hayabusa Ιούνιος 1, 2010 #741 Κοινοποίηση Ιούνιος 1, 2010 Media Browser version 2.2.4.0- The Media type is now retrieved from locally stored metadata.- Better support for using MyMovies and Media Browser side-by-side. The user can now set the preferred order of local artwork.- Watched status indicators are working normally again.- It is now possible to Clear the Cache from the Media Browser Configuration Wizard.- Various sort-order bugs for Media Collections have been fixed.- Lots of other bugs have been fixed.- You can use SQLite and share playstate settings & display settings.- Better rotating backdrop support. It is now possible to randomize the order in which they appear.- Using the custom entrypoints no longer results in a full library refresh.- Improved installer interface that can create optional shortcuts to Media Browser.- Overall performance increase due to various changes to the cache mechanism.- Last but not least, Media Browser can now be localized by theme developers and the community. Link to comment Share on other sites More sharing options...
hayabusa Ιούνιος 1, 2010 #742 Κοινοποίηση Ιούνιος 1, 2010 DiskDigger version 1.0- Added support for .WPD (WordPerfect) file format.- Improved error handling and saving of large files.- Improved detection of disk drives. Added logical disk drives for scanning.- Added ability to select a disk image file for scanning.- Added functionality to actually undelete files from FAT and NTFS file systems.- Updated manifest file to automatically ask for admin privileges.- Added support for Rich Text Format (RTF).- Added progress indicator when saving multiple files. Link to comment Share on other sites More sharing options...
hayabusa Ιούνιος 4, 2010 #743 Κοινοποίηση Ιούνιος 4, 2010 Chrome 6.0.422.0 All - Crash when changing networks or waking from sleep (Issue: 44724) Mac - Fix a crash when downloading a file with no tabs open (Issue: 44454) - Fix idle renderer CPU usage regression. (Issue: 44494) - Add a preference for the tab key cycling between just form fields, or links as well. (Issue: 31177) - Download shelf now slides out instead of collapsing Linux - CUPS “add printer” crashes tab (Issue 30880) Link to comment Share on other sites More sharing options...
poly Ιούνιος 8, 2010 #744 Κοινοποίηση Ιούνιος 8, 2010 DirectX End-User Runtimes (June 2010) Link to comment Share on other sites More sharing options...
vgiozo Ιούνιος 9, 2010 #745 Κοινοποίηση Ιούνιος 9, 2010 Kaspersky Internet Security (& Antivirius) 2011 v.11.0.0.232http://www.kaspersky.com/kis_latest_versions Link to comment Share on other sites More sharing options...
MOS Ιούνιος 10, 2010 #746 Κοινοποίηση Ιούνιος 10, 2010 Chrome 6.0.427.0 All - No preview is seen in empty form fields when Autofill profile is in focus. (Issue 38582) Linux - Huge alert box crashes Chrome Truncate very long javascript alert messages. (Issue 45002) - Backtrace when dragging lock icon to page GTK: fix site type icon dragging. (Issue 45270) Chrome Frame - Fixed sad-tab showing briefly during switch to Chrome Frame. Sometimes, navigating to a page in Chrome Frame within IE would display the sad tab page briefly until the navigation was initiated from IE. Link to comment Share on other sites More sharing options...
MOS Ιούνιος 10, 2010 #747 Κοινοποίηση Ιούνιος 10, 2010 Thunderbird 3.1 RC2- New Migration Assistant giving Thunderbird 2 users a way to choose the new features in Thunderbird 3.1 or to keep their current features and settings. - a Saved Files Manager that displays all the files you downloaded from your email to your computer. - a Mail Account Setup Wizard - Faster Search Results - a Quick Filter Toolbar that lets you filter against search terms, tags, starred messages, address book contacts, new emails, and attachments. - better password handling Link to comment Share on other sites More sharing options...
