defiant Απρίλιος 17, 2005 #21 Κοινοποίηση Απρίλιος 17, 2005 FireTune 1.0.1FireTune for Mozilla Firefox v1.x was developed for an easy and fast optimization of your browsing experience with Firefox.It is based on a collection of popular and well working optimization settings used and tested by the experts.Usually you have to optimize Firefox manually, which can be time consuming and difficult for the novice user.FireTune helps you here - it includes all the performance optimizations.The only thing you must do is: make your selection. FireTune does the work for you.Download Link to comment Share on other sites More sharing options...
PGM Απρίλιος 17, 2005 Author #22 Κοινοποίηση Απρίλιος 17, 2005 Acronis True Image 8.0 build #826, 2005-04-11 Changes: * GUI fixes * Serial number problem fixed * Better hardware support * Unmount image under Win2003 fixed Link Link to comment Share on other sites More sharing options...
PGM Απρίλιος 22, 2005 Author #23 Κοινοποίηση Απρίλιος 22, 2005 Realtek HD Audio CODEC R1.19New realtek HD Audio CODEC drivers are out, this time build R1.19.Pack with Microsoft High Definition Audio UAAV1.0a(5013)Add/Fix * Customization. * Avoid Pop noise when toggle output sampling rate for ALC260. * Restore the original timer resolution first before check the original system timer resolution.For New architecture: * Customization. * Driver store mixer setting after windows rebootDownload Link to comment Share on other sites More sharing options...
PGM Απρίλιος 28, 2005 Author #24 Κοινοποίηση Απρίλιος 28, 2005 ZoneAlarm Link to comment Share on other sites More sharing options...
PGM Απρίλιος 28, 2005 Author #25 Κοινοποίηση Απρίλιος 28, 2005 Adobe Link to comment Share on other sites More sharing options...
PGM Μάϊος 10, 2005 Author #26 Κοινοποίηση Μάϊος 10, 2005 Opera for Windows [ Win 95/98/ME/NT/2000/XP ] Final Version Changes since Beta 3User interface * Added integrated Opera Web search with keyword 'S'. * Fix for dragging page tabs when "Open new page next to active" preference is set. * Added automatic downloading of language files if the language is selected and the file is available for download. * Changes to preferences dialog o Readded language settings dialog. o Readded default browser settings. o Readded "Show exit dialog" setting. o Readded "Enable inline frames" setting. o Readded "Max connections to a server" and "Max total connections" settings. * Readded "Enable special effects" to "Appearance" dialog. * Fix for deleting sessions in sessions manager. * Fixed renaming of setup files (keyboard, mouse, menu, toolbars, voice) in the preferences dialog. * Enabled styling of scrollbars by default. * Disabled AltGr shortcuts during inline search. * Fix for mouse gestures over form inputs being applied to wrong tab. * Improvements for spatial navigation within frames. * Fix for accesskey in area maps. * Fix for deleting existing skins when new skin downloads are cancelled. Messaging and newsfeeds * Fixed a blank message problem displaying forwarded messages. * Improved encoding selection for RSS feeds. * Fix to prevent data loss when opening two compose windows for same draft message. * Fix for displaying entity characters in RSS subjects. * Fix to respect the xml:base attribute for inline XML content in RSS. * Improved handling of whitespace characters in e-mail addresses. * Fix to avoid refetching newsfeeds every minute, if the feed was not a valid RSS or Atom document. * Fix to prevent filtering messages to incorrect view. Display and standards * New User JavaScript feature o Add your own .js file directories in Preferences > Advanced > Content. o Is disabled for all URLs using the HTTPS or opera: protocols. o Read more about User JavaScript * Changes to "Fit to window width" handling/ERA. * Improved support for SVG 1.1 Tiny. * Improvements to display of Simplified Chinese characters, as well as serif and sans-serif font-families with Japanese fonts. * Changes to Javascript and DOM o JavaScript pop-up windows respect "scrollbars" option. o Removed support for ActiveXObject function as an alternative reference to XMLHttpRequest. o Implemented XMLHttpRequest.getAllResponseHeaders and XMLHttpRequest.getResponseHeader o Added support for RegExp.leftContext and RegExp.rightContext o Fix for onclick detection and emulation for mouseless systems. o Selection is preserved when clicking links or buttons, for use with document.getSelection() and document.selection o Fix to prevent sending load events to images when switching stylesheets. o Fix for document.body.offsetHeight to report viewport height in quirks mode. * Fix for CSS generated content being applied to elements with xml:lang attribute instead of accesskey attribute Voice * Removed VoiceXML support for documents served as text/html. * Enabled text-to-speech on pages that use english locale language codes such as en-gb. Miscellaneous * Solved multiple stability issues. * Allowed caching of redirected URLs. * Enabled smooth zooming of images by default. To disable smooth zooming of images, set "Interpolate Images" to "0" to the [Multimedia] section of opera6.ini * Fix to respect "Use Proxy On Local Names Check" setting for local server addresses. * Fix for deleting plug-in path when installed on network drive. * Speed-up of initial reading of global history. Download and Info Link to comment Share on other sites More sharing options...
