hayabusa Μάρτιος 9, 2010 #661 Κοινοποίηση Μάρτιος 9, 2010 MyDefrag 4.2.9- Added a check to MoveToEndOfDisk to exit more quickly if the program is stopped prematurely.- Fixed an installation bug that causes an "unable to execute file" error for the MyDefragScreenSaver.scr file.- Changed the MoveToEndOfDisk fileaction so it will skip a file faster if there is no gap large enough above the file.- Changed the MoveToEndOfDisk fileaction so it will stop faster when MyDefrag is stopped by the user.- Fixed a bug that limited the value of constant numbers in a script to 2147483647.- The ZoneBegin will no longer be automatically moved by a zone that contains a MoveToEndOfDisk fileaction.- Removed the automatic disk filters from most of the default scripts. For example, the script for flash memory disks will now run for all the selected disks, and not only for removable disks.- Fixed a problem where enlarging a gap for FastFill would be extremely slow if the file to be moved away was a NTFS compressed file.- Fixed a bug in MaxRunTime statement that would cause it to always use zero as maximum runtime.- Fixed a bug that could cause the subroutine that enlarges gaps for FastFill(WithShuffling) to move items that were already processed (placed in a previous zone).- Fixed a bug in the grammar that prevented the WhenFinished(Shutdown) setting from accepting the sub-options.- Fixed 2 bugs in string variables.- Changed PreventScreenSaving() into SetScreenSaver.- Changed PreventPowerSaving() into SetScreenPowerSaver.- Changed the subroutine that vacates the NTFS reserved area, Previously it would not count NTFS reserved area free space that was already there, resulting in unnecessary data movement.- Fixed a bug in NTFS scanner so it will now load a minimum of 1 sector when loading the first record of the MFT. On ultra-big harddisks the size of an MFT record (1 kilobyte) can be smaller than the number of bytes per sector.- The ImportListFromProgramHints fileboolean is now oompatibel with Windows XP. Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 11, 2010 #662 Κοινοποίηση Μάρτιος 11, 2010 Skype version 4.2.0.155Changes include:- Payments: It was not possible to make payments with a credit card that had not been previously used for any Skype purchases.- Installation: Skype crashed for some users after installation.- Security: Fixed Skype URI handler security vulnerability. Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 11, 2010 #663 Κοινοποίηση Μάρτιος 11, 2010 ESET Smart Security, NOD32 Antivirus 4.2 - Windows Automated Installation Kit (AIK) 2.0 for Windows 7- Improved performance HTTP scanning- Limited support for NT 4.0 SP6 (ESET NOD32 Antivirus only)- Support for Thunderbird 3 and Opera 10 (ESET Smart Security only)- Trusted network zone authentication (ESET Smart Security only)- Firewall profiles (ESET Smart Security only)- Support for centralized quarantine management (with ESET Remote Administrator 4 Beta)- Support for firewall rule merge wizard (ESET Smart Security with ESET Remote Administrator 4 Beta)- GUI enhancements- Fixes for known issues Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 12, 2010 #664 Κοινοποίηση Μάρτιος 12, 2010 Foxit Reader version 3.2.0.0303Changes include:- Undo and Redo. Allows users to easily correct mistakes by cancelling their previous actions and quickly adding back in changes made with the Undo option, this makes it convenient for users to revoke their performances and enables better editing requirements.- Expand Current Bookmark. Click the Expand Current Bookmark icon to expand nested bookmarks and highlight the bookmark of the current page.- Grayscale Printing. Reader 3.2 supports to print in grayscale, using many shades of gray to represent subtle variations in color and light.- Speed up printing. Foxit Reader has optimized the printing feature, improving the speed of printing dramatically.- Logical Page Number Support. Display the physical and logical page number on the status bar at the bottom of the working area, enabling you to go right to the desired page fast and accurately.- Hundreds bugs fixed Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 15, 2010 #665 Κοινοποίηση Μάρτιος 15, 2010 DisplayFusion version 3.1.8Changes include:- Added a “Don’t snap windows while ‘Shift’ is pressed” option- Added a “Pause wallpaper changes while on battery power” option- Added a new HotKey & TitleBar Button: “Toggle Window Always on Top”- Added a new HotKey & TitleBar Button: “Move window to monitor #X”- Added a new HotKey & TitleBar Button: “Move all windows to monitor #X”- Added a “Check for Beta Updates” option in the Settings window, on the Options tab- Added an “Automatically select the best image” option in the “Edit TitleBar Button” window- Added an “Image” column to the TitleBar Button tab in the Settings window to show the selected button image’s filename- Added a new Advanced Setting called “TitleBar Button Vertical Offset” for