Καινούργιες εκδόσεις (Haya)
PGM
Auslogics Disk Defrag ver 3.1.4.110
Changes include:
- Added VSS mode support, a special defragmentation mode that is optimized for volumes with enabled Shadow Copy mode (VSS). This mode minimizes the increase of VSS storage space caused by moving files and diminishes the risk of overwriting old VSS copies
- Improved consolidation algorithm when moving system files. Now the program does not move files that have no effect on computer speed
- Improved program operation when there are too many fragmented files on the disk
- Fixed bugs
- Improved program interface
Link to comment
Share on other sites
  • Replies 2,4k
Chrome 5.0.366.2 (windows +linux) & ve r5.0.366.0 (MAC)
All
- Fixed a bug with incognito extensions like RSS Subscription.
- Will no longer automatically offer to translate in incognito mode.
- Fix file upload code to not hang the HTTP session when the file is unreadable.
Mac
- Improvements to the bookmark manager
- Re-enable pinned tabs; add support for mini and app tabs.
- Fix selection issues with the cookie manager after deleting cookies.
Linux
- Some minor UI changes in the omnibox.
- Recent regressions in font rendering have been fixed.
Link to comment
Foxit reader 3.2.1
New features:
  • Undo and Redo
    Allows users to easily correct mistakes by cancelling their previous actions and quickly adding back in changes made with the Undo option, this makes it convenient for users to revoke their performances and enables better editing requirements.
  • Expand Current Bookmark
    Click the Expand Current Bookmark icon to expand nested bookmarks and highlight the bookmark of the current page.
  • Grayscale Printing
    Reader 3.2 supports to print in grayscale, using many shades of gray to represent subtle variations in color and light.
  • Speed up printing
    Foxit Reader has optimized the printing feature, improving the speed of printing dramatically.
  • Logical Page Number Support
    Display the physical and logical page number on the status bar at the bottom of the working area, enabling you to go right to the desired page fast and accurately.
  • Hundreds bugs fixed
Link to comment
GPU-Z 0.4.2
  • Fixed an issue on all NVIDIA cards that would sometimes cause them to lose fan control when GPU-Z is running. Please don't run pre-0.4.2 and 0.4.2 at the same time, this might result in incorrect readings in the 0.4.2 window.
  • Fixed system crash on MSI HD 5830 TwinFrozr II
  • Validation upload now uses Unicode for entered name
  • Reverted memory bandwidth calculation introduced in last version. It introduces too much confusion, we will go with what all companies use in their marketing material, even though we believe it is not correct. Using power of 10 again now, 1 GB/s = 1,000,000,000 Bytes per Second.
Link to comment
uTorrent 2.0.1 RC2
Changes include:
- Fix: uTP performance and TCP rate control have been greatly improved!
- Fix: BEP22 has been fixed
- FIx: Access denied problems should be virtually non-existent
- Change: prioritize downloading torrents even more than seeds when making new connections
- Change: change default uTP packet size to 600 bytes
- Change: Use new uTP header by default
- Change: remove duplicate IPv6 peer connection fix
- Fix: crash with webseeds
- Change: default double click action is "Open Folder" for seeding torrents
- Fix: eliminate duplicate connections to the same peer ID over different IPs
- Fix: saving of column settings
Link to comment
ESET NOD32 Antivirus version 4.2.42
Changes in this update include:
- Fix: Issues with HTTP scanner with longer domain names ( support for length of domain name to 256 characters)
- Fix: Issues after PC restart when firewall system integration is "only scan application protocols"
- Fix: When ESS installed with disabled FW, dialog about trusted networks not displayed
- Fix: Installation of ESS using Remote Desktop; after selecting firewall's "Interactive mode", the session will interrupt
- Fix: Long file name makes trouble with logs in "document protection enabled" mode
- Fix: Scan profile settings not retained after reinstallation
- Fix: Open ESI log of EAV doesn't work on Microsoft Windows NT4.0
- Fix: Not possible to save EAV's ESI log and export service script on Microsoft Windows NT4.0
- Fix: Wrong settings imported from ESS configuration cause problems in EAV
- Fix: All ESI logs are lost after upgrade from V4 to V4.2
- Fix: Impossible to delete the on-demand Scan Log in ESS
- Fix: Fixed ceasing of scan tasks when logged in as standard user
- Fix: Minor issues with Trusted zone conversion from older to newer version
- Fix: Unification of behavior when disabling some parts of EAV/ESS/EMS in the main settings window
- Fix: Possible to delete log of a running on-demand scan
- Fix: X64 Vista + win7: UAC appears when opening ESI log from ESS/EAV GUI
- Fix: Minor Thunderbird and Outlook issues.
Link to comment
Trillian 4.2 beta
- Windows Live - Trillian now supports signing in to WLM from multiple locations! File transfer speed has been improved (more to come), and mobile messaging is now supported.
