Καινούργιες εκδόσεις (Haya)
PGM
CPU-Z 1.53
  • New version in chinese language.
  • Intel Core i7 930 & 950, Core i7 980X "Gulftown", Xeon W3565.
  • Intel Mobile Core i7/i5/i3 "Arrendale" (LV and ULV).
  • Intel "Clarkdale" platform improved support.
  • AMD Phenom FX-5000, Athlon II X2/X3/X4, Athlon L110.
  • AMD AM3 socket detection improved.
  • VIA VX800 and VX855 chipsets support.
  • ATI Radeon 2100 and Radeon X1250 support.
  • DirectX 11 detection fix.
  • Hardware virtualization support now reported as instructions set.
  • New HTML report with less information.
Link to comment
Share on other sites
  • Replies 2,4k
ESET Smart Security, NOD32 Antivirus 4.2 betas
- Windows AIK 2.0 for Windows 7
- Preliminary support for NT 4.0 (ESET NOD32 Antivirus only)
- Support for Thunderbird 3 (ESET Smart Security only)
- Added support for Dynamic Disks (ESET NOD32 Antivirus only)
- Added support for Opera 10 (ESET Smart Security only)
- Trusted network authentication (ESET Smart Security only)
- Firewall profiles (ESET Smart Security only)
- Support for centralize quarantine management (with ESET Remote Administrator 4 Beta)
- Support for firewall rule merge wizard (ESET Smart Security with ESET Remote Administrator 4 Beta)
- Added ability to include external programs on ISO images (ESET NOD32 Antivirus only)
Opera 10.5 pre-alpha build
- Presto 2.5 rendering engine which contains a huge numbers of improvements, support for CSS3 transitions and transforms, and more HTML5 features.
- Carakan - new JavaScript engine that's more than 7x faster in SunSpider than Opera 10.10 with Futhark on Windows.
- Vega graphics library - currently software based but can be hardware accelerated.
- 'Private tab' and 'Private window' - You can open a new Private tab or Private window that doesn't keep any browsing data (cookies and such) once closed.
- Better platform integration
- Non-modal dialogs - Dialog boxes are now non-modal and are displayed as a page overlay. This allows you to switch tabs or windows while the dialog is still displayed.
- Address field and Search field improvements - Both fields have been upgraded in looks and functionality. They can now remember searches, support removing items from history and show results in a better layout.
Link to comment
BitComet updated to version 1.17
- GUI Improved: support download Magnet URI when click "Open Torrent from URL" from file menu
- GUI Improved: change "copy BC link" in context menu of task list, Torrent History and Torrent Exchange to "Copy Magnet URI"
- GUI Improved: new auto-shutdown condition: shutdown at specified time
- GUI Improved: display information of every connection to the same server in connection tab of HTTP task
- GUI Improved: add context menu to BT task file list header, to select columns to display
- GUI Improved: display the preview buttons of files in BT task file list according to each file's downloading progress
- GUI Improved: support mouse wheel in task summary
- GUI Improved: remove "Task Content" tab
- GUI Improved: highlight the row on which mouse hovers in file list, peer list and tracker list
- GUI Improved: rename "Super-Seeding" to "Initial-Seeding" in BT task properties dialog
- GUI Improved: display local-language name of every language in Tools menu, besides theirs English name
- GUI Improved: remove es_ar language due to the limit in launchpad.net, and add Uighur
- GUI Improved: rename Torrent Archive under Torrent Share to Torrent Share under Torrent Exchange, and add Torrent History in addition
- GUI Improved: display introduction page when click Torrent Exchange in left fav tree
- GUI Improved: new option in BT task page of options dialog: add to Torrent History when open .torrent file
- GUI Improved: new option in BT task page of options dialog: list of BitTorrent clients allowed connecting to
- GUI Improved: new option in Integration page of options dialog: associate with Magnet URI
- GUI Improved: option to restart program immediately when send crash report
- GUI Improved: when opening video file, use the player program configured in advanced option
- GUI Bugfix: fix many spell mistakes in GUI (thanks to greywizard)
- GUI Bugfix: cannot input Web Seed address longer than one row of the input edit-box
- Core Improve: support BitTorrent Extension Protocol of metadata exchange, compatible with BitTorrent mainline
- Core Improve: support BitTorrent Extension Protocol of report DHT port, compatible with BitTorrent mainline
- Core Bugfix: display file failed to create in task log when start new BT task in certain situation
- Core Bugfix: can not open torrent file containing multi-files, in which the name field ends with space
Link to comment
HD tune pro 4.00
HD Tune is a hard disk utility with many functions. It can be used to measure the drive's performance, scan for errors, check the health status (S.M.A.R.T.), securely erase all data and much more
Changes:
Health (S.M.A.R.T) and temperature display support for external drives
Support for drives larger than 2 TB
Supports up to 32 drives
Advanced S.M.A.R.T log functions
Added short stroke testing
Extra tests: quick read/write tests
Added cache test
More information is shown
Benchmark tests can be run seperately
Added option to perform the transfer rate test on the entire surface
New command line parameters
Link to comment
CPU-Z 1.53.1
  • Fix validation bug on AMD Phenom processors (1.53.1).
