nickstamat Ιούνιος 23, 2010 #761 Ιούνιος 23, 2010 Creative Console Launcher (BETA) v.2.61.48Released: 23/06/2010Size: 43.71 MBFile name: CSL_PCAPPBETA_US_2_61_48.exe DownloadTHIS IS AN UNSUPPORTED BETA APPLICATION. There is no technical support for this application.We recommend that only experienced users install this application. Do not install this application on a system used to perform critical tasks.Users who are looking for stable applications should wait for the final release. When this happens, user should install the latest Creative Console Launcher application available.This download supports the following audio devices only:Sound Blaster® X-Fi XtremeGamer Fatal1ty® Professional SeriesSound Blaster X-Fi Platinum Fatal1ty Champion SeriesSound Blaster X-Fi XtremeMusicSound Blaster X-Fi XtremeGamerSound Blaster X-Fi PlatinumSound Blaster X-Fi Fatal1tySound Blaster X-Fi Elite Pro Sound Blaster X-FiPCI Express Sound Blaster X-Fi Xtreme AudioSound Blaster X-Fi Xtreme AudioExpressCard Sound Blaster X-Fi Xtreme Audio NotebookSound Blaster X-Fi Titanium Fatal1ty Champion SeriesSound Blaster X-Fi Titanium Fatal1ty Professional SeriesSound Blaster X-Fi Titanium Professional AudioSound Blaster X-Fi TitaniumFixed issues:For Sound Blaster X-Fi Titanium series only:Resolves slow shutdown issues when Dolby® Digital Live and/or DTS Connect™ is enabled.Requirements:Microsoft Windows 7 64-bit, Windows 7 32-bit, Windows Vista 64-bit with Service Pack 1 (SP1), Windows Vista 32-bit with SP1, Windows XP Professional x64 Edition, Windows XP Service Pack 3 (SP3), Windows XP Media Center Edition (MCE) 2005 or Windows XP MCE 2004Creative audio devices listed above
MOS Ιούνιος 27, 2010 #763 Ιούνιος 27, 2010 Firefox 3.6.4Download Firefox 3.6.4Release NotesFirefox 3.6.6
hayabusa Ιούλιος 1, 2010 #764 Ιούλιος 1, 2010 Opera 10.60 - Geolocation services provided by Google Location Services (GLS) - Support for Offline Web Applications - Web Workers - WebM support - Bing added as an option for the integrated search box - Search suggestions - Appcache: Use in-browser applications such as word processors and spreadsheets even without an Internet connection by storing the necessary files locally.
hayabusa Ιούλιος 3, 2010 #765 Ιούλιος 3, 2010 Chrome 5.0.375.99 - [42396] Low OOB read with WebGL. - [42575] [42980] Medium Isolate sandboxed iframes more strongly. - [43488] High Memory corruption with invalid SVGs. - [44424] High Memory corruption in bidi algorithm. - [45164] Low Crash with invalid image. - [45983] High Memory corruption with invalid PNG (libpng bug). - [46360] High Memory corruption in CSS style rendering. - [46575] Low Annoyance with print dialogs. - [47056] Low Crash with modal dialogs.As for Chrome 6.0.453.1, it can be found here and it includes... Windows - Consolidated menu is on by default - [r50830] Show preview images when dragging images. - Printing from the built-in PDF plugin now prints vectors instead of pixels. - [r50617] Fix avutil-50.dll entry point not found error by limiting the DLL search path when loading FFmpeg binaries Mac - Continued feature parity work Linux - New experimental support for gnome-keyring and kwallet for storing your passwords. Currently off by default; you can opt in via a command line flag and we’d love feedback as to whether it eats your data. - Fixed overlapping characters sometimes seen with complex (Thai, Indic) text. - The PDF plugin is now available (turn it on in about:plugins).
dj_chris_g Ιούλιος 3, 2010 #766 Ιούλιος 3, 2010 Virtual Dj v6.1http://www.virtualdj.com/products/virtualdj/version6.htmlTractor Pro v1.2http://www.native-instruments.com/#/en/products/dj/traktor-pro/Έχουν βγεί εδώ και κάμποσο καιρό, αλλά το ποστάρω για να ενημερώνουμε και για τα συγκεκριμένα πρόγραμματα...
