hayabusa Φεβρουάριος 8, 2010 #621 Κοινοποίηση Φεβρουάριος 8, 2010 Opera 10.50 build 3228Core- Fixed CORE-26715 (Farmville on Facebook freezes Opera)- Fixed CORE-27064 (Horizontal scrollbar visible on multiple sites (neowin.net, huffingtonpost.com...))User Interface- Merged back and forward buttons- Split out Fast Forward and password button to a separate button- Added a pref for the height of the draggable area when integrating the tabs in the chrome- Use a more flexible layout of the pagebar when integrating in the chrome, allowing pagebar tail and floating to go under the close/maximize/minimize buttons when there is space- Minor tweak to geolocation toolbars- Fixed DSK-274391 (Window size corruption when using Show desktop)- Fixed DSK-276712 (Create search icon on menu only appears in opera:config)- Fixed DSK-278500 (Tweaks to the O menu)- Fixed DSK-278881 (Using the Add private tab icon activates content blocker in previous tab)- Fixed DSK-279015 (Internal opera.css stylesheet missing from builds)- Fixed DSK-279018 (Bottom part of characters cut off in address field)- Fixed DSK-279091 (Opera Link crashes)Chrome 5.0.317.2- Do not select a word by right-click on an editable field in a web page.- (Extensions) Adds a new experimental processes module to the extensions API.- Integrated page level language translation.- Added new privacy management tools, under "Options->Under the Hood->Content settings..." which all for better management of images, JavaScript, plugins, and popups. Link to comment Share on other sites More sharing options...
hayabusa Φεβρουάριος 9, 2010 #622 Κοινοποίηση Φεβρουάριος 9, 2010 HWiNFO32 3.40- Added reporting of TRIM command capability (for SSD).- Improved sensor monitoring for Giga-Byte series: H55, 790FXTA.- Improved support of nVidia GT21x series.- Fixed support of several nVidia GPU sensors.- Added monitoring of nVidia GPU temperature for G92, G94, GT200, GT21x.- Added reporting of ATA drive media rotation rate in RPM (if drive supports reporting).- Fixed detection of first DIMM on certain nVidia chipsets.- Improved sensor monitoring for MSI series: Big Bang Trinergy (MS-7580), P55-GD80 (MS-7581), P55-GD65 (MS-7583), P55-CD53 (MS-7586), H57M-ED65 (MS-7587), P55M-GD41/45 (MS-7588).- Improved general handling of sensor monitoring, added possibility to clear stored preferences.- Enhanced reporting of PCIe properties for GPU.- Added preliminary Sandy Bridge support.- Improved sensor monitoring for Biostar series: TPower I55 and X58.- Improved sensor monitoring for MSI series: MS-7032, MS-7046, MS-7100, MS-7185, MS-7204, MS-7236, MS-7250, MS-7260, MS-7267, MS-7327, MS-7350, MS-7369, MS-7373, MS-7376, MS-7388, MS-7501, MS-7577, MS-9130.- Improved sensor monitoring for Gigabyte series: 945P, 945G, 946, G31MX, 965P, 965Q, N650SLI, M55S, M57SLI, M56S, M61P, M61SME, M61VME, M68SM.- Improved sensor monitoring for ECS series: 945P, P55H, X58, RS480, RS482, RS485, A740GM, A785GM, A790GXM.- Improved sensor monitoring for DFI series: CFX3200, RDX200, NF590, NF4, 790FX.- Improved sensor monitoring for Biostar series: N750, TA780, TP35.- Improved sensor monitoring for Foxconn series: 945, 946, 965, 975, P31, G31, G33, P35, X38, G41, Q45, G43, P43, P55, C55, MARS, BlackOps.- Improved sensor monitoring for Foxconn series: CK804, VX800, RS690, RS740, RS780, RX780, RD790, RS880, A79A, N570, C51G, MCP55, MCP61, MCP65, MCP68, MCP72, MCP78, MCP73, MCP7A.- Improved sensor monitoring for Biostar series: NF520, NF560, TA770, TF520, TF560, TF570, TF7025, TF7050, TF7100, TF7150.- Improved sensor monitoring for several Supermicro and ASUS workstation boards using W83793 and W83795 sensors.- Improved sensor monitoring for Intel series: DX58, D5400XS (SkullTrail).- Added identification of nVidia MCP89.- Added support of Fintek F71872F and F75334DG sensors.- Improved sensor monitoring for several EPoX motherboards.- Improved sensor monitoring for EVGA series: E173, E178, E179, E180.- Improved sensor monitoring for Foxconn series: BLOODRAGE, Flaming Blade, Destroyer.- Added preliminary support of AMD Hudson FCH.- Improved sensor monitoring for Supermicro series: C2SBX, X8SII, X8SIL.- Improved sensor monitoring for Albatron series: PX975X.- Improved sensor monitoring for JW series: 780G, 790G.- Improved sensor monitoring for Shuttle series: P35, X38.- Added new AMD Family 10h CPU models.- Fixed reporting of temperatures in Farhenheit in tray. Link to comment Share on other sites More sharing options...
