Fireman1234 Αύγουστος 27, 2009 #581 Κοινοποίηση Αύγουστος 27, 2009 CCleaner 2.23.993 Change Log: - Added Taskbar Jump List cleaning for Windows 7. - Added history cleaning support for Opera 10. - Added icons to Cookie selection to show browser. - Improved scrolling in new results window. - Improved Avira Anti-virus cleaning. - Improved multiselect in listviews. - Improved 64-bit support when including/excluding files. - Improved 64-bit issue detection in Registry screen. - Updated internal icons. - Added language support for Armenian. - Fixed language bugs with new results window. - Fixed bug in Recycle Bin cleaning. - Fixed minor bug with help files in Registry Cleaner. - Fixed bug when deleting an application in Uninstall Tool. - Fixed bug when enabling/disabling in Startup Tool. - Minor GUI improvements. Link to comment Share on other sites More sharing options...
hayabusa Αύγουστος 29, 2009 #582 Κοινοποίηση Αύγουστος 29, 2009 PeaZip version 2.7 beta Full support: 7Z, 7Z-sfx, ARC/WRC, BZ2/TBZ2, Custom (user defined), GZ/TGZ, PAQ/LPAQ, PEA, QUAD/BALZ, split, TAR, UPX, ZIP. Open, browse, extract, test: ACE, ARJ, CAB, CHM, COMPOUND (MSI, DOC, XLS, PPT), CPIO, ISO, Java (JAR, EAR, WAR), Linux (DEB, PET/PUP, RPM, SLP), LHA/LZH, LZMA, Mac (DMG/HFS), NSIS, Open Office files, PAK/PK3/PK4, RAR, SMZIP, U3P, UDF, WIM, XAR, XPI, Z/TZ (79 file extension supported).Other features: robust file copy, search functions, split/join files, secure file deletion, compare/checksum/hash files, system benchmark, export job definition and archive layout, generate random passwords/keyfiles, two factor authentication, strong encryption (AES256).Changes include:File browser:- It is now possible to force refresh inside archives- The password / keyfile can now be set once, for being used in file browser, archive creation (setting - Password triggers use of encryption) and archive extraction, like in WinRar; the locker icon reports if the password is set- The advanced inclusion and exclusion filters (7z backend) can now be set once (in a separate form) for archive browsing, extraction and creation- Clipboard is now displayed in a panel at the bottom of file browser, like history and bookmarksArchive creation interface:- New task oriented GUI for compression, adding / dropping files and folders to archive uses the archive creation interface (like in WinRar, where adding to archive raises the archive creation dialog)- Can optionally archive each input item to separate archives- Can chose output path with a powerful navigator (like in former "extract to" popup menu): system's paths, - Bookmarked folders, recent folders- Supports use of the advanced inclusion and exclusion filters (7z and FreeArc backend)Archive extraction interface:- New task oriented GUI for extraction- The advanced inclusion and exclusion filters (7z and FreeArc backend) are supported also for multiple archives at once Link to comment Share on other sites More sharing options...
ea6gka Σεπτέμβριος 2, 2009 #583 Κοινοποίηση Σεπτέμβριος 2, 2009 http://mpc-hc.sourceforge.net/download-media-player-classic-hc.htmlv1.3.1249.0 - 26 august 2009======================NEW : Support for Flac audio streamsNEW : Support for Dolby Digital+ (Eac3) and Dolby true HD (MLP)NEW : Nellymoser audio decoderNEW : Belarusian, Brazilian and Sweedish translationNEW : New shader "Sharpen Complex 2" (required hardware compatible with pixel shader 2.A)NEW : Support for madVR video renderer (http://madshi.net/madVR.zip)NEW : Additional information on video using MediaInfo (DLL can be download from http://mediainfo.sourceforge.net and placed in mpc-hc directory)NEW : Internal DXVA decoder support for H264 with Intel G45 (thanks for people who help me at Intel Corp.)CHANGED: Add support of interlaced flags in software mode for MPCVideoDecoder filterCHANGED: D3DFullScreen mode now takes into account the monitor to full-screen mode in options, if monitor is not specified on the command line.CHANGED: Auto-hide playlist on fullscreen(feature request #2219561)CHANGED: Detours library updated to v2.1CHANGED: Support for AC3 in MP4 splitterCHANGED: