Καινούργιες εκδόσεις (Haya)
PGM
  • Replies 2,4k
Opera 11.60 Beta 1 (Build 1147)
  • Speed Dial: Your favorite sites are just one click away at all times.
  • Search Shortcuts: Faster search - type your queries directly into the address bar.
  • Trash Can: Instantly reopen recently closed tabs.
  • Mouse Gestures: With Opera you can navigate the Web with your mouse.
  • Opera Link: Synchronize data of your choice online, or among different computers and devices.
  • Quick Find: Opera remembers not only the titles and addresses, but also the actual content of the Web pages you visit.
  • Feed Preview: Preview a Feed by clicking on the feed icon, and you will see it in clean and efficient multiple-column layout.
  • Quick and customizable Web search: Get quick access to Google, eBay, Amazon and more with the search field in the upper right corner.
FastPictureViewer 1.6 Build 218
  • Fastest RAW viewer ever. Period.
  • Instant zooming to 100% view, for quick sharpness checks. Best in industry!
  • RGB histogram, EXIF shooting data and Adobe XMP Rating/Label/Urgency instant display.
  • Instantaneous display of the next image in line (when computer resources allows).
  • Instant industry-standard Adobe XMP compatible rating and tagging.
  • Fast tethered shooting through MTP/PTP. Tether a Nikon D3S or D3X in 64 bit, today!
  • Supports most common image formats, including Adobe DNG, plus specialists formats such as OpenEXR, DDS, PNM and more, through separately installable image codecs.
DAEMON Tools Lite 4.45.1
- Support of FLAC image files;
- Flexible scheme of adding DT and SCSI virtual devices (maximum 4 in total);
- Separate Autostart option;
- Drag-and-drop of folders that contain image files;
- Improvements in auto update process;
- SPTD 1.79.
* Bugs fixed:
- Incompatibility with McAfee;
- GUI issues with some RTL languages (Arabic, Hebrew etc);
- Crash with Danish language;
- Command line parameter get_count returns quantity of virtual devices of specific type by default;
- Minor bugs.
Flash Player 11.1.102.55
  • Immersive experiences with Flash video, content and applications with full-screen mode.
  • Low-bandwidth, high-quality video with advanced compression technology.
  • High-fidelity text using the advanced text rendering engine.
  • Real-time dynamic effects with filters for Blur, DropShadow, Glow, Bevel, Gradient Glow, Gradient Bevel, Displacement Map, Convolution, and Color Matrix.
  • Innovative media compositions with 8-bit video alpha channels.
  • Blend modes, radial gradient, and stroke enhancements.
  • Additional image formats: GIF, Progressive JPEG, and PNG.
Total Commander 8.00 beta 9
  • Two file windows side by side
  • Multiple language support
  • Enhanced search function
  • Compare files (now with editor) / synchronize directories
  • Quick View panel with bitmap display
  • ZIP, ARJ, LZH, RAR, UC2, TAR, GZ, CAB, ACE archive handling + plugins
  • Built-in FTP client with FXP (server to server) and HTTP proxy support
  • Parallel port link, multi-rename tool
  • Tabbed interface, regular expressions, history+favorites buttons
  • Thumbnails view, custom columns, enhanced search
  • Compare editor, cursor in lister, separate trees, logging, enhanced overwrite dialog, and more
Notepad++ 5.9.6.2
  • Syntax Highlighting and Syntax Folding
  • WYSIWYG
  • User Defined Syntax Highlighting
  • Auto-completion
  • Multi-Document
  • Multi-View
  • Regular Expression Search/Replace supported
  • Full Drag 'N' Drop supported
  • Dynamic position of Views
  • File Status Auto-detection
  • Zoom in and zoom out
  • Multi-Language environment supported
  • Bookmark
  • Brace and Indent guideline Highlighting
  • Macro recording and playback
Defraggler 2.08.373
- Added Disk and File benchmarking.
- Added Volume Shadow Service (VSS) compatible mode.
- Improvements to disk health tab.
- Added Real Value information to SMART data.
- Health tab now supports Fahrenheit.
- Improvements to SSD detection.
- Minor fixes to scheduler stop commands.
- Minor defrag algorithm improvements.
- Translation fixes.
Google Chrome 15.0.874.121
One box for everything
Type in the address bar and get suggestions for both search and web pages.
Thumbnails of your top sites
Access your favorite pages instantly with lightning speed from any new tab.
Incognito mode
Don't want pages you visit to show up in your web history? Choose incognito mode for private browsing.
Safe browsing
Google Chrome warns you if you're about to visit a suspected phishing, malware or otherwise unsafe website.