- Notifications - You can now use notifications to directly retweet, reply to a tweet, and interface with mail right away.
- MetaContact Windows - When talking to a MetaContact, if you receive a message from another of their usernames the window will automatically switch for you.
- Instant Lookup for Hyperlinks - Move your mouse cursor on top of links to preview. Youtube links will show a preview image, too. Great for detecting NSFW links before you open them in browser, and will even resolve shortened links.
- Instant Lookup for Popular Terms - We now have more up-to-date Wikipedia data, and more relevant links for each popular term detected.
- Activity History - A polished look and powerful new asset view feature that lets you browse through images sent and received help improve history.
- Quicker MetaContact Creation - You can now drag and drop one contact on top of another to instantly combine them into a MetaContact.
- Other Updates - Support for Twitter's new retweet mechanism, Twitter Lists, a customizable timeout for notification windows, and the return of custom avatar support.
- Skin Packs - Emoticon and Sound Packs have been moved to a more prominent location in preferences and are easier to change on-the-fly. You can also change contact list icons now with the new Icon Packs.
- Faster Setup For New Users - We've tidied up some of the screens in the installation wizard so new customers can get started more quickly than before!
Link to comment
Baku registry cleaner version 4.1.3757
Changes in this version include:
- Ability to create system restore points before registry scan.
- Improved web browser cleaning (includes Chrome support).
- Improved ability to ignore specific registry errors.
- Ability to delete old system restore points.
- Improved 64-bit support.
- Bug fixes.
Link to comment
Orbit Downloader 3.0.0.4
Changes since version 3 include:
- Fix: Firefox Addon doesn't work in some case.
- Add: Add "Become a fan" and "Follow us" link on status bar.
- GetIt can not catch some URL in IE6
- Add: editing function and right mouse button function of Tag
- Add: remember the selected state, tag, tab when you exit
- Improve: keep the task stay in "downloading" when you pause it
- Fix: file has not been removed when delete the completed task
- Fix: Crash When start.
Link to comment
Chrome 4.1.249.1059
- [39443] High - Type confusion error with forms.
- [39698] High - HTTP request error leading to possible XSRF.
- [40136] Medium - Local file reference through developer tools.
- [40137] Medium - Cross-site scripting in chrome://net-internals.
- [40138] High - Cross-site scripting in chrome://downloads.
- [40575] Medium - Pages might load with privileges of the New Tab page.
- [40635] High Memory corruption in V8 bindings.
Link to comment
firefox 3.6.4build1
Firefox 3.6.4 provides uninterrupted browsing for Windows and Linux users when there is a crash in the Adobe Flash, Apple Quicktime or Microsoft Silverlight plugins.
If a plugin crashes or freezes, it will not affect the rest of Firefox. You will be able to reload the page to restart the plugin and try again.
Firefox 3.6.4 also fixes the following issues found in previous versions of Firefox 3.6:
* Fixed several security issues.
* Fixed several stability issues.
Link to comment
Chrome 5.0.375.17
All
- Disabled profile based Autofill (this will return in a future release)
- Various UI features related to the url bar/ omnibox have been removed from this release (e.g. http:// truncation, star icon, etc...)
- Various crash fixes
Windows
- We have restored the shortcuts for the bookmarks bar and bookmarks manager (Ctrl+B and Ctrl+Shift+B respectively)
Link to comment
Ccleaner v2.31.1153
v2.31.1153 (26 Apr 2010) - Improved Opera favicon cleaning by only deleting non-bookmarked entries.
- Detailed view can now be set as default in Advanced options.
- Added support to save Startup items to a text file.
- Added new INI variable for Local Low folder %locallowappdata%.
- Improved OpenOffice 3.x support.
- Improved Quicktime player cache cleaning when in Protected Mode.
- Fixed bug where Summary panel text could be edited.
- Fixed bug in Uninstall Tool for Windows 2008 R2.
- GUI improvements to Cookie screen.
- Include/Exclude screen sorts entries in alphabetical order.
- Number formatting is more accurate in Cleaner results.
- Various minor bug fixes.
Link to comment
Chrome 4.1.249.1064 stable
Fixed problem when Google Chrome was not using the correct path for the Java plugin for Java Version 6 Update 20.
- 4.1.249.1059 was much slower on JavaScript benchmarks than 4.1.249.1045.
- Fixed - High Cross-origin bypass in Google URL (GURL).
- Fixed - High Memory corruption in HTML5 Media handling.
- Fixed - High Memory corruption in font handling.