chriss Μάϊος 10, 2005 #27 Κοινοποίηση Μάϊος 10, 2005 Την έχω καταβρεί με αυτό το πρόγραμμα. Link to comment Share on other sites More sharing options...
acv Μάϊος 10, 2005 #28 Κοινοποίηση Μάϊος 10, 2005 CCleaner v1.19.105 - (28/04/05)http://www.ccleaner.com/Belarc Advisor version 7.0L (01/05/05) http://www.belarc.com/free_download.html Link to comment Share on other sites More sharing options...
PGM Μάϊος 11, 2005 Author #29 Κοινοποίηση Μάϊος 11, 2005 MICROSOFT SECURITY UPDATE ALERTMay 10, 2005SECURITY UPDATE INFORMATIONMicrosoft has released a security update for Microsoft Windows.Information about this update and which versions of Windows areaffected is available on the Microsoft.com Security Web site:http://www.microsoft.com/updates Link to comment Share on other sites More sharing options...
PGM Μάϊος 12, 2005 Author #30 Κοινοποίηση Μάϊος 12, 2005 Firefox 1.0.4 is a security update that is part of our ongoing program to provide a safe Internet experience for our customers. We recommend that all users upgrade to this latest version. Here's what's new in Firefox 1.0.4: * Several security fixes. * Fix to DHTML errors encountered at some web sites. For web developers, learn more. Fixed in Firefox 1.0.4 MFSA 2005-44 Privilege escalation via non-DOM property overrides MFSA 2005-43 "Wrapped" javascript: urls bypass security checks MFSA 2005-42 Code execution via javascript: IconURL Info and Download Link to comment Share on other sites More sharing options...
jpavly Μάϊος 15, 2005 #31 Κοινοποίηση Μάϊος 15, 2005 EVEREST Home Edition is a freeware hardware diagnostics and memory benchmarking solution for home PC users, based on the award-winning EVEREST Technology. It offers the world's most accurate hardware information and diagnostics capabilities, including online features, memory benchmarks, hardware monitoring, and low-level hardware information. Hardware Information Motherboard & CPU Accurate low-level information about motherboard, CPU and BIOS, including chipset details, DMI enumeration, AGP configuration information, SPD memory modules list, DRAM timing information and CPU instruction set support. Video adapter & monitor Detailed information about the video adapter, video drivers and monitor, including DDC information, monitor serial number and supported video modes detection, low-level GPU details, OpenGL and Direct3D features list. Storage devices Information about all hard disk and optical disk drives, including IDE autodetection, S.M.A.R.T. disk health monitoring, ASPI SCSI devices list and partitions information. Network adapters, multimedia, input devices Exhaustive information about network adapters, sound cards, keyboard, mouse and game controllers, including NIC MAC address detection, IP and DNS list, network traffic monitoring, DirectSound, DirectMusic and DirectInput information. Misc hardware Information about PCI, PnP, PCMCIA and USB devices, communication ports, power management information, device resources list, printers information. Diagnostics Hardware monitoring Sensor information including system, CPU and GPU temperature, fan status, CPU, GPU, AGP and DRAM voltage monitoring, S.M.A.R.T. disk health status. Support for Corsair Xpert memory modules. Benchmarking Memory read and write speed, memory latency measurement to stress the memory and cache subsystem, including references list to compare actual performance with other systems. Tips & suggestions Detection of possible hardware and software misconfiguration and compatibility issues. Reporting Report Wizard Easy-to-use method to produce report files of the system, by either using pre-configured report profiles or custom selection of information. Report formats Three different report file formats: plain text, customizable HTML and the unique MHTML format. MHTML reports including icons are ideal for printing purposes. Report e-mailing and printing Built-in e-mail transfer client using SMTP, also support for MAPI and Outlook protocols. Instant report display and one-click printing capabilities using IE4+ technology. Download It Link to comment Share on other sites More sharing options...