Support for EAc3 in Matroska splitterCHANGED: Hotkeys added to support more remote control keysCHANGED: Support for Theora in Matroska internal splitterCHANGED: LibVorbis updated to v1.2.3CHANGED: LibOgg updated to v1.1.4CHANGED: Improved streaming performancesCHANGED: Prevent display or computer to sleep during playbackCHANGED: Faad library updated to rev 2.2.7CHANGED: LibPNG updated to release 1.2.38 (fix security bug)CHANGED: Playlist file is now saved in mpc folder (patch # 2671496)CHANGED: frame by frame modify to support step frame back functionality (except for VMR9)CHANGED: support for AC3 in MP4 files created by Nero DigitalCHANGED: EVR custom and VMR9 renderless revamped (Beliyaal), better synchronisation, remove tearing in windowed mode, support for dialog box in DirectX exclusive mode, ...FIXED : Support for Theora stream in Ogg internal splitterFIXED : Save thumbnails crash in x64FIXED : Bugs on presentation graphics (missing subtitles, better synchronization)FIXED : Audio change on M2TS files reset the selected subtitleFIXED : Switch to "Minimal view" reset main menu language to EnglishFIXED : Bug in Mpeg splitter for VC1FIXED : Maximum texture resolution to "Desktop" not working with Haali renderer (Bug #2456735)FIXED : Better synchronization with EVR custom to improve playback smoothnessFIXED : 24 bits LPCM not properly playFIXED : Possible deadlock with ReclockFIXED : Support of framestep backward, even if the codec didn't support it natively (bug #2600542)FIXED : DXVA decoder support multiple graphics cards (PCI vendor id detection on the fly)FIXED : Incorrect aspect ratio for some H264 files with DXVA1 decoder (extended SAR)FIXED : H264 files with 16 reference frames freeze during playback (bug #2795785 and #2784256)FIXED : AVI with H264 not decoded properly (bug #2794854)FIXED : Revamped DXVA h264 decoder based on new insights, fixing black screen, macroblock, support for AVI, ...FIXED : Incorrect playback for padded DTSFIXED : Hang when moving player between monitors Link to comment Share on other sites More sharing options...
winters Σεπτέμβριος 4, 2009 #584 Κοινοποίηση Σεπτέμβριος 4, 2009 Opera 10: Fast, powerful, efficient and officialhttp://www.opera.com/browser/ Link to comment Share on other sites More sharing options...
Tzimmys Σεπτέμβριος 6, 2009 #585 Κοινοποίηση Σεπτέμβριος 6, 2009 RivaTuner 2.24c (23/08/2009) Προέκδοση που έβγαλε ο Unwinder για το MSI oc event του Πεκίνο. Ουσιαστικές διαφορές δε παίζουν, αλλά παρέχει υποστήριξη στους πιο νέους drivers. Επίσης όπως λέει, η 2.25 λογικά θα κυκλοφορίσει πριν το '10.When 2.25 will be released. Link to comment Share on other sites More sharing options...
hayabusa Σεπτέμβριος 14, 2009 #586 Κοινοποίηση Σεπτέμβριος 14, 2009 Chrome 3.0.195.20 beta Link to comment Share on other sites More sharing options...
Fireman1234 Σεπτέμβριος 15, 2009 #587 Κοινοποίηση Σεπτέμβριος 15, 2009 Mozilla Firefox 3.5.3Firefox 3.5.3 fixes the following issues:Several security issues.Fixed several stability issues. Link to comment Share on other sites More sharing options...
Vamire Σεπτέμβριος 17, 2009 #588 Κοινοποίηση Σεπτέμβριος 17, 2009 quickplay Get instant access to the stuff you care about most with shortcuts to favorites, recently downloaded or played music, videos, and more. smart dj From any artist, album, or song, Smart DJ will generate a related playlist from the music on your computer and new music from Zune Marketplace. mini mode Putting the Zune software into mini mode while listening to music allows you to use your other programs while continuing to see what's playing. mixview Launch into Mixview from any artist or album and discover a mosaic of connections to other artists, albums, and fans. Επισης βάλανε και με το που κάνεις Μινιμίζε να μπαίνει στην μπάρα οπως και το Windows media player πολυ καλο παιδιά. A βαλανε και full screen mode νεα θέματα xbox υπηρεσία και φτιάξανε και αλλο το social και βάλανε περισσότερα θέματα μπράβο στην ms:mobile1: Download από δώ http://www.zune.net/en-us/products/software/default.htm Link to comment Share on other sites More sharing options...
