Καινούργιες εκδόσεις (Haya)
PGM
Chrome 4.1.249.1064
- Fixed problem when Google Chrome was not using the correct path for the Java plugin for Java Version 6 Update 20.
- 4.1.249.1059 was much slower on JavaScript benchmarks than 4.1.249.1045.
- Fixed - High Cross-origin bypass in Google URL (GURL).
- Fixed - High Memory corruption in HTML5 Media handling.
- Fixed - High Memory corruption in font handling.
Link to comment
Share on other sites
  • Replies 2,4k
Chrome 4.1.249.1064
it's up
www.thelab.gr/showpost.php?p=1062808638&postcount=698
Link to comment
Trillian 4.2 build 16
FIXED [Activity History] Browse expand collapse graphic is clipped
- FIXED [Alerts] Quick Reply does not work with metacontacts
- FIXED [Cobalt] MetaContact IM Window Automation Broken
- FIXED [Contact List] Metacontact buddy icons don't display for non-primary identities
- FIXED [Contact List] mychats won't open chat windows out of contact list
- FIXED [Contact List] Primary identity contact list starts collapsed
- FIXED [Current Song] Skipping songs in Winamp causes Trillian to crash
- FIXED [iL] Better image zooming for non square images
- FIXED [iL] Better mouse movement detection so that the tooltip hides properly in certain situations
- FIXED [iL] Scrolling scrollbar may disappear midscroll if you move your mouse out of the area
- FIXED [iL] Secondary type support
- FIXED [Login] 4.2 Build 15 does not preserve proxy setting at login screen
- FIXED [Menus] Separators may appear at the bottom of a menu by themselves
- FIXED [Menu] Delete menu is missing from selecting multiple contacts
- FIXED [Preferences] Crash when viewing channel preferences and using 'back' and 'forward' buttons
- FIXED [Wizard] A user who is not fully set up may go to a migration wizard incorrectly
- FIXED [Wizard] Show an incorrect username error with the proper background color
- FIXED [MSN] Cannot ignore/block user
- FIXED [MSN] Incoming file transfers don't work
- FIXED [MSN] MSN contacts can't send nudges
- FIXED [OSCAR] aim status not being updated when away
- FIXED [TWITTER] Clicking on an alert should show reply window
- FIXED [TWITTER] Do not alert me about my own posts
- FIXED [TWITTER] duplicate alerts
- FIXED [TWITTER] Hide support for favorites group (hidden by default)
- FIXED [TWITTER] inline reply or retweet does not work correctly
- FIXED [TWITTER] OAuth support
- FIXED [TWITTER] reply via message window, subsequent messages should be replies
- FIXED [XMPP] Renamed Google contacts aren't saved
- FIXED [YAHOO] In messages from Yahoo I get "" at the end of each response
- FIXED [YAHOO] Missing context menu options
Link to comment
Trillian 4.2 beta
- FIXED [Contact List] Astra is Unresponsive after recent 4.2 beta upgrade
- FIXED [iL] Featured support w/ pref to turn off
- FIXED [iL] Strip formatting from menu text
- FIXED [Menu] Multiline support
- FIXED [Menu] Tooltips for ellipsis menus
- FIXED [YAHOO] Webcams crash when closing down
- FIXED [MSN] Msn default name overriding is not working with names that starts with "%" sign.
