upgraded H2 to v1.3.164.
* When browsing FrostWire for Android devices (0.9.6+), date added and date modified fields are available on all file types.
LibreOffice 3.5.1 RC 2
# Core
* "Distributy Columns Evenly" does not work with the selected columns
* add Gurmukhi MT font for pa-IN
* don't copy page styles into temporary clipboard doc
* don't crash for empty input data in charts
* don't create uno::Sequence with new
* don't show an error message for empty names in Define Names
* expand group memberships in PostgreSQL-SDBC get*Privileges
* fix core when clicking on entries in Manage Names dialog in calc
* fix crash using instances dialog of dataform navigator
* pack libstdc++ and libgcc_s only in the new stdlibs subpackage
* resolves Fix Partial::contains for paths that go past a leaf node
* UI fix on PDF export dialog
* use Traditional Chinese installer for zh-HK and zh-MO locales
* use the correct db range for the copy
Gladinet Cloud Desktop 4.0.854
Gladinet Cloud Desktop mounts cloud storage as local folders. Users can access their cloud files in Windows Explorer. Supported storage includes Amazon S3, AT&T Synaptic, Box.net, EMC Atmos onLine, FTP, Google Docs and Picasa, Google Storage for Developer, Mezeo, Nirvanix, OpenStack, Peer1 CloudOne, Rackspace Cloud Files, WebDav, Windows Azure Storage, and more. Once the storage is mounted as local folders, users can setup backup tasks in Gladinet, to simultaneously backup multiple local folders to a redundant arrary of cloud storage. For example, users can backup a local folder on drive C and another on drive D to an FTP server, Amazon S3 and WebDav server in a single task. Users can also setup Google Docs backup task, to backup documents in Google Docs to other cloud storage directly.
