vgiozo Σεπτέμβριος 19, 2005 #81 Κοινοποίηση Σεπτέμβριος 19, 2005 K-Lite Codec Pack 2.54 Full, Standard and Basichttp://www.free-codecs.com/K_Lite_Codec_Pack_download.htmFeatures of K-Lite Mega Codec Pack 1.38http://www.free-codecs.com/download/K_Lite_Mega_Codec_Pack.htmHaali Matroska Splitter 18.09.2005http://www.free-codecs.com/download/Haali_Matroska_Splitter.htm Link to comment Share on other sites More sharing options...
greekfragma Σεπτέμβριος 19, 2005 #82 Κοινοποίηση Σεπτέμβριος 19, 2005 http://grc.com/spinrite.htm ειναι a MUST-HAVE-APPLICATION . Link to comment Share on other sites More sharing options...
vgiozo Σεπτέμβριος 19, 2005 #83 Κοινοποίηση Σεπτέμβριος 19, 2005 Central Brain Identifier 7.6.0.3 Build 0918 R3http://www.benchmarkhq.ru/cgi-bin/dclick.cgi?32"New features include: another 10 newest single a dual core AMD Opteron EE and HE processors (revision E) detection, AMD Opteron series detection using the newest BrandId identification set, support for the latest AMD Athlon 64 processors (CPUID 30Fxxh), more accurate clock frequency and rate speed report for the VIA V-Link peripheral bus, a new flexible code to identify AMD Athlon FX processors and show Segment and TDP parameters for them, minor improvemetns, bugfixes" Link to comment Share on other sites More sharing options...
PGM Σεπτέμβριος 21, 2005 Author #84 Κοινοποίηση Σεπτέμβριος 21, 2005 DimadSoft has just released a new version of their popular DvdReMake and DvdReMake Pro software. DvdReMake is a tool which enables you to change content, appearance and navigation of a DVD without the need of re-authoring the DVD.Version 3.1.4 - 20 Sep 2005Version History:http://www.dimadsoft.com/dvdremake/history.phpDownload:http://www.dimadsoft.com/dvdremake/download.php Link to comment Share on other sites More sharing options...
PGM Σεπτέμβριος 21, 2005 Author #85 Κοινοποίηση Σεπτέμβριος 21, 2005 5.4.3.1, 2005 09 20 AnyDVD is a driver, which unprotects DVD-Movies automatically in the background. This DVD appears unprotected and region code free for all applications and the Windows operating system as well. With AnyDVD's help copy tools like CloneDVD, Pinnacle Instant Copy, InterVideo DVD-Copy, etc. are able to copy CSS protected Movies. With the help of AnyDVD you can watch movies with non matching region codes with every DVD Player Software you like!AnyDVD decrypts not just DVDs: AnyDVD allows you also to play, copy and rip protected Audio CDs! But AnyDVD does much more, of course. For example, it is possible to control the rotational speed of your DVD drive, so you can watch DVDs on your PC with far less noise! AnyDVD is the perfect Add-On for your HTPC (Home Theater PC). It can prevent the automatic launch of software from your Video DVDs (e.g., PC-Friendly) and you can start user defined programs on disc insertion and removal. AnyDVD can adjust your monitor's vertical refresh rate (e.g. 72 Hz with NTSC and 75 Hz with PAL) automatically if you wish! Download:http://www.slysoft.com/en/download.html Link to comment Share on other sites More sharing options...
vgiozo Σεπτέμβριος 21, 2005 #86 Κοινοποίηση Σεπτέμβριος 21, 2005 Acronis True Image 9.0http://www.acronis.com/homecomputing/products/trueimage/ Link to comment Share on other sites More sharing options...
spc Σεπτέμβριος 22, 2005 #87 Κοινοποίηση Σεπτέμβριος 22, 2005 nForce Drivers 6.67 WHQL nForce Driver 6.67 WHQL (64-bit) Link to comment Share on other sites More sharing options...