- FIXED [MSN] Trillian invisible away mode changes personal/status message in Windows Live Messenger
- FIXED [WLM] Typing indicator shows up even if chat partner is not typing
Link to comment
EVGA Precision 1.9.3
# Default tray icon text color has been changed from white to red to improve icon text readability in Windows 7
# Default screenshots folder location has been changed from application folder to common pictures folder
# Full EVGA Precision uninstallation no longer unregisters EVGA OC Scanner
# Fixed units and On-Screen Display group name for videomemory usage graph
# 'Stop the task if it runs longer than 3 days' option is no longer set in thetask settings when using alternate startup mode via the task scheduler under Windows Vista / Windows 7
# Screen capture and On-Screen Display hotkey events are now being processed via direct connection to the On-Screen Display server instead of command line. Due to this change Screen capture and On-Screen Display visibility control hotkeys are being processed faster now
# Now 'i' button displays info about active clients connected to EVGA On-Screen Display server, allowing you to see why the server is running on your system
# Now automatic 2D/3D profiles management feature is unlocked by default
# EVGA On-Screen Display server has been upgraded to version 3.7.0. New server gives you a lot of improvements including:
* DirectX 11 On-Screen Display and screen capture support
* DirectX screen capture engine is no longer using DirectX runtimes to capture and compress screenshots. Screen capture and compression to PNG/JPG formats in DirectX applications is now handled by own more effective LIBPNG/JPEGLIB based library
* PNG and JPG screen capture support for desktop and OpenGL applications
* Adjustable JPG screen capture quality for experienced users
* Screen capture support for DirectX10 and DirectX11 applications using multisampled antialiasing or non-standard frame buffer formats (e.g. sRGB)
* Optional On-Screen Display 3D rendering mode. New mode uses 3D accelerated DirectX functions to emulate previously used 2D framebuffer access functions and render 2D text. New rendering mode provides On-Screen Display support in DirectX10 and DirectX11 applications using multisampled antialiasing and can also drastically reduce OSD related performance hit on the systems with badly optimized 2D acceleration in display drivers
* Simplified On-Screen Display coordinate space settings. Rarely used desktop and window coordinate space modes have been merged into single framebuffer coordinate space mode
* Now the server automatically selects framebuffer coordinate space instead of viewport coordinate space when viewport is not accessible (e.g. if pure Direct3D8 device is in use)
* Improved application notification scheme during runtime profiles adjustment. Now runtime changes in OSD application profiles (e.g. OSD zoom ratio change on the fly) are reflected in affected application almost immedaitely instead of approximately 1 second delay in the previos versions
* Reduced runtime skin engine memory footprint due to dynamic skin storage unloading
* Improved race condition protection system for multithreaded 3D engines (e.g. Dragon Age: Origins and ArmA II)
* Improved race condition protection system for the systems running multiple OSD applications simultaneously (e.g. OSD server, FRAPS and STEAM In-Game Chat)
* Improved floating injection address hooking technology. Due to more advanced built-in code analyzer hooks can be injected deeper into 3D application code if stealth mode is enabled. These changes improve stealth mode compatibility with third party tools using similar stealth injection technologies (e.g. FRAPS v2.9.8 and newer)
* Now stealth mode cannot be toggled during 3D application runtime to reduce the risk of crashing 3D application
* Removed single screen capture per second limitation
* Updated profiles list
Link to comment
Opera 10.54
Core
- Made resolution of out-of-sync situations more reliable (Opera Link)
Desktop/UI
- Fixed DSK-284570 (No domain name shown on collapsed address bar)
- Fixed DSK-288469 (User interface becomes unresponsive after middle clicking on a link and selecting text)
- Fixed DSK-289395 (Text gone in appearance/toolbars section when using several old skins)
- Fixed DSK-292713 (Address bar searches in private mode is not using private mode context)
- Crash fixes
Mac
- Fixed DSK-281885 (Mouse gestures with Right-Click incorrectly triggers context menus)
- Fixed DSK-288147 (IME, without hitting Enter, doesn't work on input/textarea with key event listeners)
- Fixed DSK-293263 (Crash when getting icons from corrupt Opera Widget apps)
- Fixed DSK-295979 (Random Font Crash)
- Fixed DSK-296207 (Opera won't start when other apps change Opera menus)
- Fixed DSK-296242 (Crash on startup with system crash logger in WidgetInitLibrary)
- Fixed DSK-296550 (Crash on exit/closing windows)
- Fixed DSK-296554 (Crash when opening or closing a Window)
- Fixed DSK-295113 (Opera is stealing window focus by notification popup)
Windows
- Fixed DSK-279021 (Unable to install Unite applications)
- Fixed DSK-293862 (Desktop window got into weird non-drawing state)
Link to comment
Chrome 5.0.396.0
All
- The toolbar, omnibox and other UI changes reverted for Chrome 5 have been restored in this build.