Billys Σεπτέμβριος 22, 2009 #589 Κοινοποίηση Σεπτέμβριος 22, 2009 Memtest v 4.00http://www.memtest.org/#downiso Link to comment Share on other sites More sharing options...
pank Σεπτέμβριος 26, 2009 #590 Κοινοποίηση Σεπτέμβριος 26, 2009 Καινούρια έκδοση gpu-z (v0.35)http://www.techpowerup.com/downloads/1642/TechPowerUp_GPU-Z_v0.3.5.html Link to comment Share on other sites More sharing options...
Fireman1234 Οκτώβριος 5, 2009 #591 Κοινοποίηση Οκτώβριος 5, 2009 CCleaner 2.24.1010Change Log:- Added support for Firefox 3.6.- Added file search history cleaning for Windows 7.- Improved Opera 10 cleaning.- Reduced temp folder cleaning delay to 24 hours.- Several bugs fixed to better support Windows 7.- Added winapp2.ini filter support to detailed results view.- Improved 64-bit support for Registry Cleaner.- Fixed minor bug in Uninstall Tool.- Fixed minor bug in System Restore Tool.- Minor interface bugs fixed.- Minor display bugs fixed. Link to comment Share on other sites More sharing options...
hayabusa Οκτώβριος 5, 2009 #592 Κοινοποίηση Οκτώβριος 5, 2009 FileZilla 3.2.8 finalNew features:- Remember last used search conditions- Display link overlay on icons of links in remote file list- Display of average transfer speed should converge faster to overall average- Simplify default file exists action dialogs- Apply decimal places size formatting option also to total queue size- MSW: Reduce number of needed user interactions in installer if update started from within FileZilla- MSW: Check that there are no running instances of FileZilla before installing- Fixed handling of remote directory names with leading or trailing spaces- *nix: Fix memory leaks in D-Bus session management and power management inhibitor client code- *nix: Fall back to org.gnome.SessionManager if org.freedesktop.PowerManagment does not exit to inhibit idle sleep during transfers- Increase default size of SO_RCVBUF (TCP advertised window) to fix performance issues on high-latency connections- MSW: Fix displaying list of shares on local network resources- MSW: Remote file editing no longer gets confused if two filenames only differ in character case- Fixed dialog line wrapping issues- Ensure width of site manager is large enough to fit all tabs- Better guard against filename columns being moved or hidden- *nix, OS X: Handle filesystems without advisory file locking instead of falsely warning about site manager being opened in a different instance of FileZilla- Changing directories at the same time an upload finishes no longer disturbs synchronized browsing- *nix: Ensure dialogs can be closed using escape key- *nix: Fix height of settings dialog Link to comment Share on other sites More sharing options...
hayabusa Οκτώβριος 8, 2009 #593 Κοινοποίηση Οκτώβριος 8, 2009 SmartFTP version 4.0.1054Changelog- Remote Browser - Command help text/tip is now displayed in status bar- Fixed Windows Vista+ Favourites Browser - Crash when pane is closed- Fixed Shell Tools - Upload through the shell context menu caused the application to hang.- Added option to export public key in OpenSSH format- Fixed Remote Browser - 'Upload->Select Files' crash32bit version64bit version Link to comment Share on other sites More sharing options...
hayabusa Οκτώβριος 14, 2009 #594 Κοινοποίηση Οκτώβριος 14, 2009 File Property Changer 1.43Changes in this version include:- Minor update with various bug fixes and feature enhancements.Notepad++ version 5.5.1Changes include:- The old icon is back!- Set ".txt" extension automatically while saving a document text.- Real characters count is added in status bar.- Fix some memory leaks.- Add "open all" capacity in finder (for find in files).- Replaced nppcm with NppShell (in installer). Link to comment Share on other sites More sharing options...
pank Οκτώβριος 15, 2009 #595 Κοινοποίηση Οκτώβριος 15, 2009 Foxit reader v3.1.2.1013 GPU-Z v0.3.6 Added Infotips, they can be turned off in the system menu Added preliminary support for ATI Radeon HD 5900 (Hemlock), HD 5600 (Cedar), HD 5300 (Redwood) Added full support for HD 5850, HD 5770, HD 5750 GPU-Z no longer crashes on ATI ULPS enabled CrossFire configurations Fillrate Pixel, Fillrate Texel, Memory Bandwidth will now correctly recalculate when clocks change Bus Interface, ATI shader count is now periodically refreshed Added support for HD 5850 voltages Second voltage on HD 5870 correctly named VDDCI ATI clock reading code fixed Fixed default clock reading on HD 5850 Added Mutex to avoid collisions on long I2C operations Added basic detection for a lot of NVIDIA card fakes Added detection for ATI FireGL V7600, M92, RS880 Added detection for NVIDIA GT 130, 9600 GE, Tesla C1060, G 220, GT 220, NVS 3100, GTS 160 M, NVS 160M, NVS 150M, G105M, GT 240M, G105M, G210M, G310M, ION LE Fixed die size and transistor count on G72 M Link to comment Share on other sites More sharing options...