  • Preliminary support of Intel Pinetrail platform (1.53.1).
  • Intel Mobile Core i7/i5/i3 "Arrandale" (LV and ULV).
Link to comment
CoreFTP version 2.1 Client/Server
- XCRC fixes for large files
- Cert selection option added (adv props ssl/tls)
- Cert request for Windows SSL cert manage options
- File verson added to .exe/install.
- Updated help file (.chm)
- SFTP piplining options (adv -> ssh)
- Properties in queue check/crash fixed
- Additional checks/handling on queue crashes
- SSL cipher updates
Link to comment
Firefox 3.6 RC2
- Improved JavaScript performance, overall browser responsiveness and startup time.
- Support for new CSS, DOM and HTML5 web technologies.
- Support for WOFF (Web Open Font Format).
- The ability to change the browser's appearance with a single click, with built in support for Personas.
- Alerts for out of date plugins.
- Open, native video can now be displayed full screen, and supports poster frames.
- Improved automatic form fill provides better options from your form history.
- The ability to run scripts asynchronously to speed up page load times.
Link to comment
Trillian 4.1
HotKeyz version 2.7.8.0
- Fixed memory leak.
- Fixed access violation on exit.
- Added an active window command to minimize all other windows except the active one (top most). Specify additional window titles not to be minimized.
- When launching an external command i.e. an exe file like notepad.exe, two options are now available on the Options Tab: start as a new instance or open the previous instance. This is handy when you only want one instance of an application to be launched when pressing a hotkey.
- When deleting a macro play command, a confirmation dialog will be displayed asking if you want to delete the macro file as well.
- Fixed "List index out of bounds (10)" error when duplicating a command in the Multiple Command editor.
- The Multi or Pick List commands will not be visible for Multiple or Pick List Commands as you cannot have a multiple command within a multiple command.
- When you create a new hotkey and have selected a Category, the category will remain as is when you select a command. But if you select the command first the category will change to the built-in category.
- When creating a new macro the Playback Fast will be checked by default.
- Fixed macro path error.
- Fixed macro playback tray icon. Will now change to blue to indicate macro playback.
- Added Google Chrome to Internet defaults.
Link to comment
Chrome 4.0.302.2/3
Windows
- Fix for issue 32648 - Render crash @ NormalizeText.
Mac
- Various improvements to the bookmark manager.
- Fix mis-sized download shelf close button. (Issue: 31785)
- Enable the task manager. (Issue: 13156)
- Support pinch to zoom on the Mac. (Issue: 16305)
- Implements context menus for Page and Browser Actions. (Issue: 30655)
- Eliminate Helper zombies. (Issue: 32001)
- Quake Live Plugin will now load. (Issue: 24788)
- Fix issues with browser action popups. (Issues: 32161, 31097, 32162)
- Support plugin cursors, and fix cursor flicker with fullscreen plugins. (Issue: 20717)
- Improve scroll performance on some sites.
