ChSin7 Απρίλιος 18, 2009 #561 Κοινοποίηση Απρίλιος 18, 2009 EVGA Precision 1.7.0EVGA, once again, sets itself apart from the rest with the EVGA Exclusive Precision Overclocking Utility. This program allows you to fine tune your EVGA graphics card for the maximum performance possible, with Core/Shader/Memory clock tuning, real time monitoring support including in-game, Logitech Keyboard LCD Display support, and compatibility with almost all EVGA graphics cards. Features: Independent or Synchronous control for fan and clock settings in a multi-GPU systemAllows up to 10 profiles, and ability to assign hotkeys to these profiles to allow in-gameAbility to view temperatures in the system trayCore/Shader Clock Link/Unlink capabilityFan Speed manual or auto adjustmentReal-Time on-screen display support for ingame temp, framerate, and clock monitoringLogitech Keyboard LCD Display supportIn-app temp/clockspeed monitoring of GPU'sInformation button shows device, driver, memory size, BIOS Revision and SLI modeAbility to choose different skins, and make your own!Now you can save screenshots from your favorite games!System Requirements:Windows XP32/64 or Vista32/64EVGA 6, 7, 8, 9 or GTX 200 series graphics cardForceware 96.xx or higher drivershttp://www.evga.com/precision/Μπορείτε (όσοι δεν έιναι registered στο EVGA website) να το κατεβάσετε από εδώ : http://www.toomanydownloads.com/index.php?option=com_mtree&task=viewlink&link_id=349&Itemid=54 Link to comment Share on other sites More sharing options...
spc Απρίλιος 29, 2009 #562 Κοινοποίηση Απρίλιος 29, 2009 Vista SP2 RTM: http://www.theregister.co.uk/2009/04/29/vista_sp2/''κυκλοφορεί'' Link to comment Share on other sites More sharing options...
hayabusa Μάϊος 1, 2009 #563 Κοινοποίηση Μάϊος 1, 2009 CCleaner version 2.19.889 software update- Improved support for Google Chrome v2.- Fixed bug with IE8 cookies.- Added support for Flash Cookies.- Added Tool to manage System Restore Files (XP and Vista only).- Added support to remove Opera Recently Typed URLs.- Fixed bug which was displaying wrong Total Bytes removed.- Improved exception handling.- Fixed virtual function bug.- Minor performance improvements. Link to comment Share on other sites More sharing options...
hayabusa Μάϊος 6, 2009 #564 Κοινοποίηση Μάϊος 6, 2009 Trojan Hunter version 5.1 build 972- Fixed scheduling issues. Users are now required to enter their account password to set up scheduled scans, which solves the previous issues with scans not running properly.- Option to turn on or off cab-file scanning. This was previously enabled by default.- Fixed bug causing TrojanHunter Scanner to lock up in certain circumstances.Download Free Trial Link to comment Share on other sites More sharing options...
hayabusa Μάϊος 21, 2009 #565 Κοινοποίηση Μάϊος 21, 2009 Chrome 2.0.181.1- Fixed a common crash when using a French spell-check dictionary.- Fixed a regression where maximizing Chrome turned the tab-background black.- Improved remote desktop (RDP) performance by using the standard dotted rectangle when moving a tab out.- The command line debugger has been replaced by a graphical debugger using the WebKit inspector scripts tab to debug JavaScript running in V8.- It is now possible to set proxy setting from the command-line. See the issue for more information. Full ChangeLog Link to comment Share on other sites More sharing options...
hayabusa Μάϊος 22, 2009 #566 Κοινοποίηση Μάϊος 22, 2009 Pidgin 2.5.6- Fix a crash when removing an account with an unknown protocol ID.- Beta support for SSL connections for AIM and ICQ accounts. To enable, check the "Use SSL" option from the Advanced tab when editing your AIM or ICQ account.- Fix a memory leak in SILC.- Fix some string handling in the SIMPLE prpl, which fixes some buddy name handling and other issues.- Implement support for resolving DNS via the SOCKS4 proxy (SOCKS4a).- Fix retrieval of status messages from users of ICQ 6.x, Miranda, and other libpurple clients.- Change client ID to match ICQ Basic 14.34.3096. This fixes publishing of buddy icons and available messages.- Properly publish status messages for statuses other than Available. ICQ 6.x users can now see these status messages.- Fix receipt of messages from the mobile client Slick.- Fix transfer of buddy icons, custom smileys, and files from the latest Windows Live Messenger 9 official client.- Large (multi-part) messages are now correctly re-combined. Link to comment Share on other sites More sharing options...