- Fixed bug related to scheme stripping that could cause URLs of the form "http://ftp.foo.com" to be misnavigated, by not stripping the scheme in this case.
- Many bugs fixed relating to stripping "http://" and its interaction with the clipboard. Chrome should now prepend schemes onto the pasted text in a variety of situations.
Mac
- Continual polish to main frame UI, including the bookmark bar
Linux
- Bookmark bar icons should no longer be cropped under some GTK themes (particularly, the new ones in Ubuntu Lucid).
- Flash content when using nspluginwrapper should be clickable again.
Security
- Linux: Fixed a crash caused by a premature application data record in the middle of an SSL handshake (Issue: 42538)
Link to comment
WinSnap version 3.5.1
- New options toolbar for quick access to capture preferences
- New feature: delayed capture (5 seconds before taking snapshot)
- Updated trial reminder and enter license key dialogs
- Added ability to capture popup menus of QT applications (Object mode)
- Several fixes and improvements on the region selection mode
- Region selection is now 2 pixels wide
- Some other minor improvements and bug fixes
Link to comment
VirtualBox 3.2.0 Beta 2
# The following items were fixed and/or added:
* Following the acquisition of Sun Microsystems by Oracle Corporation, the product is now called "Oracle VM VirtualBox" and all references were changed without impacting compatibility
* Experimental support for Mac OS X guests (see Section 3.1.1, “Mac OS X guests”)
* Memory ballooning to dynamically in- or decrease the amount of RAM used by a VM (64-bit hosts only) (see Section 4.9, “Memory ballooning”)
* CPU hot-plugging for Linux (hot-add and hot-remove) and certain Windows guests (hot-add only) (see Section 9.5, “CPU hot-plugging”)
* New Hypervisor features: with both VT-x/AMD-V on 64-bit hosts, using large pages can improve performance (see Section 10.5, “Nested paging and VPIDs”); also, on VT-x, unrestricted guest execution is now supported (if nested paging is enabled with VT-x, real mode and protected mode without paging code runs faster, which mainly speeds up guest OS booting)
* Support for deleting snapshots while the VM is running
* Support for multi-monitor guest setups in the GUI for Windows guests (see Section 3.5, “Display settings”)
* USB tablet/keyboard emulation for improved user experience if no Guest Additions are available (see Section 3.4.1, “"Motherboard" tab”).
* LsiLogic SAS controller emulation
* RDP video acceleration (see Section 7.1.8, “VRDP video redirection”)
* NAT engine configuration via API and VBoxManage
* Use of host I/O cache is now configurable (see Section 5.7, “Disk images and I/O caching”)
* Guest Additions: added support for executing guest applications from the host system
* OVF: enhanced OVF support with custom namespace to preserve settings that are not part of the base OVF standard
* VMM: fixed crash with the OpenSUSE 11.3 milestone kernel during early boot (software virtualization only)
* VMM: fixed OS/2 guest crash with nested paging enabled
* VMM: fixed Windows 2000 guest crash when configured with a large amount of RAM (bug #5800)
* VMM: fixed massive display performance loss (AMD-V with nested paging only)
* Linux/Solaris guests: PAM module for automatic logons added
* GUI: guess the OS type from the OS name when creating a new VM
* GUI: added VM setting for passing the time in UTC instead of passing the local host time to the guest (bug #1310)
* GUI: fixed seamless mode on secondary monitors (bugs #1322 and #1669)
* GUI: added --seamless and --fullscreen command line switches (bug #4220)
* GUI: offer to download the user manual in the OSE version (bug #6442)
* Main: allow to start a VM even if a virtual DVD or floppy medium is not accessible
* Settings: be more robust when saving the XML settings files
* Mac OS X: rewrite of the CoreAudio driver and added support for audio input (bug #5869)
* Mac OS X: external VRDP authentication module support (bug #3106)
* Mac OS X: Moved the realtime dock preview settings to the VM settings (no global option anymore). Use the dock menu to configure it.