kreach Φεβρουάριος 9, 2010 #623 Κοινοποίηση Φεβρουάριος 9, 2010 Sandboxie version 3.44 ... Released on 3 February 2010 http://www.sandboxie.com/index.php?DownloadSandboxie These are the changes to Sandboxie since version 3.42. * Full support for 64-bit Windows. o Single installation EXE contains both 32-bit and 64-bit editions of Sandboxie. * Improved Disable Forced Programs mode. o Hold Ctrl+Shift while invoking the right-click Run Sandboxed command on a program that is forced, to run the program outside the supervision of Sandboxie. o When Disable Forced Programs is used to start some forced program X outside the supervision of Sandboxie, then any other forced programs started by that program X will also start outside the supervision of Sandboxie. * Improved support for User Account Control (UAC) elevation by sandboxed programs. o No longer requires Sandboxie Control to be running. o Pop-up window displays information about the elevating program. * Fixed incompatibility with Software Restriction Policies (SRP) on Windows 7. * Windows Explorer running under Sandboxie displays current folder in title. * Prevent Mozilla Firefox and Google Chrome browsers from updating in the sandbox. o Message SBIE2191 will be displayed. * Support for installing extensions into Google Chrome. * Support for ICMP (ping) operations by sandboxed programs in Windows Vista and Windows 7. * Improved compatibility with third-party security software: a2 Anti Malware. * Improved compatibility with other third-party software: Macro Express, LinkStash, Bing Toolbar. Για όσους δεν γνωρίζουν το sandboxie ας ρίξουν μια ματιά: εδώ ή στο thread του Jaco Link to comment Share on other sites More sharing options...
pank Φεβρουάριος 10, 2010 #624 Κοινοποίηση Φεβρουάριος 10, 2010 Fraps 3.1.03.1.0 - 8th Feb 2010- Added option to capture videos with framerate locked or unlocked- Fixed startup crash for some Intel i5/i7 configurations under Windows 7 - Minimum recording speed is now 1 fps to allow for time lapse recording- Fixed vista desktop recording not capturing mouse cursor- Fixed sound length for Vista/Win7 recordings- Added large address support to 32-bit codec- Fixed window starting off screen on some multi-monitor systems Link to comment Share on other sites More sharing options...
hayabusa Φεβρουάριος 11, 2010 #625 Κοινοποίηση Φεβρουάριος 11, 2010 BestSync FTP 2010 version 5.0.48 (32bit)BestSync FTP 2010 version 5.0.48 (64bit)- Fast file filtering engine, only designated file types and changed files are transferred;- 128BITS RSA|RC2 encryption to protect your data on FTP server or USB disk;- Opened/locked file copying function to backup using file without stop the application;- Resume transfer file from last breakpoint to sync large file in unstable internet environment;- Flexible scheduler to start task automatically; File change monitoring feature to start synchronization immediately after the files are changed;- Run as windows service without user logon;- Backup old file with compression and encryption feature;- Preview windows to modify hit files and synchronization direction;- Log view to view log record and restore file easily.Updates include:- Added the expand all button to the log view window.- Added the completed size information in the log file.- And other minor improvements.- Implemented the tab page for modifying the setting of task.- Support multiple selection in the log view.- Fixed the problem that the installer may failed to install BestSync. Link to comment Share on other sites More sharing options...