forcing the -TitleBar Buttons position up/down- Vladstudio random image changer now chooses from all the images, not just the newest 100 images- Each HotKey in the HotKeys list in the Settings window now has a tooltip describing it’s actions- Improved taskbar button dragging- Wallpaper and Settings windows now open on the monitor the mouse cursor is currently on (instead of always opening on the primary monitor)- Wallpaper window now automatically re-sizes itself to fit on smaller resolution monitors (like netbooks)- Wallpaper window now has a “Copy settings from Monitor #x” in each monitor’s context menu- Wallpaper window now only prompts to apply settings when you have changed something- Wallpaper images can now be scaled by a certain percent to enlarge or shrink the image- Added new options for middle-clicking taskbar buttons on the DisplayFusion taskbars- Added 2 new Compatibility settings for disabling maximized window dragging and middle-click window moving- Added an “Edit” button to the TitleBar Buttons tab in the Settings window for editing existing buttons- As well as a whole host of other fixes and enhancements Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 15, 2010 #666 Κοινοποίηση Μάρτιος 15, 2010 Opera 10.51 RC1 (windows only)- Several Carakan crash fixes- Fixed CORE-27660 (Improve Carakan memory usage compared to Futhark)- Fixed ALIEN-892 (Fix unite 404 issues due to zip loader not adding all folders)- Fixed DSK-287613 (Crash when right-clicking entries under "All messages" and selecting Compose) Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 16, 2010 #667 Κοινοποίηση Μάρτιος 16, 2010 WinRAR version 3.93Changes include:- In WinRAR 3.92 -xd:\path\folder switch could also exclude folders, which path does not match the path specified in the switch and only the folder name is the same as specified.- Switches -y -or did not work correctly together. Switch -or was ignored in presence of -y. Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 17, 2010 #668 Κοινοποίηση Μάρτιος 17, 2010 Chrome 4.1.249.1036- Translate infobar.- Privacy features: content settings (cookies, images, JavaScript, plug-ins, pop-ups).- Disabling experimental new anti-reflected-XSS feature called "XSS Auditor".... and multiple security fixes:- Race conditions and pointer errors in the sandbox infrastructure (High rating)- Delete persisted metadata such as Web Databases and STS (Low)- HTTP headers processed before SafeBrowsing check (Medium)- Memory error with malformed SVG (High)- Integer overflows in WebKit JavaScript objects (High)- HTTP basic auth dialog URL truncation (Medium)- Bypass of download warning dialog (Medium)- Cross-origin bypass (High)- Memory error with empty SVG element (High) Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 18, 2010 #669 Κοινοποίηση Μάρτιος 18, 2010 FTPGetter Standard version 3.30.0.63Changes include:- Pausing some tasks in the profile. Tasks with the Paused status are not processed.- New variables that can be used in source and destination paths to files, in the parameters of external programs, in FTP scripts: %c_dd%, %c_mm%, %c_yy%, %c_yyyy%, %c_hh%, %c_min% - current day, month and year, hours and minute; %s_dd%, %s_mm%, %s_yy%, %s_yyyy%, %s_hh%, %s_min% - day, month, year, hours and minute when the source files was modified.- If profile tasks are being processed, the processing stops immediately after a click on the Suspend button.- New program statuses have been added: queuing files for transfer, comparing files, downloading files, uploading files.- Canceling executing all tasks while they are being executed.- Selecting the command that is used to view the contents of directories on the server LIST, LIST -la, NLST- The file comparison procedure has been improved. Now no comparison occurs if the destination folder has not existed before the program started to transfer files and FTPGetter has just created it, if the destination file does not exist so far on the local disk in the download mode.- Now if the "Also process subfolders" option is selected, subfolders are processed right after the parent folder is processed.- The file transfer rate has been increased.- Fixed: Working with large files (>2GB ).- Fixed: Error while starting the GUI when FTPGetter runs as a service under Vista. Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 19, 2010 #670 Κοινοποίηση Μάρτιος 19, 2010 Miranda IM version 0.8.17Updates include:- Installer now includes a portable mode option- Added auto rename button to file transfer file exists prompt- Minor fix for off screen positioning- Fixed docking issues with contact list- Gadu-Gadu: Improved message handling- Gadu-Gadu: Fixed memory leaks- Gadu-Gadu: Support contacts with large UINs- Gadu-Gadu: Fixed idle issues with empty status messages- MSN: Added handling of authentication failure due to incomplete profile- Jabber: Translation improvements Link to comment Share on other sites More sharing options...