hayabusa Ιούλιος 6, 2010 #767 Ιούλιος 6, 2010 PeaZip version 3.2.1Full support: 7Z, 7Z-sfx, ARC/WRC, BZ2/TBZ2, Custom (user defined), GZ/TGZ, PAQ/LPAQ, PEA, QUAD/BALZ, split, TAR, UPX, ZIP. Open, browse, extract, test: ACE, ARJ, CAB, CHM, COMPOUND (MSI, DOC, XLS, PPT), CPIO, ISO, Java (JAR, EAR, WAR), Linux (DEB, PET/PUP, RPM, SLP), LHA/LZH, LZMA, Mac (DMG/HFS), NSIS, Open Office files, PAK/PK3/PK4, RAR, SMZIP, U3P, UDF, WIM, XAR, XPI, Z/TZ (79 file extension supported).Changes include:- (Windows) 7z 9.15 beta- Fixed browsing some types of split compressed files, i.e. .bz.001- Fixed preserving/removing original file extension in archive name accordingly to archive type- Added optional theming image for file manager's toolbar- Fixed the installer now removes older versions' language files during the installation- (Linux) Nautilus script files are now marked as executable, as required in some distributions- (Qt version) The installer now tries to link libqt4intf.so in some more paths used by some distributions.
hayabusa Ιούλιος 7, 2010 #768 Ιούλιος 7, 2010 Firefox 4 Beta 1- Significant API improvements are available for JS-ctypes, a foreign function interface for extensions. - The stop and reload buttons have been merged into a single button on Windows, Mac and Linux. - The Bookmarks Toolbar has been replaced with a Bookmarks Button by default (you can switch it back if you'd like). - Crash protection for Windows, Linux, and Mac when there is a crash in the Adobe Flash, Apple Quicktime or Microsoft Silverlight plugins. - CSS Transitions are partially supported. - Full WebGL support is included but disabled by default at this time. - Core Animation rendering model for plugins on Mac OS X. Plugins which also support this rendering model can now draw faster and more efficiently. - An experimental Direct2D rendering backend is available on Windows, turned off by default. - Web developers can use Websockets for a low complexity, low latency, bidirectional communications API. - Web developers can update the URL field without reloading the page using HTML History APIs. - More responsive page rendering using lazy frame construction. - Link history lookup is done asynchronously to provide better responsiveness during pageload. - CSS :visited selectors have been changed to block websites from being able to check a user's browsing history. - New HTML5 parser. - Support for more HTML5 form controls.
hayabusa Ιούλιος 7, 2010 #769 Ιούλιος 7, 2010 Notepad++ version 5.7supports the following languages: C, C++ , Java , C#, XML, HTML, PHP, javascript , RC resource file, makefile, ASCII art file, doxygen, ini file, batch file, ASP , VB/VBS source files , SQL , Objective-C , CSS, Pascal, Perl, Python and Lua.Changes include:- Upgrade Scintilla to version 2.12.- Add "Inverse bookmark" feature.- Add NPPM_SAVECURRENTFILEAS message.- Fix premature deallocation bug for import UDL.- Add import/export User Defined Language features.- File detection : Switch to modified or deleted file while user is asked to reload or keep the file.- Fix closing several detected non-existing files bug.- Fix language switching to English not working bug.- Reduce PostIt/FullScreen restore button size.- Fix PostIt wrong restore button position after toggling off fullScreen mode.- Fix crashes on new 11 character long UDL names bug.- Fix "Save all" inconsistent icon state on toolbar.- Add new keywords of HTML 5 and css.
hayabusa Ιούλιος 7, 2010 #770 Ιούλιος 7, 2010 Miranda IM 0.8.27- ICQ: Fixed status when AIM support enabled- MSN: Updated WLM 10 detection- MSN: Fix infinite loop- Yahoo: Fix empty “Nick” issues- Yahoo: Fixed client version detection- Yahoo: Fix issues with Yahoo! Japan
hayabusa Ιούλιος 7, 2010 #771 Ιούλιος 7, 2010 γκουχ γκουχ --> http://www.thelab.gr/showpost.php?p=1062850597&postcount=606
hayabusa Ιούλιος 8, 2010 #772 Ιούλιος 8, 2010 WHS Add-in Download Manager 3.2.4Updates include:- Support for Hi-Drive and sharingmatrix.com- New settings properties- It is now possible to monitor your Download Folder for new DLC Containers.- You have the option to activate/deactivate the monitoring and set a Standard Pool-Time for the DLC Files.- Schedule your complete downloads to a defined download time- Rapidshare Free Download – Resolved some bugs from version 3.2.3- Save.tv – Function changes for the Save.tv Relaunch. Works only with the Basic Account, XL Account follows in the next version.