hayabusa Φεβρουάριος 11, 2010 #626 Κοινοποίηση Φεβρουάριος 11, 2010 Network File Monitor version 2.32.15.1Changes include:- Error in command line option NOLOGO fixed.- Moved group position wasn't saved.- Launched module detection improved.- "Run once" didn't work.- [4BB7] error fixed.- Group and task moving in the settings tree wasn't saved.- New Features: VMS FTP support improved.- FIXED: Safe copy problem for One-To-One synchronization type.- FIXED: environment variable list didn't contain all the variables.- FIXED: IIS FTP parsing error.- FIXED: error new FTP task testing. Link to comment Share on other sites More sharing options...
hayabusa Φεβρουάριος 12, 2010 #627 Κοινοποίηση Φεβρουάριος 12, 2010 OpenOffice version 3.2 - File locking implementation changes.- Allow usage of default master password.- Remove unused 3D options- Make slideshow media controllable via effects- Sorting has been improved: - Sorting preserves the original order of entries with equal sort keys. - If there are no previous sort settings, the sort dialog defaults to the column of the cursor position. The toolbar buttons always use the cursor position. - The toolbar buttons use the same logic as the sort dialog to determine if a range has column headers.- INDIRECT now supports the '!' sheet separator- Rename sheet with double-click- Repeat vectors if used in 2D array- Formula syntax in tip help- Zoom slider in Calc status bar- Scaling factor in toolbar for page preview- Scroll wheel switches pages in page preview- BETADIST with optional parameter for cumulative/density- Storage of data pulled in by external references changed- Added EUROCONVERT function- New GAMMA, CHISQDIST, CHISQINV, changed GAMMADIST.- DATEVALUE and TIMEVALUE now return date or time only- Base parameter of LOG now optional- Cumulative parameter of POISSON now optional- New "Context" mode for numerals setting- Introduction of an overline font effect- Accept/Reject Change in context menu- changes to format menu- Introduction of an outline level attribute for paragraphs and paragraph styles- More hyperlink related entries in the context menu- search inside notes- Serbian Cyrillic Numbering Provider- Inconsistent terms: Autoformat - Autocorrect- New look for selection: transparency- "Navigator" added to the view menu- Grammar checking- reply to existing notes- changes to Tools-AutoCorrect- Footnotes... renamed to Footnotes/Endnotes...- bi-directional writing for chart elements- image controls: support for document-embedded images- Relative path for file based databases- SQL syntax highlighting- New short cuts for Sun Report Builder- views opened for editing are automatically put into "Run SQL Directly" mode- "Empty string is NULL" behavior refined- image controls: can be bound to text database columns, interpreting their content as relative link to the image- form controls: new property "Input Required"- image controls: scaling the image by keeping the ratio- check box grid columns have the "Tristate" property- Let OOo use own file locking mechanics to lock alien formats as well. Link to comment Share on other sites More sharing options...
hayabusa Φεβρουάριος 15, 2010 #628 Κοινοποίηση Φεβρουάριος 15, 2010 VirtualBox 3.1.4- SMP stability fixes- Fixed guru meditation in certain rare cases- Activate NXE for PAE enabled guests (VT-x and AMD-V on 32 bits hosts only)- Added workaround for broken BIOSes that make VirtualBox think AMD-V is in use- Fixed rare host reboot when restoring a saved state- Fixed incompatibility with 2.6.32 Linux kernels- Turn on nested paging by default for new VMs (if available; VT-x and AMD-V only)- Turn on VPID by default for new VMs (if available; VT-x only)- Perform strict CPUID compatibility checks when teleporting; to get the old behavior set "VBoxInternal/CPUM/StrictCpuIdChecks" to 0- Fixed VM crash with certain 16 bits Windows applications Link to comment Share on other sites More sharing options...