Link to comment
Opera 10.52
# User Interface
* Added
- A tooltip to the Opera O menu
* Fixed
- After removing an option from a SELECT, the wrong option appears selected
- Windowless QuickTime not working
- Context menu search opening in a new tab, and not reusing current tab
- Copy Link Address context menu item following redirects
- Problem with MDI window size after maximizing an Opera window
- Not being able to drag a bookmark into a tab with a page already loaded
- Scrollbars not showing on transformed elements
- Old tab content showing briefly when opening link in a new tab
- Middleclick scrolling also scrolls fixed positioned content
- Opening and closing an Opera Panel changes the position of a child window
- Slow scrolling when using page search (when page is dimmed)
- UI dropdowns should be closing when their parent button is clicked a second time
- Crash dialog not defaulting to a restart of Opera
- Warning dialog for configuration file download not disappearing
- Problem occurring after customizing the Transfers Panel
- "Copy Video Address" not working
- "Exit" button in sync dialog not working
- Flash videos flickering, disappearing, or being corrupted after scrolling
- First Opera Link synchronization not properly syncing modified bookmarks
- Not being able to copy an audio address in a context menu
- "Rewind" and "Fast Forward" always being disabled/grayed out in a right-click context menu
- "New Tab" from Dock or Jumplist creating a new window with two tabs
- Printing dialog on maps.google.com blocks keyboard input
- Check boxes not having a focus indication
- Client being put in an endless synchronization loop
- Problem closing a tab with customized search field or appearance dialog open
- Problem occurring with the Westpac bank Web site
- Gray out/disable "remove from toolbar" for the Opera O menu button
- Edited Notes not being updated when using Opera Link
- Filename missing from the image context menu
- Freeze when importing a large bookmark file
- Problem occurring after synchronization
- "Reload Image" being ignored after an unfinished image load
- Mouse gesture "Back | Close page" not working for the "Close page" action
- Several problems related to accessibility
- Problem causing immediate exit on a page with Silverlight
- Clearing of clipboard data from private browsing on tab/window close
- Open window in the background opens a link in a foreground window
- A problem when typing any character in the Open dialog and pressing the Enter key
# Mail, News, Chat
* Fixed
- Mail lost when upgrading from Opera 9.27 to Opera 10.52
# Display and scripting
* Improved
- Various aspects of the Carakan JavaScript engine
* Fixed
- Several cache issues
- An issue with the image onerror event
- Enabling designmode removes event listeners
- XMLHttpRequest response referrer being wrong when request initiated in call from another frame
- Incorrect precision on negative numbers, setTimeout, and setInterval
- Wrong accelerator key being used for CJK fonts
- Incorrect font being used for UTF-8 pages without a language specified
- Painting issues affecting page scrolling when part of the page is covered
- Opera Dragonfly not selecting an active tab when opened
- Problem when enumerating an object
- Flash video continuing to download after the tab is closed
- Arguments for "execute program" not being sent to the external program
- Problem when changing the skin and color scheme
- Links from external applications not opening in Opera
- Problem when opening international fonts dialog
- Painting issues scrolling page when part of the page is covered by dialog
- Problem with SVG DOM
- Problem with the Facebook website
# Security
* Improved
- Security information dialog entries
# Network
* Fixed
- Waiting for DNS confirmation of cookie domain(s)
- Network problem when using a proxy
- Supporting any HTTP verb in XHR, with exceptions
- Multiple connection attempts failing over a proxy
- Incorrect location setting of an HTTPS iframe from different server
# Opera Unite
* Fixed
- Problem when accessing the admin pages
- "Enable Unite" preference not working
# Opera Widgets for Desktop
* Improved
- Removed security policy restrictions on widget.openURL and external links
* Fixed
- Opera Unite Media Player application being maximized when hovering over the taskbar
- Issue when clicking the right mouse button in the "Connect to Remote Debugger" dialog
- Creating folders is not questioned if an installation path is simply typed
- Widgets with sufficiently long non-ASCII names not always appearing as being installed
- Widget in application mode position being stored incorrectly after a restart
- Spellcheck not fixing words in widgets
- Instance number not displaying on initial installer screen if installing another instance of the same widget
- Widget with : and / in its name not being installed
- Widget freezing when connecting to debugger
Link to comment
HWiNFO32 v3.50
Added support of Fintek F81865 LPC/Sensor.
- Added Patsburg PCH support.
- Added support of PCI Express 3.0 (8.0 GT/s) capabilities.
- Added monitoring of sensor values in graph.
- Fixed recognition of Intel Xeon W35xx CPUs.
- Improved sensor monitoring for ASUS Crosshair IV Formula.
- Added reporting of GPU clocks and memory size for GF100.
- Improved sensor monitoring for several ASRock boards.
- Added nVidia D12U, T20, Tesla C2050/C2070/M2050/M2070/S2050/S2070, Quadro Q11U-3, MCP83 and some other models.
- Fixed reading of AMD K10 temperature sensor.
- Improved reporting of CPU dynamic clock for AMD Family 10h and later.
- Improved support of Sandy Bridge family.
- Improved sensor monitoring for Giga-Byte EP43/EP45/X38/X48 series.
- Added GPU Diode temperature reporting for nVidia G92 and G94.
Link to comment