pank Οκτώβριος 17, 2009 #596 Κοινοποίηση Οκτώβριος 17, 2009 AVG Free Anti-virus 9.0Fraps 2.9.99 2.9.99 - 16th Oct 2009- Fixed flickering video capture in Operation Flashpoint: Dragon Rising- Fixed 30-bit color captures in Eve Online- Fixed mouse cursor not being recorded in Conquer Online- Other minor bug fixes Link to comment Share on other sites More sharing options...
Fireman1234 Οκτώβριος 28, 2009 #597 Κοινοποίηση Οκτώβριος 28, 2009 CCleaner v.2.25.1025Change Log:- Improved Windows 7 jump list cleaning.- Improved Windows 7 thumbnail cache cleaning.- Added support for Windows Server 2008 R2.- Improved 64-bit support and performance.- Fixed issue with Windows 7 task scheduler.- Fixed issue with Startup tool, displaying incorrect folder contents.- Added support for AVG Antivirus 9.0.- Added support for ExcludeKey in INI files.- Improved support for wildcards and RECURSE/REMOVESELF.- Fixed minor GUI bugs in non-English versions.- Fixed minor GUI usability issues.- Improved input validation.- Lots of minor bugs fixed. Link to comment Share on other sites More sharing options...
pank Νοέμβριος 8, 2009 #598 Κοινοποίηση Νοέμβριος 8, 2009 Fraps 3.0.0Changelog 3.0.0 - 5th Nov 2009- DirectX 11 support- Compatible with Windows 7 final (RTM) and RC1 versions- Stereoscopic 3D Vision video capture up to 1920x1200 for D3D9 games- Force lossless RGB option to always capture video in pure form- Ability to mix both game sound and external input such as microphone (Vista/Win7 only) Link to comment Share on other sites More sharing options...
hayabusa Νοέμβριος 9, 2009 #599 Κοινοποίηση Νοέμβριος 9, 2009 Chrome 4.0.237.0Lots of work to polish and stabilize the browser and page action APIs:Add badge text color API. Also change color APIs from ARGB to RGBABrowser actions (buttons, popups) are now implemented.Add support for tab-specific state to browser actions. Also, fix the bug where only the first call to setIcon() works.Constrain browser action popups to a min/max size. Also fix some glitches in popup sizing.Use a better signature for the new page actions API (chrome.pageAction.* instead of chrome.pageActions.*).- Remove toolstrips on Linux.- Add chrome.extension.sendRequest() -- a simpler way to do content script messaging.- Add new event chrome.tabs.onStatusChange. This makes the common case of wanting to know when tabs load much easier.- Correctly handle reloading in the task manager- Fix bug where content scripts did not always apply to first page load- Various cleanup for the extension management page- Improve install UI on Mac- Filter out hidden files when loading and packing extensions (Issue 23004)- Copy chrome.extension.getTabContentses() to chrome.extension.getExtensionTabs(). Nobody liked the old name.- Use the puzzle piece as the default extension icon.- Hide the theme install bubble a little earlier. It was overlapping with the install dialog on Linux. Link to comment Share on other sites More sharing options...
pank Νοέμβριος 14, 2009 #600 Κοινοποίηση Νοέμβριος 14, 2009 Real Temp 3.40 Core i7/i5/Xeon Socket 1156 support including accurate turbo mode reporting. New information window for NVIDIA GPUs with improved SLI support. Correct reporting of Super Low Frequency Mode (SLFM) for Core 2 mobile CPUs. Correct reporting of Intel Dynamic Acceleration (IDA) for Core 2 mobile CPUs. Added VID reporting to the main GUI for Core 2 based CPUs. Added a Fahrenheit=1 INI file option. Added the option to view a Task Manager based or a C0% based load meter. Added the ability to toggle C1E state and view the SpeedStep (EIST) state. Improved dual and multi-monitor support including Anchor mode. Includes RealTemp GT, a 6 core version of RealTemp for Gulftown CPUs. Includes i7 Turbo, a high precision multiplier monitoring tool for all Core CPUs. Includes LoadTester, a variable load, single core testing program. Skull=1 or Skull=2 INI option for reading each CPU on a Dual Quad system. Thanks rge, burebista and somebody on TPU for all of your ideas and help. Link to comment Share on other sites More sharing options...
