Καινούργιες εκδόσεις (Haya)
PGM
  • Replies 2,4k
Chrome 14.0.803.0
All
- Updated V8 - 3.4.6.2
- Change the meaning of third-party cookie blocking to allow whitelists
Mac
- Relaunches do not work in this release. You will need to manually relaunch Chrome following a forced update, an about:flags change, or any other action that attempts to relaunch the browser.
Linux
- Remove the Global Bookmarks menu by default on Ubuntu Natty, in an attempt to fix minute long startup regression on desktop environments that use dbusmenu. (Issue 86715)
Opera 11.50
This version allows the use of Speed Dial extensions (web apps that boost functionality) and brings password synchronization support through Opera Link.
Opera 11.50 also features some design tweaks that make the interface more streamlined and lightweight, and includes upgraded rendering and software graphics engines so as to deliver even higher speeds.
Thunderbird 5.0
- a new Add-ons Manager
- a revised account creation wizard to improve email setup
- a new Troubleshooting Information page
- Tabs can now be reordered and dragged to different windows
- Attachment sizes now displayed along with attachments
- Plugins can now be loaded in RSS feeds by default
- several theme fixes for Windows Vista and Windows 7
- support for Mac 32/64 bit Universal builds (Thunderbird no longer supports PowerPC on Mac)
CCleaner 3.08.1475
v3.08.1475 (27 Jun 2011)
- Added support for Firefox 5.0.
- Improve Firefox History cleaning.
- Improved cleaning for Windows Error Reporting and Other Explorer MRUs.
- Added cleaning for Ditto, Evernote, I2P, McAfee AntiVirus,
MS AntiMalware, PerfectDisk, PowerISO, UltraISO, GIMP,
Go!Zilla, MagicISO.
- Improved cleaning for 7-Zip, Daemon Tools, Windows Defender.
- Improved DOMStore cookie domain discovery and cleaning.
- Improved Uninstall tool scanning and uninstalling routines.
- Improved Registry Cleaner detection algorithm.
- Improved Start Up tool detection algorithm.
- Added multiple monitor support.
- Improved shortcut key accelerators.
- Improved search response when using wild cards.
- Added support for root registry keys in the exclude list.
- Added Kazakh language.
- Minor GUI improvements and fixes.
Firefox 6.0 beta
- The address bar now highlights the domain of the website you're visiting
- Streamlined the look of the site identity block
- Added support for the latest draft version of WebSockets with a prefixed API
- Added support for EventSource / server-sent events
- Added support for window.matchMedia
- Added Scratchpad, an interactive JavaScript prototyping environment
- Added a new Web Developer menu item and moved development-related items into it
- Improved usability of the Web Console
- Improved the discoverability of Firefox Sync
- Reduced browser startup time when using Panorama
Flash Player 11 beta
- 64bit support, Stage3D, 7.1ch surround
- Asynchronous bitmap decoding (for decoding images on initial load instead of on demand for improved app responsiveness)
- H.264/AVC software encoding for cameras
- 7.1 channel surround sound
- G.711 audio compression for telephony
- support for TLS Secure Sockets
- support for the JPEG-XR advanced image compression standard
- Protected HTTP Dynamic Streaming (HDS) and extra content protection features
- secure random number generator
2011-07-12 PuTTY 0.61 is released
These features are new in beta 0.61 (released 2011-07-12):
  • Kerberos/GSSAPI authentication in SSH-2.
  • Local X11 authorisation support on Windows. (Unix already had it, of course.)
  • Support for non-fixed-width fonts on Windows.
  • GTK 2 support on Unix.
  • Specifying the logical host name independently of the physical network address to connect to.
  • Crypto and flow control optimisations.
  • Support for the zlib@openssh.com SSH-2 compression method.
  • Support for new Windows 7 UI features: Aero resizing and jump lists.
  • Support for OpenSSH AES-encrypted private key files in PuTTYgen.
  • Bug fix: handles OpenSSH private keys with primes in either order.
  • Bug fix: corruption of port forwarding is fixed (we think).
  • Bug fix: various crashes and hangs when exiting on failure,
  • Bug fix: hang in the serial back end on Windows.
  • Bug fix: Windows clipboard is now read asynchronously, in case of deadlock due to the clipboard owner being at the far end of the same PuTTY's network connection (either via X forwarding or via tunnelled rdesktop).
Official Site
VLC 1.1.11
Mac OS X
- Fixed scrolling direction if the input device's signal is inverted
- Update Auhal audio output to the latest API
- Fix images disappearing issue on the interface
- Reduced installation size by up to 30 MB
- Resolved conflict between iTunes and VLC wrt Media Key handling
Mozilla/ActiveX webplugin
- Fullscreen mode is fixed on Win32
- Very simple fullscreen controller is visible on Win32
Demuxers/Meta Readers
- Better support for cover art embedded in mp4, wma
Muxers/Output
- Fix AVI muxer so the generated files are readable on other players
Extensions
- Multiple fixes for crashes and malfunctionning issues
Qt Interface
- Fix quitting on Linux
- Fix opening of VIDEO_TS folders through the open disc dialog on Windows
- Miscellaneous
Win32 port
- Update of codecs, fixing the mpeg-2 decoder crash
Translations
- Update of Slovak, Lithunanian, Russian, Brazillian Portuguese, Serbian
CCleaner v3.09.1493
v3.09.1493 (26 Jul 2011)
- Added Firefox 6.0 beta support.
- Added HTML5 Offline cache cleaning and management for Firefox.
- Added wildcard support to folders.
(i.e. "Include1=PATH|%AppData%\*\|*.txt|RECURSE"
or FileKey1=%AppData%\?*e|*.txt|RECURSE)
- Added convertion of custom file entry to folder when using wildcard.
- Added cleaning for Zune, BreezeBrowser Pro, FastStone Image Viewer, Notepad++ and NoteXpad.
- Improved cleaning for Real Player.
- Improved Chrome Saved Form Information and Saved Passwords cleaning.
- Improved Enabling/Disabling StartUp items.
- Improved icons detection for Uninstall screen.
- Improved drag-and-drop functionality for Include/Exclude screen.
- Improved localization support.
- Improved StartUp items discovery.
- Improved memory handling and garbage collection.
- Minor UI tweaks.
Δεν άργησε και πολύ τελικά :D
Thunderbird 6.0
This new Tbird release is based on the Gecko 6 engine (same on used for Firefox 6) and promises to be faster, more stable and more secure than its predecessors.
- Several theme improvements for Windows 7
- Support for Windows 7 Jump lists
- Several fixes when importing email from Microsoft Outlook
- Default mail client check now works with newer Linux distributions
- Various other user interface fixes and improvements