hayabusa Ιούνιος 2, 2009 #567 Κοινοποίηση Ιούνιος 2, 2009 7-Zip 9.04 Beta- 7-Zip now can update solid .7z archives.- 7-Zip File Manager now can calculate SHA-256 checksum.- 7-Zip now can unpack ZIP archives encrypted with PKWARE-AES.- A memory leak in LZMA2 code was fixed.- Some bugs were fixed. Link to comment Share on other sites More sharing options...
hayabusa Ιούνιος 8, 2009 #568 Κοινοποίηση Ιούνιος 8, 2009 LAN Viewer version 2.3 - Interface improvements.- Allow select passive or active mode for FTP.- Ability to monitor FTP-resources has been added.- As well as various other fixes and improvements. Link to comment Share on other sites More sharing options...
hayabusa Ιούνιος 26, 2009 #569 Κοινοποίηση Ιούνιος 26, 2009 CCleaner version 2.21.940Changes include:- Added U3 smart drive support. (Separate installer)- Adobe Reader 9.0, Adobe Photoshop CS3,- Adobe Photoshop CS4, Adobe Illustrator CS4,- Nero Burning ROM 9, OpenOffice 3.1,- AVG AntiVirus 8.0, AntiVir Desktop and Vuze.- Added Installed date and size to Uninstall Tool.- Added support for multiple item selection on Start up tool.- Added support for cleaning Windows 2008 IIS log files.- Improved Windows 7 support.- Improved 64-bit Registry cleaning accuracy.- Improved loading of System Restore Tool.- Improved various routines in the uninstaller code.- Fixed Windows 7 Task Scheduler bug.- Fixed "No Disk" bug when using Wipe Free Space.- Fixed Win98 support.- Minor text and translation improvements.- Minor bug fixes. Link to comment Share on other sites More sharing options...
hayabusa Ιούλιος 3, 2009 #570 Κοινοποίηση Ιούλιος 3, 2009 FileZilla version 3.2.6.1- Fix FTP over TLS regressions in provided binaries due to two bugs in GnuTLS causing transfer failures- OS X: Revert regression in wxWidgets in provided binaries leading to a crash on drag & drop- Keep bookmarks menu sorted after adding new bookmarks Link to comment Share on other sites More sharing options...
kreach Ιούλιος 4, 2009 #571 Κοινοποίηση Ιούλιος 4, 2009 Glary Utilities - Ένα freeware alternate του TuneUp Utilities Version: 2.14.0.711 Release Date: July 01, 2009 Optimize, clean and boost the speed of your Windows. Protect your privacy and security. Block spyware, trojans, adware, etc. Fix certain application errors. Simple, fast and User friendly interface For only private use One Click A Day For PC Maintenance, Keeps Any PC Problems Away. With millions of worldwide users, the first-rank & free Glary Utilities is an INDISPENSABLE friend for your PC, with its 100% safe, thorough & quick cleaning and worry-free restoration. Glary Utilities is a freeware with registry and disk cleaning, privacy protection, performance accelerator and amazing multifunctional tools. It can fix dogged registry errors, wipe off clutters, optimize internet speed, safeguard confidential files and maintain maximum performance. It is designed for both novice and professionals. User-friendly interface shows clear & detailed directions. For novice, all work can be done with just 1 or 2 clicks, while for professionals, abundant options are available. To call Glary Utilities helpful would drastically understate the situation. It hopes to become your INDISPENSABLE friend with its one-stop-shop utilities for optimizing and maintaining your PC for best performance. My friend, welcome to have a try for Glary Utilities and have your say! http://www.glaryutilities.com/gu.html Link to comment Share on other sites More sharing options...
hayabusa Ιούλιος 4, 2009 #572 Κοινοποίηση Ιούλιος 4, 2009 SmartFTP 3.0 Build 1034.0- Fix: RMDA reply was not checked.- Converted remaining dialogs to XAML- Fix: Dynamically calculating input field width in toolbars- Fix: Windows 7: Drag&Drop from favorites to Multi Upload Destination view Link to comment Share on other sites More sharing options...
hayabusa Ιούλιος 7, 2009 #573 Κοινοποίηση Ιούλιος 7, 2009 VLC media player 1.0.0- Live recording- Instant pausing and Frame-by-Frame support- Finer speed controls- New HD codecs (AES3, Dolby Digital Plus, TrueHD, Blu-Ray Linear PCM, Real Video 3.0 and 4.0, ...)- New formats (Raw Dirac, M2TS, ...) and majors improvements in many formats...- New Dirac encoder and MP3 fixed-point encoder- Video scaling in fullscreen- RTSP Trickplay support- Zipped file playback- Customizable toolbars- Easier encoding GUI in Qt interface- Better integration in Gtk environments- MTP devices on linux- AirTunes streaming- New skin for skins2 interface Link to comment Share on other sites More sharing options...
