K_tech Οκτώβριος 20, 2011 #1003 Οκτώβριος 20, 2011 Opera 11.52# Display and scripting* Fixed- Adjusting volume on a YouTube HTML5 Video causes freeze- Fixed a non-exploitable bug which allowed injection of untrusted markup into the X-Frame-Options error page.# Network* Fixed- Crashes when downloading via BitTorrent# Security* Fixed- Fixed an issue where manipulating fonts in SVG could allow execution of arbitrary code
dmarccos Οκτώβριος 20, 2011 #1006 Οκτώβριος 20, 2011 Mozilla Firefox 8.0 beta4Mozilla Thunderbird 8.0 beta2
K_tech Οκτώβριος 21, 2011 #1007 Οκτώβριος 21, 2011 WinRAR 4.10 Beta 2 (32-bit)* Volume size in archiving and wizard dialogs can be specified as a decimal fraction. Decimal mark is defined by Windows regional settings.-v command line switch also allows decimal fractions. In command line mode the dot (.) is always used as the decimal mark. For example, -v1.5g switch means 1.5 gigabytes.* "Add" command in first WinRAR beta did not allow to create a console SFX archive using WinCon.SFX module.* If ZIP archive contained ZIP Unicode path extra fields, the first beta could not unpack files in subfolders of such archive.* "CD700" and "FAT32" predefined volume sizes did not work properly.
hayabusa Οκτώβριος 21, 2011 #1009 Οκτώβριος 21, 2011 Chrome 16.0.912.4All - Updated V8 - 3.6.6.5 - Fixed stability issue in Print and Instant Mac - Fixed bugs introduced in the last Dev Channel release with Pepper 3D on Mac OS X, primarily affecting Native Client applications using OpenGL.
K_tech Οκτώβριος 24, 2011 #1010 Οκτώβριος 24, 2011 Google Earth 6.1.0.5001# Fixed bugs and product changes:* To conform more closely with the OGC KML 2.2 standard, we've made the parsing of the <coordinates> tag more strict in version 6.1. Spaces must only be used to separate the (longitude,latitude,altitude) triplets which specify the coordinates of a single point. It is invalid to add spaces between individual coordinates. We understand that previous versions of the client were more lenient, so if your KML files contain spaces beween coordinates in coordinate triplets, an easy workaround is to remove all whitespace located immediately before or after commas inside a <coordinates> tag.* Several performance improvements that would allow smoother experience in specific computer configurations.* Fixed 'Restrict to View' functionality during a shapefile import in Google Earth Pro.* Fixed an issue where Google Earth would sometimes save incorrect ordering of elements in KML.* Added field of view recording to tours and ability to play back those changes.* Fixed an issue where the icon heading did not work in Google Earth API.* Changes to reduce occurrences of missing desktop icon and shortcut menu items on an update.* Sped up overlay polygon rendering in OpenGL mode.* Fixed loading of kmz files when the first file at the root level was image file.* Upgraded GDAL support to 1.7.0 and fixed issues with importing .tab files in Google Earth Pro.* Fixed the discrepancy caused in measurements due to multiple radii of Earth used inside Google Earth.* Fixed an issue where placemarks created with UTM coordinates did not move when edited.* Fixed an issue when screen overlays disappeared in a print-out.
K_tech Οκτώβριος 24, 2011 #1013 Οκτώβριος 24, 2011 CCleaner 3.12.1572- Added Firefox 8.0 Beta support.- Added Firefox 7.0 Final support.- Added secure delete for Cluster tips.- Added secure delete for Alternate Data Streams.- Added cleaning for Network Passwords.- Added PATH environment variable cleaning.- Added cleaning for Top Sites in Google Chrome.- Improved support for Chrome Canary.- Improved support for Firefox Aurora channel.- Added cleaning for AVG AntiVirus 2012, ACDSee 14, BitZipper and Avast! Antivirus 6.- Improved cleaning for VLC Media Player and Axialis IconWorkshop.- Added Marathi translation.- Minor bug fixes.
hayabusa Οκτώβριος 24, 2011 #1014 Οκτώβριος 24, 2011 Notepad++ 5.9.5Syntax Highlighting and Syntax FoldingWYSIWYGUser Defined Syntax HighlightingAuto-completionMulti-DocumentMulti-ViewRegular Expression Search/Replace supportedFull Drag 'N' Drop supportedDynamic position of ViewsFile Status Auto-detectionZoom in and zoom outMulti-Language environment supportedBookmarkBrace and Indent guideline HighlightingMacro recording and playback
hayabusa Οκτώβριος 25, 2011 #1016 Οκτώβριος 25, 2011 MySQL 5.5.17Partitioning to improve performance and management of very large database environmentsRow-based/Hybrid Replication for improved replication securityEvent Scheduler to create and schedule jobs that perform various database tasksXPath SupportDynamic General/Slow Query LogPerformance/Load Testing Utility (mysqlslap)Improved! Full Text Search (faster, new dev templates)Improved! Archive engine (better compression, more features)Improved! User session and problem SQL identificationImproved! MySQL embedded library (libmysqld)Additional INFORMATION_SCHEMA objectsFaster data import operations (parallel file load)ACID Transactions to build reliable and secure business critical applicationsStored Procedures to improve developer productivityTriggers to enforce complex business rules at the database levelViews to ensure sensitive information is not compromisedInformation Schema to provide easy access to metadataPluggable Storage Engine Architecture for maximum flexibilityArchive Storage Engine for historical and audit data