2cpu Φεβρουάριος 15, 2010 #629 Κοινοποίηση Φεβρουάριος 15, 2010 FRAPS 3.1.13.1.1 - 11th Feb 2010- Fixed detection of loading screens when recording with unlocked framerate- Added product information to installer Link to comment Share on other sites More sharing options...
hayabusa Φεβρουάριος 16, 2010 #630 Κοινοποίηση Φεβρουάριος 16, 2010 WinRAR version 3.92- WinRAR 3.91 reported the incorrect "Unexpected end of archive" error, when opening an empty ZIP archive created with "New WinRAR ZIP archive" context menu command.- If "Delete archive" option was enabled when unpacking several ZIP archives and if one of archives was damaged, WinRAR did not delete archives after the damaged one, even if they were unpacked successfully.- If file matched two different masks in RarFiles.lst, WinRAR could select the last match. Normally, if neither of masks is a subset of another, the first match must be chosen. Link to comment Share on other sites More sharing options...
hayabusa Φεβρουάριος 19, 2010 #631 Κοινοποίηση Φεβρουάριος 19, 2010 Pidgin 2.6.6libpurple- Fix 'make check' on OS X.- Fix a quirk in purple_markup_html_to_xhtml that caused some messages to be improperly converted to XHTML.- Set "controlling-mode" correctly when initializing a media session. Fixes receiving voice calls from Psi.- When looking up DNS records, use the type of record returned by the server (instead of the type we asked for) to determine how to process the record.- Fix an issue with parsing XML attributes that contain "<br>".General- Correctly disable all missing dependencies when using the --disable-missing-dependencies option.Gadu-Gadu- Fix display of avatars after a server-side change.AIM- Allow setting and displaying icons between 1x1 and 100x100 pixels. Previously only icons between 48x48 and 50x50 were allowed.MSN- Fix CVE-2010-0277, a possible remote crash when parsing an incoming SLP message.- File transfer requests will no longer cause a crash if you delete the file before the other side accepts.- Received files will no longer hold an extra lock after completion, meaning they can be moved or deleted without complaints from your OS.- Buddies who sign in from a second location will no longer cause an unnecessary chat window to open.- Support setting an animated GIF as a buddy icon.- Numerous code cleanups and memory savings.MySpace- Fix a leak and crash when retrieving buddy icons.XMPP- Less likely to send messages to a contact's idle/inactive resource.- Added support for the SCRAM-SHA-1 SASL mechanism. This is only available when built without Cyrus SASL support.- When getting info on a domain-only (server) JID, show uptime (when given by the result of the "last query") and don't show status as offline.- Fix getting info on your own JID.- Wrap XHTML messages in, as described in XEP-0071, for compatibility with some clients.- Don't do an SRV lookup for a STUN server associated with the account if one is already set globally in prefs.- Don't send custom smileys larger than the recommended maximum object size specified in the BoB XEP. This prevents a client from being disconnected by servers that dislike overly-large stanzas.- Fix receiving messages without markup over an Openfire BOSH connection (forcibly put the stanzas in the jabber:client namespace).- The default value for the file transfer proxies is automatically updated when an account connects, if it is still the old (broken) default (from 'proxy.jabber.org' to 'proxy.eu.jabber.org').- Fix an issue where libpurple created duplicate buddies if the roster contains a buddy in two groups that differ only by case (e.g. "XMPP" and "xmpp") (or not at all).Yahoo- Don't send and tags.- Support PingBox. PingBoxes will appear as pbx/PingBoxName.Pidgin- Fix CVE-2010-0423, a denial of service attack due to the parsing of large numbers of smileys.