kreach Ιούλιος 7, 2009 #574 Κοινοποίηση Ιούλιος 7, 2009 Eπιτέλους βγήκε και η πρώτη έκδοση !!! Καιρό την περίμενα και τακτικότατα έκανα search για updates μέχρι και χτες αλλά ... μάταια Tώρα τη κατεβάζω, εύχομαι να δω διαφορά Edit: Πάλι έκανα αναζήτηση για updates και πάλι έβγαλε πως έχω την τελευταία έκδοση, αν κι έχω μείνει με την 0.9.9... wtf? Link to comment Share on other sites More sharing options...
Fireman1234 Ιούλιος 30, 2009 #575 Κοινοποίηση Ιούλιος 30, 2009 CCleaner 2.22.968http://www.ccleaner.com/downloadChange log:- Redesign of Cleaner results panel.- Added support for Opera 10 Beta.- Added support for Safari 4.0.- Added search to Uninstall tool.- Added search to Cookies screen.- Improved User assist cleaning in Windows 7.- Fixed bug in OpenOffice cleaning.- Fixed IE8 SuggestedSites.dat cleaning support.- Fixed UI bugs. Link to comment Share on other sites More sharing options...
Fireman1234 Αύγουστος 4, 2009 #576 Κοινοποίηση Αύγουστος 4, 2009 Firefox 3.5.2 Firefox 3.5.2 fixes the following issues:Several security issues.Images with ICC profiles now render properly on all monitors. Link to comment Share on other sites More sharing options...
The/Real/In/Me Αύγουστος 6, 2009 #577 Κοινοποίηση Αύγουστος 6, 2009 Glary Utilities - Ένα freeware alternate του TuneUp Utilities Version: 2.14.0.711 Release Date: July 01, 2009 Optimize, clean and boost the speed of your Windows. Protect your privacy and security. Block spyware, trojans, adware, etc. Fix certain application errors. Simple, fast and User friendly interface For only private use One Click A Day For PC Maintenance, Keeps Any PC Problems Away. With millions of worldwide users, the first-rank & free Glary Utilities is an INDISPENSABLE friend for your PC, with its 100% safe, thorough & quick cleaning and worry-free restoration. Glary Utilities is a freeware with registry and disk cleaning, privacy protection, performance accelerator and amazing multifunctional tools. It can fix dogged registry errors, wipe off clutters, optimize internet speed, safeguard confidential files and maintain maximum performance. It is designed for both novice and professionals. User-friendly interface shows clear & detailed directions. For novice, all work can be done with just 1 or 2 clicks, while for professionals, abundant options are available. To call Glary Utilities helpful would drastically understate the situation. It hopes to become your INDISPENSABLE friend with its one-stop-shop utilities for optimizing and maintaining your PC for best performance. My friend, welcome to have a try for Glary Utilities and have your say! http://www.glaryutilities.com/gu.html το πιο χαλια προγραμμα που υπαρχει,δεν κανει τπτ το μονο π σβηνει σωστες καταχωρισεις registry:rip: Link to comment Share on other sites More sharing options...
lefteriz Αύγουστος 21, 2009 #578 Κοινοποίηση Αύγουστος 21, 2009 Windows live Messenger 2009 build 14.0.8089.726 english full installer: http://wl.dlservice.microsoft.com/download/F/2/B/F2BDDA8A-F285-440B-98CE-BABEE6CA0B0E/en/wlsetup-all.exe greek full installer: http://wl.dlservice.microsoft.com/download/D/0/9/D09D1100-E33A-4A1D-AD59-AC360F0F51E9/el/wlsetup-all.exe και με αυτό το πατς βγαζουμε διαφημίσεις κλπ και επιτέλους απενεργοποιείται το ΗΛΙΘΙΟ photo sharing http://apatch.org/downloads.php Link to comment Share on other sites More sharing options...
l_satsok Αύγουστος 21, 2009 #579 Κοινοποίηση Αύγουστος 21, 2009 ναι,μονο που τρεχω το patch και εχει μεινει εκει στη μεση μιση ωρα τωρα...applying patch,please wait...μεχρι αυριο; Link to comment Share on other sites More sharing options...
slaught Αύγουστος 21, 2009 #580 Κοινοποίηση Αύγουστος 21, 2009 To winrar σε 32&&64bit εκδοση 3.90 εδώ Link to comment Share on other sites More sharing options...