HotPeanut Ιούλιος 8, 2010 #773 Ιούλιος 8, 2010 CCleaner v2.33.1184- Added support for Flock 3.0.- Improved database compacting to only run when needed.- Improved Index.dat files cleaning for IE8 to include IECompatCache, IETldCache, PrivacIE folders.- Improved accuracy of cleaning status messages.- Improved localization and language support.- Improved UI text formatting for Cleaner screen.- Fixed Startup Tool double-clicking behavior on Win9x.- Minor improvements to Registry Cleaner on Windows 7.- Added Kurdish translation.
hayabusa Ιούλιος 9, 2010 #774 Ιούλιος 9, 2010 Chrome 6.0.458.1 All - InfoBar should not be shown when the user first submits a form. - AutoFill should continuously update profile data as the user submits forms with new data AutoFill: Aggregate profile data. Remove the AutoFill InfoBar. Remove more remnants of shipping address and CVV. - When editing a field in a previously auto-filled form, only display unique suggestions AutoFill: Remove duplicate suggestions when providing suggestions for a field. - Enabling sync freezes Chromium Remove NIGORI from the sync routing info. Windows - Chrome unable to start if other FFmpeg DLLs are present on the system.
dmarccos Ιούλιος 16, 2010 #775 Ιούλιος 16, 2010 Recuva v1.38.504- Added ability to restore images to the clipboard.- Improved Windows 7 support.- Improved stability of background checking.- Updated all internal URL references to piriform.com.- Improved support for PDFs in deep scan.- Updated setup routine to install for all users.- Updated and simplified the installer.
hayabusa Ιούλιος 20, 2010 #776 Ιούλιος 20, 2010 iTunes 9.2.1 - Addresses minor issues with dragging and dropping items - Addresses a performance issue when first syncing to some devices with iTunes 9.2 - Addresses an issue upgrading to iOS 4 on an iPhone or iPod touch with encrypted back-ups
pcfreak111 Ιούλιος 21, 2010 #777 Ιούλιος 21, 2010 Cpu-z 1.55- VIA VX900/VX900M and VN1000/VN1000M chipsets.- Intel Core i5-760, Core i7-875K and Core i5-655K processors.- Intel Core i7-940XM, 840QM, 740QM mobile processors.- Intel Core i5-450M, 540UM, 430UM, Core i3-370M mobile processors.- Intel Pentium P6000 processor.- New parameter in cpuz.ini : UseDisplayAPI
hayabusa Ιούλιος 21, 2010 #779 Ιούλιος 21, 2010 VLC 1.1.1 - New capabilities for libVLC - Various fixes and crash preventions, especially when video functions were called early Decoders/Demuxers - Fix performance issues with GPU decoding using DxVA2 using ATI graphic cards (Catalyst 10.7 is required) - Fix :program selection in TS and DVB-T - Fixes and improvements for MKV, Avformat and Avcodec modules - Fix mod (.xm, .s3m, .it) files support on Windows and Mac builds Stream output - Fix h264 streaming in ts Interfaces - Qt: fix preferences, hotkeys, messages and some fulscreen behavior - Skins: support for mousewheel in fullscreen, fix radialsliders - Http: fix fullscreen toggle Linux - Fix pulse closing - VAAPI small improvements, notably for extraction mode selection Mac OS - Multiple interface and crash fixes - Deinterlace selection is repaired - Crashes when playing multi-channel tracks fixes Windows - Activation of DEP on XP SP3 - Fix opening of .m3u and .pls playlists - Fix crash when My Document isn't available - Fix crash when Windows was getting into standby while playing video Translations - Update translations for Spanish, Polish, German, Sinhala, Hungarian, Khmer, Brazilian Portuguese, Chinese, Hebrew, Slovak and Galician
hayabusa Ιούλιος 23, 2010 #780 Ιούλιος 23, 2010 Chrome 6.0.472.0 All - Chromium stops saving files for any large downloads (Issue 49216) - Fix crash with SSL client auth (Issue 49197) - Option clicking a link now saves a resource directly without triggering a “Save As...” dialog (Issue 36775) Mac - Implement the upgrade available notification on the Wrench menu (Issue 45147) - Implement the new, unified Wrench menu (Issue 47848) Linux - Fixed tab dragging glitches with newer GDEs (Issue 48774) - Access GNOME Keyring on the main thread to fix a crash for some users (Issue 48343)