kreach Μάρτιος 20, 2010 #671 Κοινοποίηση Μάρτιος 20, 2010 Speccy 1.00.125 Beta "Speccy will give you detailed statistics on every piece of hardware in your computer. Including CPU, Motherboard, RAM, Graphics Cards, Hard Disks, Optical Drives, Audio support. Additionally Speccy adds the temperatures of your different components, so you can easily see if there's a problem! * Processor brand and model * Hard drive size and speed * Amount of memory (RAM) * Graphics card * Operating system At first glance, Speccy may seem like an application for system administrators and power users. It certainly is, but Speccy can also help normal users, in everyday computing life. If you need to add more memory to your system, for example, you can check how many memory slots your computer has and what memory's already installed. Then you can go out and buy the right type of memory to add on or replace what you've already got." Fixes: * Added Network section. * Added 'Save as XML' feature. * Improved graphics card summary. * Added support for mouse back button. * Stability fixes when scanning system. * Many small bug fixes. Το κατέβασα πριν λίγη ώρα και το βρήκα ενδιαφέρον. Υπόψιν, βρίσκεται ακόμα σε beta φάση !!! @Haya: Το έχεις τσακίσει βλέπω το topic! Ένα μπράβο από μένα Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 22, 2010 #672 Κοινοποίηση Μάρτιος 22, 2010 Opera 10.51User InterfaceFixed - Drag and Drop not working in some instances - Deleting a bookmark closing/collapsing all folders - Focus being lost when deleting bookmarks - Integrated search performing searches in Google and not in the page - The Opera O menu button reappearing when the Menu bar is enabled - The Opera icon remaining in the system tray after closing Opera - Minimized tabs not displaying after a restart - Favicon not being added to Bookmarks due to a question mark in the filename - Individual characters in Chinese text being rotated anti-clockwiseMail, News, ChatFixed - A problem occurring when right-clicking entries under "All messages" and selecting Compose - Chat notification appearing if a chat tab is active - Ghost e-mails appearing in the Trash folder after emptying it and restarting Opera - Message not loading when it is deselected and selected again - Mail being blank when using fit to width - Attached files not being sent if mail is sent immediately after attaching them - Opera Mail welcome e-mail message not being localized - The text part of HTML e-mails missing the reply character " > " for block quotesDisplay and scriptingImproved - Numerous improvements to the Carakan JavaScript engineFixed - Icons missing from menus in 16-bit color mode - Slow scrolling performance - Incorrect font used for a UTF-8 encoded page without the language (CJK) being specifiedSecurityFixed - Fixed an issue where the HTTP Content-Length header could be used to execute arbitrary code; see our advisory (http://www.opera.com/support/search/view/948/). - Fixed an issue where XSLT could be used to retrieve random contents of unrelated documents, as discovered by crazypops; see our advisory (http://www.opera.com/support/search/view/949/).NetworkFixed - Cookies received over NPAPI being incorrectly parsed - Reinstated blocking of third party cookies by default - Opera sometimes storing a cookie for the domain it came from, rather than the set domain Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 23, 2010 #673 Κοινοποίηση Μάρτιος 23, 2010 FileZilla version 3.3.2.1 Changes include:- Remember location of update download directory- Cancel file renaming on actions that change the file list, such as changing sort order or performing a refresh- Cancel file renaming if starting a drag&drop operation- Filter invalid