Καινούργιες εκδόσεις (Haya)
PGM
  • Replies 2,4k
doPDF converter free version 7.1.366
Changes include:
- New: Add Hebrew language to user interface
- Update: Optimized PDF file size for documents with Asian characters
- Fix: Corrected selection on edit fields on Paper page (when pressing TAB the selection didn't switch correctly
- Fix: Compatible with Windows 2000 now (didn't work before)
Link to comment
Share on other sites
VirtualBox 3.2.0.61806
# The following items were fixed and/or added:
* Following the acquisition of Sun Microsystems by Oracle Corporation, the product is now called Oracle VM VirtualBox and all references were changed without impacting compatibility
* Experimental support for Mac OS X guests (see the manual for more information)
* Memory ballooning to dynamically in- or decrease the amount of RAM used by a VM (64-bit hosts only) (see the manual for more information)
* Page Fusion automatically de-duplicates RAM when running similar VMs thereby increasing capacity. Currently supported for Windows guests on 64-bit hosts (see the manual for more information)
* CPU hot-plugging for Linux (hot-add and hot-remove) and certain Windows guests (hot-add only) (see the manual for more information)
* New Hypervisor features: with both VT-x/AMD-V on 64-bit hosts, using large pages can improve performance (see the manual for more information); also, on VT-x, unrestricted guest execution is now supported (if nested paging is enabled with VT-x, real mode and protected mode without paging code runs faster, which mainly speeds up guest OS booting)
* Support for deleting snapshots while the VM is running
* Support for multi-monitor guest setups in the GUI for Windows guests (see the manual for more information)
* USB tablet/keyboard emulation for improved user experience if no Guest Additions are available (see the manual for more information).
* LsiLogic SAS controller emulation (see the manual for more information)
* RDP video acceleration (see the manual for more information)
* NAT engine configuration via API and VBoxManage
* Use of host I/O cache is now configurable (see the manual for more information)
* Guest Additions: added support for executing guest applications from the host system (replaces the automatic system presimparation feature; see the manual for more information)
* OVF: enhanced OVF support with custom namespace to preserve settings that are not part of the base OVF standard
* VMM: fixed Windows 2000 guest crash when configured with a large amount of RAM (bug #5800)
* Linux/Solaris guests: PAM module for automatic logons added
* GUI: guess the OS type from the OS name when creating a new VM
* GUI: added VM setting for passing the time in UTC instead of passing the local host time to the guest (bug #1310)
* GUI: fixed seamless mode on secondary monitors (bugs #1322 and #1669)
* GUI: offer to download the user manual in the OSE version (bug #6442)
* Main: allow to start a VM even if a virtual DVD or floppy medium is not accessible
* Settings: be more robust when saving the XML settings files
* Mac OS X: rewrite of the CoreAudio driver and added support for audio input (bug #5869)
* Mac OS X: external VRDP authentication module support (bug #3106)
* Mac OS X: Moved the realtime dock preview settings to the VM settings (no global option anymore). Use the dock menu to configure it.
* Mac OS X: added the VM menu to the dock menu
* 3D support: fixed corrupted surface rendering (bug #5695)
* 3D support: fixed VM crashes when using ARB_IMAGING (bug #6014)
* 3D support: fixed assertion when guest applications uses several windows with single OpenGL context (bug #4598)
* 3D support: added GL_ARB_pixel_buffer_object support
* 3D support: added OpenGL 2.1 support
* 3D support: fixed Final frame of Compiz animation not updated to the screen (Mac OS X only) (bug #4653)
* 3D support: fixed blank screen after loading snapshot of VM with enabled Compiz
* Added support for virtual high precision event timer (HPET)
* OVF: fixed mapping between two IDE channels in OVF and the one IDE controller in VirtualBox
* OVF: fix VMDK format string identifiers and sort XML elements from rasd: namespace alphabetically as prescribed by standard
* VBoxShell: interactive Python shell extended to be fully functional TUI for VirtualBox
* Linux Additions: support Fedora 13 (bug #6370)
* VBoxManage: fixed overly strict checks when creating a raw partition VMDK (bugs #688, #4438)
Link to comment
Trillian 4.2 build 18
FIXED [MSN] "PassportAuthFail" when trying to remove a contact
- FIXED [MSN] Allow list not remembering status
- FIXED [MSN] Hotmail mail notification keeps disappearing
- FIXED [MSN] Msn default name overriding is not working with names that starts with "%" sign.
- FIXED [MSN] Trillian 4.2 MSN/WLM Buddy Icons are still not updating
- FIXED [MSN] Trillian invisible away mode changes personal/status message in Windows Live Messenger
- [MSN] Trillian send messages to random offline users
- FIXED [TWITTER] Doesn't warn if post has failed
- FIXED [TWITTER] Update trends timer is not working
- FIXED [XMPP] Entering a Jabber chat room with ' in you nickname results in service disconnect.