- Controls in QuickTime content now work. (Issue: 24952)
- Double-clicking a plugin will no longer select it. (Issue: 31358)
Linux
- Theme the NTP with GTK+ colors when matching GTK. (Issue: 29948)
- Fix to way we identify the active window. (Issue: 31971)
Opera 10.50
General
- Lots of crash fixes
- Improved address bar with dropdown button
- Fixed: regression: redraw issues while scrolling textareas and dropdowns
- Fixed: Clicking a link in an external app doesn't open a new tab anymore
Core
- Improved support for webfonts
- CORE-15970 New protocol layer for scope
- HTTPS fixes
- Memory leak fixes
- Google Reader now works
- Text in transformed content displayed properly (windows)
Link to comment
PeaZip 2.9.1
Full support: 7Z, 7Z-sfx, ARC/WRC, BZ2/TBZ2, Custom (user defined), GZ/TGZ, PAQ/LPAQ, PEA, QUAD/BALZ, split, TAR, UPX, ZIP. Open, browse, extract, test: ACE, ARJ, CAB, CHM, COMPOUND (MSI, DOC, XLS, PPT), CPIO, ISO, Java (JAR, EAR, WAR), Linux (DEB, PET/PUP, RPM, SLP), LHA/LZH, LZMA, Mac (DMG/HFS), NSIS, Open Office files, PAK/PK3/PK4, RAR, SMZIP, U3P, UDF, WIM, XAR, XPI, Z/TZ (79 file extension supported).
Other features: robust file copy, search functions, split/join files, secure file deletion, compare/checksum/hash files, system benchmark, export job definition and archive layout, generate random passwords/keyfiles, two factor authentication, strong encryption (AES256).
Changes include:
- (Windows) Added reference SendTo items in PeaZip's path to simplify customizing installation, to share those items between users, and to use this type of system integration for PeaZip Portable
- (Windows) New default icon library with icons from Seven theme
- (Windows 7) Cascaded context menu with icons, since in Windows 7 and later cascading menu implementation is supported through registry settings, which is now recommended over COM methods
- Display sizes with suffixes (and a decimal) to improve readability
- Improved startup time searching unc name only for remote units
- Fixed some possible crash conditions
- As well as various other updates and fixes
Link to comment
CCleaner v2.28.1091
  • Added support for custom locations for applications.
    e.g. CustomLocation1=FIREFOX|C:\MyFirefox\Profile
  • Improved detection and cleaning algorithm for new releases of Mozilla based browsers.
  • Added news tasks to W7 jumplist.
  • Added new command line parameters: /CLEANER, /REGISTRY, /TOOLS and /OPTIONS.
  • Improved MUI cache cleaning for Vista and Windows 7.
  • Added drive information to Wipe Free space status.
  • Improved Wipe MFT free space routines.
  • Improved W7 toolbar feedback.
  • Improved several core processes and routines.
  • Improved file search algorithm when recursing.
  • Added support for cleaning Paint Shop Pro 12.
  • Improved support for IZarc and Axialis IconWorkshop.
  • Minor GUI tweaks.
Link to comment
Miranda IM 0.8.13
Enhancements:
- ICQ: Improved AIM capabilities detection
- ICQ: Added ICQ 7 client detection
Bugfixes:
- Incompatible contact list plugins could load on startup
- ICQ: Fixed possible memory leak
- Jabber: Minor translation fixes
- MSN: Fixed issue with SOAP requests
- MSN: Fixed issue denying users
- Yahoo: Fixed nudges
- Yahoo: Support cancelling file transfer in progress
Link to comment
VLC media player v1.0.5
Decoders
- SubRip extra styles improvements
- Fix potential crashes in SSA and svg decoders
Mac OS X Interface
- Improved support for the 2009 Apple Remote
Windows port
- Use of gcc 4.4.2 to compile instead of gcc 4.2.
Translations
- Portuguese Brazilian, Lithunanian, Romanian, Ukranian, Japanese, Bengali, Walloon, Galician, Danish, Khmer, Polish, Slovenian, Vietnamese, Finnish, Russian, Slovak translation updates
- New Malayalam, Macedoninan, Nynorsk translations
Link to comment
Chrome 5.0.307.1
Windows
- Use default downloads directory on Vista and Windows 7 (except where it is the desktop)
- Start work on Content Settings window and sub-dialogs
Mac
- Improved plugin stability.
- Cocoa NPAPI plugins will now get NPCocoaEventMouseDragged and NPCocoaEventFlagsChanged events
- Fix crash that sometimes happened when dragging tabs
- Fix %cpu in task manager.
- Give the cookies manager a search field.
- Make copying of big images more robust.
- Improve task manager resizing behavior.
Link to comment