* Mac OS X: added the VM menu to the dock menu
* 3D support: fixed corrupted surface rendering (bug #5695)
* 3D support: fixed VM crashes when using ARB_IMAGING (bug #6014)
* 3D support: fixed assertion when guest applications uses several windows with single OpenGL context (bug #4598)
* 3D support: added GL_ARB_pixel_buffer_object support
* 3D support: added OpenGL 2.1 support
* 3D support: fixed Final frame of Compiz animation not updated to the screen (Mac OS X only) (bug #4653)
* 3D support: fixed blank screen after loading snapshot of VM with enabled Compiz
* Added support for virtual high precision event timer (HPET)
* LsiLogic: Fixed detection of hard disks attached to port 0 when using the drivers from LSI
* NAT: fixed ICMP latency (non-Windows hosts only; bug #6427)
* Keyboard/Mouse emulation: fixed handling of simultaneous mouse/keyboard events under certain circumstances (bug #5375)
* Shared folders: fixed issue with copying read-only files (Linux guests only; bug #4890)
* OVF: fixed mapping between two IDE channels in OVF and the one IDE controller in VirtualBox
* OVF: fix VMDK format string identifiers and sort XML elements from rasd: namespace alphabetically as prescribed by standard
* VRDP: allow to bind to localhost only on Mac OS X (bug #5227)
* VBoxShell: interactive Python shell extended to be fully functional TUI for VirtualBox
Link to comment
OpenOffice version 3.2.1
Changes in this version include:
- Improved startup speed
- Support for Microsoft Office 2007 files
- Encryption support for Microsoft Word 97, 2000, XP files
- Database forms now support zooming
- Impress supports comments
- Import pivot tables from Microsoft Excel 2007 documents
- Improved sort, cell merging, and complex copy and paste features in Calc
Link to comment
Skype 4.2.0.166
Fixed issues:
* Call forward
- Skype crashed for the caller when a call was being forwarded to a phone and answered on the actual device.
* Skype Access
- Extending a Skype Access session first resulted in a “hotspot not valid” dialog, then after a few seconds the session got correctly extended, but the cost information and wifi SSID was not shown.
Link to comment
FotoMix version 6.2
- New skin and implements transparent background feature
- Fix a problem when installed in a read only disk folder
- This new release fix a problem with the online help.
- Remove, add or alter backgrounds.
- Add or remove your loved and not so loved ones from your pictures.
- Design eye-catching photo collages, illustrations, wallpapers, CD and DVD covers, and miscellaneous Web graphics.
- Create photo montages by combining multiple pictures into a unique heirloom depicting retrospectives of a birth, marriage, anniversary, etc. Anything is possible.
Link to comment
Pidgin version 2.7.0
Changes include:
- Changed GTK+ minimum version requirement to 2.10.0.
- Changed GLib minimum version requirement to 2.12.0.
- Using the --disable-nls argument to configure now works properly. You will no longer be forced to have intltool to configure and build.
- Fix two related crashes in the GnuTLS and NSS plugins when they suffer internal errors immediately upon attempting to establish an SSL connection.
- Fix NSS to work when reinitialized after being used. (Thanks to Ludovico Cavedon for the testcase)
- Added support for PURPLE_GNUTLS_PRIORITIES environment variable. This can be used to specify GnuTLS priorities on a per-host basis. The format is "host=priority;host2=priority;...". The default priority can be overridden by using "*" as the host. See the GnuTLS manual for documentation on the format of the priority strings.
- Fix autoconf detection of Python. (Brad Smith)
- Fix a crash when a Windows proxy (from IE) does not have a port. (Marten Klencke)
Link to comment