- FIXED [Away] Automatically saved messages are not being saved properly
- FIXED [Contact List] Contact List Blackout
- FIXED [Languages] Crash when creating meta contact with Drag&Drop (German surface)
- FIXED [Languages] Remove language code NO, add NB and NN
- FIXED [Languages] Update for 4.2
- FIXED [Menu] Some items have incorrect margins (think they are multiline but draw single)
- FIXED [Preferences] [Crash] Trillian crashes when you are in plug-ins menu and press ESC
Link to comment
Foxit Reader 3.3.1
What’s New in Foxit Reader 3.3
The following is a list of exciting new features in Foxit Reader 3.3.
  • Secure Trust Manager
    The new Secure Trust Manager enables users to allow or deny unauthorized actions and data transmission, including URL connection, attachments PDF actions, and JavaScript functions; efficiently avoiding the attack from malicious contents and viruses.
  • Improved Ask Search Button Setting
    Enables users to show or hide the Ask Search Button in the Preferences menu.
  • Many Bug Fixes
    Fixes some bugs from previous versions including an issue where Ask Toolbar may be installed by default.
Link to comment
MyDefrag version 4.3.1
Changes include:
- Added the Windows "bootstat.dat" file to the build-in list of special exceptions.
- To my great chagrin I have found that some programs can crash (most notably MySQL and uTorrent) if the disk on which they have open files is dismounted with the MyDefrag DismountVolume command. The command was used in the DataDisk scripts that were introduced in the previous version. I have now removed it.
- Added the MoveUpToZone fileaction.
- Changed the NTFS scanner so it will now always use 512 bytes for the USA fixup. Previously it used the number of bytes per sector, which is 512 bytes for most harddisks, but it appears that NTFS also uses 512 for ultra-big harddisks, even though they have a different number of bytes per sector.
- Added some code to SelectNtfsSystemFiles() to protect the program against infinite loops in data on the disk.
- Fixed a bug that caused MoveToEndOfDisk() not to display a progress percentage.
- Changed the ExcludeVolumes setting. It can now be used multiple times in a script.
- Documented the "/TASKS" installer commandline option.
- Added the SkipBlock option to all the SortBy fileactions.
- Added the ExitIfTimeout setting.
- Added the bouncing box display mode to the screensaver.
- Added a special exclusion for the "$dcsys$" file used by DiskCryptor so MyDefrag will never move this file. The exclusion is not really needed because the file is protected by the DiskCryptor driver, but I have added it anyway, just in case.
- Changed the way how variables can be defined and changed. Previously the syntax was "NAME=VALUE", but this caused undesirable error messages in case of a syntax error. Variables can now be defined and changed with the SetVariable command.
- Several improvements in error reporting. One of these is that the regular MyDefrag version will no longer ask the user to post the debug logfile on the forum.
- The ImportListFromProgramHints fileboolean will now ignore hint files that are older than 30 days.
- Changed the contents of the "date" variable from "2010/12/31" into "2010-12-31". The old contents could not be used for filenames.
- The installer will now create a daily scheduled task by default. Previously the default was not to create the task.
- Added the "DataDiskDaily.MyD", "DataDiskWeekly.MyD", "DataDiskMonhtly.MyD", "Daily.MyD", and "Monthly.MyD" scripts. Renamed the "OptimizeDaily.MyD" script into "SystemDiskDaily.MyD", "OptimizeWeekly.MyD" into "SystemDiskWeekly.MyD", and "OptimizeMonthly.MyD" into "SystemDiskMonthly.MyD".
- The installer now creates two scheduled tasks, a daily task and a monthly task.
- Fixed a problem in the ZoneSize and ZoneBegin script variables.
Link to comment
Chrome 5.0.375.55
- [7713] Canonicalize URLs closer to the Safe Browsing specification.
- [16535] Possible URL bar spoofing via unload event handlers.
- [30079] Memory error in Safe Browsing interaction.
- [39740] Bypass of whitelist-mode plugin blocker.
- [41469] Memory error with drag + drop. Credit to kuzzcc.
- [42228] Incorrect execution of Javascript in the extension context.
Link to comment
CCleaner v2.32.1165
v2.32.1165 (26 May 2010) - Added support for Microsoft Office 2010.
- Added Opera search field history cleaning.
- Added Real Player SP cleaning.
- Added "Analyze" and "Clean" context menu options to rule tree parent nodes.
- Added "Restore default settings" button to Advanced Options.
- Improved Opera favicons cleaning.
- Improved support for Media Player Classic.
- Improved cleaning of shortcuts on 64-bit machines.
- Improve localization support.
- Fixed bug with Russian translation.
- Minor bug fixes.
Link to comment
Thunderbird 3.1 RC1
- New Migration Assistant giving Thunderbird 2 users a way to choose the new features in Thunderbird 3.1 or to keep their current features and settings.
- a Saved Files Manager that displays all the files you downloaded from your email to your computer.
- Mail Account Setup Wizard
- Faster Search Results
- a Quick Filter Toolbar that lets you filter against search terms, tags, starred messages, address book contacts, new emails, and attachments.
- Improvements stability, memory usage, web compatibility and password handling
Link to comment