- Correctly size conversation and status box entries when the interior-focus style property is diabled.- Correctly handle a multiline text field being required in a request form.- Search friends by email-addresses in the buddy list.- Allow dropping an image on Custom Smiley window to add a new one.- Prompt for confirmation when clearing a whiteboard (doodle) session.- Use the "hand" cursor when hovering over usernames in chat history to indicate that the username is an actionable item.- Double-clicking usernames in chat history will open an IM with that user.- Put an icon on the "Filter" button in the debug window.- Don't treat "/messages/like/this " as commands.- Explicitly mark user interaction when inserting smilies from the toolbar so "Undo" correctly removes these smilies.- Clicking "New" or "Saved" in the status selector menu while typing a status message no longer keeps the status entry area stuck in "typing" mode forever.- Show tooltips for ellipsized conversation tabs. On older systems, tooltips will show for all tabs.- The File Transfers and Debug Window windows are no longer created as dialogs.- Smiley themes with Windows line endings no longer cause theme descriptions not to be displayed in the theme selector.Finch- Fix CVE-2010-0420, a possible remote crash when handling chat room buddy names.- Rebindable 'move-first' and 'move-last' actions for tree widgets. So it is possible to jump to the first or last entry in the buddy list (and other such lists) by pressing home or end key (defaults) respectively. Link to comment Share on other sites More sharing options...
MOS Φεβρουάριος 21, 2010 #632 Κοινοποίηση Φεβρουάριος 21, 2010 Firefox 3.6Είναι ιδεα μου η τρώει περισσοτερη RAM απο οτι συνηθως ??? Link to comment Share on other sites More sharing options...
hayabusa Φεβρουάριος 22, 2010 #633 Κοινοποίηση Φεβρουάριος 22, 2010 νομίζω πως ναι...και επίσης έχω παρατήρησει ότι την μνήμη που δεσμέυει όταν έχει πολλές καρτέλες ανοιχτες, δεν την αποδεσμέυει παρά σε ελάχιστο βαθμό όταν τις κλείσεις. Link to comment Share on other sites More sharing options...
papatsonis Φεβρουάριος 22, 2010 #634 Κοινοποίηση Φεβρουάριος 22, 2010 νομίζω πως ναι...και επίσης έχω παρατήρησει ότι την μνήμη που δεσμέυει όταν έχει πολλές καρτέλες ανοιχτες, δεν την αποδεσμέυει παρά σε ελάχιστο βαθμό όταν τις κλείσεις.αυτο το προβλημα το εχει απο εποχης FF 1.0.. και ακομη να το λυσουν, προφανως κραταει καποια "cache" στη ram για πιο γρηγορο ξανα-ανοιγμα τους (??), την οποια θα χαιρομουν πολυ αν μου εδειχνε καποιος απο που να την απενεργοποιησω.. Link to comment Share on other sites More sharing options...
hayabusa Φεβρουάριος 22, 2010 #635 Κοινοποίηση Φεβρουάριος 22, 2010 Disk Management 1.1New FeaturesWe re-architected the entire Add-In to use a Windows Service to do all the back-end heavy lifting. That’s given us the flexibility to add a bunch of functionality that you’ve all been asking for.Everyone loves bullet points, so here are our new shinies in no particular order:- Significantly improved user interface (including a collapsible pane for the wireframe if you don’t use it)- Significantly improved performance, especially on multi-core CPUs- Charts for disk space statistics- Charts for disk space utilisation over time- Disk statistics logging to a file- More disk details, including the NTFS mount point for each disk- Real counting of the actual backup database size (for all you crazy kids with backup duplication enabled)- A detailed help fileThe new UI is something we’re really proud of. No more pop-up windows to see detailed information about your disks, it’s all there in one display. Link to comment Share on other sites More sharing options...
MOS Φεβρουάριος 22, 2010 #636 Κοινοποίηση Φεβρουάριος 22, 2010 Ρεσεις μιλαμε μεχρι 700MB με 7 καρτελες 100MB η καρτελα :dots: Link to comment Share on other sites More sharing options...
