K_tech Μάρτιος 2, 2012 #1501 Μάρτιος 2, 2012 PowerDVD 12.0.9026- Import and organize your music, videos, and photos in the PowerDVD Media Library. - Effortlessly browse through the videos and photos in media folders using Instant View. - Use media tabs to quickly access and play media in the PowerDVD media library, or on connected DLNA or mobile devices. - Now supports TrueTheater 3D* and Instant Seek on Blu-ray Discs. - Now supports the OGG and FLAC audio formats. - Now supports DTS-HD 7.1 audio*. - Now supports MKV with HD-Audio (DTS, Dolby, and LPCM) pass-through via HDMI 1.3/1.4*. - Precise digital zoom control during the playback of movie discs and video files with Instant Zoom. - Purchase and download music from the 7digital music store directly into the PowerDVD Media Library. - Use PowerDVD Mobile to wirelessly stream media in the media library to and from mobile Android and Apple devices. - Stream media in the Media Library to other computers and devices connected to the same network*. - Allow other computers and devices to control the playback of the media in the PowerDVD Media Library*. - Sync all of the media in the Media Library with connected Android devices via a USB connection*. - Drag and drop media from an Android device into the Media Library. Note: * this feature is not available in some versions of CyberLink PowerDVD.
K_tech Μάρτιος 2, 2012 #1504 Μάρτιος 2, 2012 Speccy 1.16.317- Added Windows 8 beta support.- Rearchitecting data loading order.- Improved exception handling for CPU and GFX sections.- Improved detection of Admin Shares.- Improved bug data collection and reporting.- Fixed minor GUI issues.
hayabusa Μάρτιος 2, 2012 #1505 Μάρτιος 2, 2012 Hide Drives 3.5.4.1Hide Drives is a very easy to use app with advanced features, which allows you to hide and/or disable access to any disk drives on your desktop/laptop/tablet PCs for all users or for any specific user. No installation is required, it is a portable app, runs well on Windows Vista and 7.
hayabusa Μάρτιος 2, 2012 #1506 Μάρτιος 2, 2012 Magic Actions for YouTube 4.8Magic Actions for YouTube is a lightweight and useful add-in designed for a more comfortable watching experience. It gives instant control over volume by scrolling mouse wheel, OSD on-screen display, any webpage with an embedded YouTube video and HTML5 video player support.
hayabusa Μάρτιος 2, 2012 #1507 Μάρτιος 2, 2012 Free USB Guard 1.0Free USB Guard will alert you in case a flash drive (or another external drive) is attached during the shutdown or log off process. The shutdown or log off will be blocked allowing you to take out the flash drive. The software can also detect them only if they are plugged after the software has been started. Otherwise you can select them manually in the menu "monitor the presence of these drives".
hayabusa Μάρτιος 3, 2012 #1508 Μάρτιος 3, 2012 FastPictureViewer Pro (32-Bit) 1.7.241FastPictureViewer Pro (64-bit) 1.7.241
hayabusa Μάρτιος 5, 2012 #1515 Μάρτιος 5, 2012 Win Lock Pro 8.0Win Lock PRO is a screen lock and computer login program created by BlueZap Industries. The project was inspired by the Windows 8 Login and screen lock system. We bring Windows 8 to Windows 7 in style ! Please download the latest versionWhat's new in this version: Version 8.0 added security modules, ease of access has been added including a cutom narrator option, login screen power button has been re-designed to resemble the Windows 8 power button even more, ALT , TAB , WIN keys have been disabled when Winlock Pro is in use (increases security), buttons have been re-designed.
hayabusa Μάρτιος 6, 2012 #1516 Μάρτιος 6, 2012 Flash Player 11.1.102.63 (IE)Flash Player 11.1.102.63 (Non-IE)