MOS Ιούνιος 10, 2010 #748 Κοινοποίηση Ιούνιος 10, 2010 Opera 10.60 WindowsOpera 10.60 MacOpera 10.60 LinuxDesktop/UI - Fixed DSK-297848 (Widgets with non-default start file will not install on Win/Nix and crash on startup on Mac) - Fixed DSK-300727 (Not possible to select items in dropdown menus using the mouse) - Fixed DSK-298554 (Unite apps not shown in panel after installation) - Fixed DSK-298488 (Opera crashes when hiding and showing bookmarks in the addressbar dropdown) - Fixed DSK-290305 (Launching previous session with two separate Opera windows causes a crash) - Fixed DSK-299048 (Mail messages not staying in focus) - Fixed DSK-298552 (Freeze on receiving mail) - Fixed DSK-265678 (Crash when dragging buttons to status bar) - Fixed DSK-274447 (Cycling tabs "without list" and "alternative page cycle mode = 0" adds focus to all cycled tabs) - Fixed DSK-295921 (Widgets are upgraded to default path only) - Fixed DSK-277917 (Advanced menu in download tab doesn't appear for files downloaded to non-ASCII folder) - Fixed DSK-289391 (Autoupdate does not close Opera when set to hide to system tray) - Fixed DSK-257454 (Impossible to change or install dictionary in dialog boxes) - Fixed DSK-180617 (Links opened in external applications close page if page is opened from a panel or mail) - Fixed DSK-287319 (Unable to accept self-signed certificate) - Fixed DSK-283179 (Find in page overlay does not disappear when clicking iframe) - Fixed DSK-280759 (Deleting private data does not remove closed windows) - Fixed DSK-299348 (Ghost close button appears when clicking top of trash button in Windows 7) - Fixed DSK-291817 (Opera does not prefetch icons for bookmarks from the custom/ folder) - Fixed DSK-299530 (Percent sign in encoded url from external application is encoded by Opera again) - Fixed DSK-298142 (Buttons often disabled in new non-modal dialogs) - Fixed DSK-288727 (Many user selected locales don't get a language even if possible) Core - Fixed a couple of DOM regressions (Facebook chat) - Fixed CORE-28120 (xhr.overrideMimeType() called before xhr.open throws) - Fixed CORE-30272 (Freeze on Youtube inbox, colspan and border with border-collapse:collapse) - Fixed CORE-30097 (Width of shrink-to-fit float with fixed-width parent and STF float grandparent not updated when content is added (Gmail)) - Fixed DSK-286851 (Can't type in windowless Flash) Mac - Fixed DSK-299467 ("Open with..." context menu passes incorrect URLs to other browsers) - Fixed DSK-297579 (Opera is activated, but Space does not change when opening link) - Fixed DSK-299028 (Crash when pressing some keyboard shortcuts in the start-up dialog) - Fixed DSK-295263 (Quick-preferences shortcut incorrectly requires you to hold Command) - Fixed DSK-298456 (Cannot customize the appearance of toolbars on Mac) Link to comment Share on other sites More sharing options...
hayabusa Ιούνιος 10, 2010 #749 Κοινοποίηση Ιούνιος 10, 2010 Thunderbird 3.1 RC 2 - New Migration Assistant giving Thunderbird 2 users a way to choose the new features in Thunderbird 3.1 or to keep their current features and settings. - a Saved Files Manager that displays all the files you downloaded from your email to your computer. - a Mail Account Setup Wizard - Faster Search Results - a Quick Filter Toolbar that lets you filter against search terms, tags, starred messages, address book contacts, new emails, and attachments. - better password handling Link to comment Share on other sites More sharing options...
hayabusa Ιούνιος 10, 2010 #750 Κοινοποίηση Ιούνιος 10, 2010 Safari 5Safari 5 comes with a 'Reader' feature which will remove ads and other possible distractions from online articles so that users can focus on the story, and also boasts Domain Name System (DNS) prefetching and more HTML5 candy like Geolocation, sectioning elements, draggable attribute, forms validation, Ruby, AJAX History, EventSource and WebSocket. Moreover, Safari 5 has support for Extensions - add-ons which are expected to be made available as of this summer via a Gallery, and brings Tabs settings, hardware acceleration for Windows and an improved Web Inspector. Link to comment Share on other sites More sharing options...
hayabusa Ιούνιος 11, 2010 #751 Κοινοποίηση Ιούνιος 11, 2010 Adobe Flash Player 10.1 final Link to comment Share on other sites More sharing options...
Havic Ιούνιος 11, 2010 #752 Κοινοποίηση Ιούνιος 11, 2010 Opera 10.60 Windows Μήπως είναι beta? γιατί εδώ λέει Opera 10.60 available shortly και έχει να κατεβάσεις την 10.10 για linux. Link to comment Share on other sites More sharing options...
hayabusa Ιούνιος 11, 2010 #753 Κοινοποίηση Ιούνιος 11, 2010 ναι, αν δεν κάνω λάθος ειναι η Alpha 1 έκδοση Link to comment Share on other sites More sharing options...