2cpu Φεβρουάριος 23, 2010 #637 Κοινοποίηση Φεβρουάριος 23, 2010 AnyDVD6.6.2.3 2010 02 22- New (HD DVD & Blu-ray): Faster response time when changing settings during scan in progress- New (Blu-ray): Updated decryption keys- New (Blu-ray): Added support for new BD+ protections- New (Blu-ray): Added support for new structural protection- New (Blu-ray): Added workaround for District 9 (US) playback problem with PowerDVD- New (DVD): Added support for new protections- New (DVD): CSS archive now stores layer break VTS key for increased performance- New (DVD): CSS keys are always stored, regardless of the "Use CSS archive" setting- New (DVD): Added workaround to AnyDVD ripper for "Angel & Demons (rental)", Japan- New: Added more info to logfile- New: Information window while AnyDVD is scanning discs- New: Option to enable / disable this window- New: Workaround for problems with some VMs and certain drives- New: Create logfiles for empty drives- New: Better handling of "files in use" during installation- Change (DVD): CSS archive is enabled by default- Change: Replaced AnyDVD "Safe Mode" with "Aggressive I/O Mode".- Note: Aggressive I/O mode is disabled by default. It might be required with some 3rd party software. Please report which programs require it. Thank you!- New: Added warning message, if applications requiring "Aggressive I/O Mode" are installed- New: Added option to disable the "Aggressive I/O Mode" warning message- Fix (DVD): AI scanner removed non-existant copy protection from "Tomorrow Never Dies", US- Fix (DVD): AI scanner could mess up chapters with some discs, e.g. "Odyssey 5", UK- Fix: Driver verifier problem with ElbyCDIO.sys- Fix: Driver verifier problem with AnyDVD.sys- Fix: Various potential crashes- Fix: Changing a disc could be missed while AnyDVD is scanning a disc in another drive- Fix: Disabling power saving didn't always work- Some minor fixes and improvements- Updated languages Link to comment Share on other sites More sharing options...
hayabusa Φεβρουάριος 23, 2010 #638 Κοινοποίηση Φεβρουάριος 23, 2010 Notepad++ version 5.6.7Changes include:- Fix "Find in files" crash bug.- Focus (switch to) the dirty document while asking to save unsaved document when user close Notepad++.- Fix the bug while giving command C:\NppDir>notepad++ (w/o quote), npp try to open file "notepad++".- Enlarge regconition of clickable link from "http://" to any URI.- Fix the bug while changing the language list in Style Configurator, the "Save and close" button is enabled. Link to comment Share on other sites More sharing options...
hayabusa Φεβρουάριος 23, 2010 #639 Κοινοποίηση Φεβρουάριος 23, 2010 FileZilla 3.3.2 Changes include:- *nix: Add support for forward and backward mouse buttons- Speed limits can be re-enabled on SFTP connections- Changed settings did not come into effect unless FileZilla was restarted- Small performance improvements- Spelling fixes- Speed limits can be quickly set using the menu and a new indicator in the status bar- Display number of bytes transferred and duration of transfer in log- MSW: React to back button of mouse in file lists- Updated blukis icon set- Refactored large parts of the toolbar and menubar code- A race condition in the socket code could lead to crashes- Fix connecting to addresses longer than 15 characters if using SOCKS proxy- Get add to queue in local directory tree context menu working again- Do not open request dialogs if user is holding a mouse button- Forward all Ctrl+Tab key events to tab bar- Do not report SFTP exitcodes that do not originate from the server Link to comment Share on other sites More sharing options...
hayabusa Φεβρουάριος 24, 2010 #640 Κοινοποίηση Φεβρουάριος 24, 2010 Moo0 SystemMonitor Software version 1.54Changes include:- Added Polish support.- It can now fix the corruption of Performance Counter Objects broken by Windows Updator.- Supported more number of Network cards.- Improved the Installer.- Added Chinese (Simplified) support to the installer.- Added Dutch support to the installer.- Added Turkish support to the installer. Link to comment Share on other sites More sharing options...