vgiozo Σεπτέμβριος 24, 2005 #88 Κοινοποίηση Σεπτέμβριος 24, 2005 Cetrnal Brain Identifier 7.604 finalhttp://cbid.amdclub.ru/files/cbid760.zip Link to comment Share on other sites More sharing options...
spc Σεπτέμβριος 26, 2005 #89 Κοινοποίηση Σεπτέμβριος 26, 2005 forceware 78.05 Link to comment Share on other sites More sharing options...
vgiozo Σεπτέμβριος 26, 2005 #90 Κοινοποίηση Σεπτέμβριος 26, 2005 DVDFab Decrypter 2.9.5.0http://www.softpedia.com/get/CD-DVD-Tools/CD-DVD-Rip-Other-Tools/DVDFab-Decrypter.shtml Link to comment Share on other sites More sharing options...
vgiozo Σεπτέμβριος 28, 2005 #91 Κοινοποίηση Σεπτέμβριος 28, 2005 Office 2003 sp2http://office.microsoft.com/en-us/default.aspxOffice 2003 Proofing tools SP2http://www.microsoft.com/downloads/details.aspx?FamilyId=63336EF2-7D76-4A8D-921F-C6F6E7152B97&displaylang=en Link to comment Share on other sites More sharing options...
vgiozo Σεπτέμβριος 29, 2005 #92 Κοινοποίηση Σεπτέμβριος 29, 2005 Νέα έκδοση Skype 1.4.0.71http://www.insomnia.gr/files/pafiledb.php?action=file&id=132Ειδα στις επιλογές ότι υποστηρίζει και προώθηση κλήσης...δεν ξέρω αν είναι καινούριο χαρακτηριστικό, αλλά είναι πολύ χρήσιμο... Link to comment Share on other sites More sharing options...
vgiozo Οκτώβριος 2, 2005 #93 Κοινοποίηση Οκτώβριος 2, 2005 Νέα σταθερή έκδοση Auto Gordian knot 2.20http://www.autogk.me.uk/index.php?name=Downloads&d_op=viewdownload&cid=1 Link to comment Share on other sites More sharing options...
mariosalice Οκτώβριος 3, 2005 #94 Κοινοποίηση Οκτώβριος 3, 2005 Forceware 81.82. Link to comment Share on other sites More sharing options...
helloween Οκτώβριος 3, 2005 #95 Κοινοποίηση Οκτώβριος 3, 2005 WinZip 10.0 Beta Build 6604 http://www.softpedia.com/progDownload/WinZip--beta-Download-4819.html Link to comment Share on other sites More sharing options...
helloween Οκτώβριος 3, 2005 #96 Κοινοποίηση Οκτώβριος 3, 2005 Internet Explorer 7.0 beta http://www.softpedia.com/get/Internet/Browsers/Internet-Explorer-7.shtml Link to comment Share on other sites More sharing options...
helloween Οκτώβριος 3, 2005 #97 Κοινοποίηση Οκτώβριος 3, 2005 Game XP 1.5.10.1 http://www.softpedia.com/get/Tweak/System-Tweak/Game-XP.shtml Link to comment Share on other sites More sharing options...
spc Οκτώβριος 5, 2005 #98 Κοινοποίηση Οκτώβριος 5, 2005 σε παγκόσμια αποκλειστικότητα ( ) οι νέοι ForceWare 81.84 Link to comment Share on other sites More sharing options...
RootX Οκτώβριος 5, 2005 #99 Κοινοποίηση Οκτώβριος 5, 2005 Damn, καλά,. όλη μέρα στον ftp της nvidia σερφάρεις? Thanx Link to comment Share on other sites More sharing options...
spc Οκτώβριος 5, 2005 #100 Κοινοποίηση Οκτώβριος 5, 2005 Αρχική απάντηση από RootX Damn, καλά,. όλη μέρα στον ftp της nvidia σερφάρεις? Thanx me guilty (δεν βλέπω τους 6.67 ακόμα όμως και ανησυχώ ) Ρε κάθαρμα, δεν φτάνει που εξασφάλισα αποκλειστικότητα, θα μου την πεις και από πάνω; Link to comment Share on other sites More sharing options...