characters if downloading through double-clicking files or if adding from the search dialog- Fix site-specific bookmarks menu- The menu did not reflect initial value of preserve timestamp option properly- MSW: Keep FileZilla subdirectory in startmenu when updating, preserves custom order- MSW: Add AppID support to installer Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 23, 2010 #674 Κοινοποίηση Μάρτιος 23, 2010 WHS Add-in ClamAV version 0.1.6 Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 25, 2010 #675 Κοινοποίηση Μάρτιος 25, 2010 FotoMorph Free Edition 10.1New features include:- Create movie add-on effects such as different animation frames- Print current animation frame; WYSIWYG print preview- Customizable skin user interface- Warping sequence Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 26, 2010 #676 Κοινοποίηση Μάρτιος 26, 2010 7-Zip version 9.12Supported formats:Packing / unpacking: 7z, ZIP, GZIP, BZIP2 and TAR; Unpacking only: ARJ, CAB, CHM, CPIO, DEB, DMG, HFS, ISO, LZH, LZMA, MSI, NSIS, RAR, RPM, UDF, WIM, XAR and Z.For ZIP and GZIP formats 7-Zip provides compression ratio that is 2-10 % better than ratio provided by PKZip and WinZip. Self-extracting capability for 7z format. Integration with Windows Shell. Powerful File Manager. Powerful command line version.Updates include:- ZIP / PPMd compression ratio was improved in Maximum and Ultra modes.- The BUG in 7-Zip 9.* beta was fixed: LZMA2 codec didn't work, if more than 10 threads were used (or more than 20 threads in some modes). Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 29, 2010 #677 Κοινοποίηση Μάρτιος 29, 2010 Chrome 5.0.360.0All- Tabbed bookmark manager- Several Translate improvements- Fixed several AutoFill features- Fixed long timeout when navigating away from slow pagesLinux- Fixed menu popups for Xinerama users- Better crash dumping Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 29, 2010 #678 Κοινοποίηση Μάρτιος 29, 2010 VirtualBox 3.1.6Changes include:- Linux hosts: fixed timing issue on hosts with Linux kernels 2.6.31 or later with certain CPUs- Linux hosts: properly handle host suspend/resume events on Linux kernels 2.6.30 or later- Mac OS X hosts: fixed VBoxSVC crash while enumerating the host network interfaces under certain circumstances- Snapshots: fixed image corruption after snapshot merge under certain circumstances- Snapshots: fixed crash with VBoxHeadless / OSEFull changelog Link to comment Share on other sites More sharing options...
hayabusa Μάρτιος 31, 2010 #679 Κοινοποίηση Μάρτιος 31, 2010 CCleaner ver. 2.30.1130Changes include:- Improved Firefox History cleaning to remove orphaned items.- Improved Opera History cleaning.- Improved Options Include/Exclude screens.- Added manual domain adding for Cookies to keep list.- Added time remaining to Wipe Free space.- Added context menu to Summary Results for individual rule cleaning.- Added context menu to Detailed Results to add file to Exclude list.- Improved Firefox database compacting.- Improved support for OpenOffice.- Improved support for screen reader.- Improved registry detection and backup support for 64-bit OSs.- Improved Free Space wiping routines.- Fixed bug in application detection algorithm.- Minor GUI improvements. Link to comment Share on other sites More sharing options...
hayabusa Απρίλιος 1, 2010 #680 Κοινοποίηση Απρίλιος 1, 2010 QuickTime 7.6.6This latest release comes with reliability improvements for iMovie (on Mac OS X), it fixes some H.264 playback issues on multicore (Windows-running) systems, and, most importantly, tackles no less than 16 vulnerabilities which could lead to crashes and/or arbitrary code execution. Link to comment Share on other sites More sharing options...
