K_tech Ιανουάριος 31, 2012 #1345 Ιανουάριος 31, 2012 PowerDVD 12.0.8680* Import and organize your music, videos, and photos in the PowerDVD Media Library. * Effortlessly browse through the videos and photos in media folders using Instant View. * Use media tabs to quickly access and play media in the PowerDVD media library, or on connected DLNA or mobile devices. * Now supports TrueTheater 3D* and Instant Seek on Blu-ray Discs. * Now supports the OGG and FLAC audio formats. * Now supports DTS-HD 7.1 audio*. * Now supports MKV with HD-Audio (DTS, Dolby, and LPCM) pass-through via HDMI 1.3/1.4*. * Precise digital zoom control during the playback of movie discs and video files with Instant Zoom. * Purchase and download music from the 7digital music store directly into the PowerDVD Media Library. * Use PowerDVD Mobile to wirelessly stream media in the media library to and from mobile Android and Apple devices. * Stream media in the Media Library to other computers and devices connected to the same network*. * Allow other computers and devices to control the playback of the media in the PowerDVD Media Library*. * Sync all of the media in the Media Library with connected Android devices via a USB connection*. * Drag and drop media from an Android device into the Media Library.
K_tech Ιανουάριος 31, 2012 #1346 Ιανουάριος 31, 2012 WinPatrol 24.1.2012.0* Delayed Start- While not everyone had the same experience some folks reported that Delayed Start was no longer working with WinPatrol 2012. This update will resolve this error and give back one of your favorite features.* Hidden Files 64 bit- This update also helps fix a bug in the display of hidden files on 64 bit versions of Windows. It doesn't affect any other versions and has no impact unless you're using Windows 64 bit version. You'll know you have Windows 64 bit if you notice the you have both a Program Files folder and one called Program Files (x86).
K_tech Ιανουάριος 31, 2012 #1347 Ιανουάριος 31, 2012 Malwarebytes Anti-Malware 1.60.1# Issues Fixed:* Fixed issue resulting in freezes in certain third-party security products on Windows XP.* Fixed issue where ignore list was not reloaded after a database update.* Fixed issue where certain malformed ignore list data would result in a mbamcore.dll crash.* Fixed issue where desktop icon was not created on certain upgrade installations.* Fixed issues with Dutch, Belarusian, and Korean language files.* Added Greek language file.
hayabusa Φεβρουάριος 1, 2012 #1350 Φεβρουάριος 1, 2012 Hard Disk Sentinel Free 4.0Hard Disk Sentinel Pro 4.0
K_tech Φεβρουάριος 2, 2012 #1354 Φεβρουάριος 2, 2012 Flash Player 11.2.202.197 Beta 5 (IE)Flash Player 11.2.202.197 Beta 5 (Non-IE)
K_tech Φεβρουάριος 2, 2012 #1357 Φεβρουάριος 2, 2012 Windows 7 Codecs 3.4.3- update LAV filters .45+- update FFDshow 4292- update Gabests filters 4026- update Intel QuickSync r30
K_tech Φεβρουάριος 2, 2012 #1358 Φεβρουάριος 2, 2012 Miro 4.0.6* Bug fixes- (windows) Feeds stopped updating- (all) non-torrent downloads (feeds or individual) update on download and use filename instead of original item name.- (all) TypeError: can only concatenate list (not "set") to list