jpavly Ιούνιος 15, 2010 #754 Κοινοποίηση Ιούνιος 15, 2010 Ένας πραγματικά πολύ δυνατός παίκτης στο χώρο των image viewers με βασικές δυνατότητες τροποποίησης που είναι πραγματικός Ελβετικός σουγιάς! Διαθέτει εντυπωσιακό interface και έρχεται με πολλές ευκολίες και ενδιαφέρουσες λειτουργίες για τον καθημερινό χρήστη.Κατά την εγκατάστασή του, μπορείτε να επιλέξετε ποιους τύπους εικόνας θα ανοίγει απ’ ευθείας με διπλό κλικ. Εκτός από την λειτουργία του ως viewer, διαθέτει βασικές λειτουργίες επεξεργασίας φωτογραφίας, όπως αποκοπή (crop), διόρθωση red-eye, χρωματισμούς, οπτική βελτίωση, clone stamp, διορθώσεις ιστογράμματος και πολλά άλλα ενδιαφέροντα. Επίσης, κάνοντας δεξί κλικ σε μία εικόνα από τον Explorer, μπορείτε να την ανοίξετε απ’ ευθείας με τον Editor.Άλλες ενδιαφέρουσες λειτουργίες: μπορείτε να δημιουργήσετε δικά σας εφέ, puzzles, ενοποίηση εικόνων πανοράματος, δημιουργία ημερολογίων.Μόλις τελειώσετε με τη δημιουργία σας, με 2 κλικ ανεβάζετε τη φωτογραφία σας στο Facebook σας ή στο Flickr!http://free.zoner.com/download.asp Link to comment Share on other sites More sharing options...
nickstamat Ιούνιος 15, 2010 #755 Κοινοποίηση Ιούνιος 15, 2010 Creative Sound Blaster X-Fi Series Driver v.2.18.0015Released: 15/06/2010Size: 46.74 MBFile name: SBXF_PCDRV_LB_2_18_0015.exeDownloadThis download supports the following audio devices only:Sound Blaster X-Fi XtremeGamer Fatal1ty® Professional SeriesSound Blaster X-Fi Platinum Fatal1ty Champion SeriesSound Blaster X-Fi XtremeMusicSound Blaster X-Fi XtremeGamerSound Blaster X-Fi PlatinumSound Blaster X-Fi Fatal1tySound Blaster X-Fi Elite Pro Sound Blaster X-FiFixed issues:System taking more than two minutes to shut down.PowerDVD® DX 8.3 (Dell® version) not working properly.Passthrough of Dolby®/DTS® audio to an external decoder not working with Windows Media Player 12.Requirements:Microsoft Windows 7 64-bit or Windows 7 32-bit onlySound Blaster X-Fi audio devices listed above Link to comment Share on other sites More sharing options...
hayabusa Ιούνιος 15, 2010 #756 Κοινοποίηση Ιούνιος 15, 2010 @ jpavly: ενδιαφέρον φαίνεται, θα το κοιτάξω οπωσδήποτε κάποια στιγμή. Link to comment Share on other sites More sharing options...
MOS Ιούνιος 15, 2010 #757 Κοινοποίηση Ιούνιος 15, 2010 Fraps 3.2.3- Added support for full-size video capture above 2560x1600- Fixed crash when loading Fraps under WinXP with 6-core CPU- Fixed crash when enabling monitor DWM option on some configurations- Fixed Fraps altering error flag on calls to GL SwapBuffers- Fixed sound input switching at startup on XP systems- Fixed counter appearing in VS2010 Link to comment Share on other sites More sharing options...
hayabusa Ιούνιος 15, 2010 #758 Κοινοποίηση Ιούνιος 15, 2010 PlayClaw 1.9 Link to comment Share on other sites More sharing options...
hayabusa Ιούνιος 17, 2010 #759 Κοινοποίηση Ιούνιος 17, 2010 iTunes v9.2iTunes 9.2 enables iPhone 4 syncing, adds support for iOS 4 and iBooks 1.1 and also includes the following: - Organize and sync PDF documents as books. Read PDFs with iBooks 1.1 on iPad and any iPhone or iPod touch with iOS 4 - Organize your apps on your iOS 4 home screens into folders using iTunes - Faster back-ups while syncing an iPhone or iPod touch with iOS 4 - Album artwork improvements make artwork appear more quickly when exploring your library - Multiple security fixes (detailed here ) Link to comment Share on other sites More sharing options...
hayabusa Ιούνιος 22, 2010 #760 Κοινοποίηση Ιούνιος 22, 2010 VLC media player v1.1.0 - GPU decoding on Windows Vista and 7, using DxVA2 for H.264, VC-1 and MPEG-2 - GPU decoding on GNU/Linux, using VAAPI for H.264, VC-1 and MPEG-2 - DSP decoding using OpenMax IL, for compatible embedded devices - Improved support for MKV HD, including seeking fixes, and 7.1 channels codecs - Support for new codecs, like Blu-Ray subtitles, MPEG-4 lossless, VP8 and WebM - Improved web plugins - Integrated playlist in the Qt4 interface - New add-ons and script framework so one can personalize its vlc. - Multiple views (like album art) in the playlist in the Qt4 interface - Improved meta-data and album-art support - Simplified and improved libVLC, removal of exceptions for better C integration - and more... Link to comment Share on other sites More sharing options...