spc Μάϊος 16, 2005 #32 Κοινοποίηση Μάϊος 16, 2005 Nero 6 Reloaded version 6.6.0.13 http://www.nero.com/eng/nero-up.phpVersion Number: 6.6.0.13 (Changes from Package #1, Version 6.6.0.12 - 6.6.0.13) Release Date: May 9, 2005 Bug FixesAAC Audio encoder settings not applied Error using disc finalize feature in the 'Disc Info' section Using UDF as default file system for using dual layer DVD-R medias with multisession compilation Nero Express did not ask to save a LightScribe document if the application was closed by ALT+F4 or the [X] close button An internal LightScribe error occurred for print and/or preview if Nero was accessing (e.g. erasing) the same device An "Internal error" occurred if accessing a folder which was linked to a remote network path Added advisory messages Version Number: 3.1.0.7(Changes from Package #2, Version 3.1.0.0c - 3.1.0.7) Release Date: May 9, 2005 New FeaturesAdded *.mod to supported video file formats BugfixesWriting a DVD-Video project failed with Burn-at-once Content import problems occurred if the source media was a DVD-RAM written in VR mode In some rare cases the application could hang if capturing directly to a DVD-RAM media Exporting a video title to uncompressed *.avi format caused a crash in Windows 9x In some cases and with certain drives, a runtime error appeared when writing a DVD VR to a DVD-RW media If two files, one audio and one video, were added together to the storyboard, the application crashed The application sometimes hung if a "Capture to VR" process was interrupted by the user If a user changed the volume label while appending video titles to a VR disc, the changes were ignored The Windows maximize button was not enabled Writing a DVD-Video project to a dual layer DVD-R media failed in some rare cases Renamed "Record directly to VR" to "Record directly to DVD" In some cases the application crashed when compiling a slide show Capturing to HDD using the DV template was not working Some MPEG-2 files were out of sync when re-used for a DVD-Video project The application showed a 4:3 preview when recording 16:9 Direct recording using a Mini-DV Camcorder as source was not working Dolby© Digital 5.1 encoder could produce jumps in the audio stream Link to comment Share on other sites More sharing options...
acv Μάϊος 16, 2005 #33 Κοινοποίηση Μάϊος 16, 2005 SpywareBlaster 3.4 (14/5/2005)http://www.javacoolsoftware.com/spywareblaster.html Link to comment Share on other sites More sharing options...
spc Μάϊος 18, 2005 #34 Κοινοποίηση Μάϊος 18, 2005 DVDFab Version 2.86http://www.dvdidle.com/el/download.htm?s=fabplatinum Link to comment Share on other sites More sharing options...
FrOsT Μάϊος 21, 2005 #35 Κοινοποίηση Μάϊος 21, 2005 Netscape 8.0.1 Σε μία μέρα από την 8 στην 8.0.1!!!!! Η νέα έκδοση περιέχει όλα τα patch ασφάλειας μέχρι και τον Firefox 1.0.4 Link to comment Share on other sites More sharing options...
Snips Μάϊος 22, 2005 #36 Κοινοποίηση Μάϊος 22, 2005 SPEEDFAN 4.24 UGURU supportspeedfan 4.24 4.24 - added uGuru support - enabled GET CONFIG button on the INFO tab (please, read the help file) - added support for ALi M1563 SMBus with M1681 - enabled online GET CONFIG procedure to download user supplied configurations for individual motherboard models - fan names set up by sensor's initialization code are now properly reflected in the UI - better detection of ITE IT8702F - identified a new revision of ITE IT8705F - added debug code and improved NS PC87366 support - fixed russian and added danish translation - Winbond W83791D and W83791SD do share the same Device ID and are now always detected as a Winbond W83791D - properly closed the I/O support routines when entering suspend Link to comment Share on other sites More sharing options...
spc Μάϊος 22, 2005 #37 Κοινοποίηση Μάϊος 22, 2005 and the game goes on....:DVDFab Version 2.87http://www.dvdidle.com/el/download.htm?s=fabplatinum Link to comment Share on other sites More sharing options...
dimitris81 Μάϊος 30, 2005 #38 Κοινοποίηση Μάϊος 30, 2005 Νεα εκδοση Ad-Aware SE Personal Edition(1.06) DOWNLOAD Link to comment Share on other sites More sharing options...
unstoppable Μάϊος 31, 2005 #39 Κοινοποίηση Μάϊος 31, 2005 * Updated ffdshow to build 2005-05-27* Fixed ffdshow VFW interface* Updated MP4 DirectShow splitter to build 2005-05-29* Updated Matroska DirectShow splitter (made by Haali) to build 2005-05-29* Added QuickTime/RealMedia browser plugin support for Netscape 8* Improved unattended install maker. Now features full control of tasks* Minor changeshttp://fileforum.betanews.com/detail/KLite_Mega_Codec_Pack/1080441198/1 Link to comment Share on other sites More sharing options...
wrong method Μάϊος 31, 2005 #40 Κοινοποίηση Μάϊος 31, 2005 ok, εγώ έχω το ffdshow και τον BSPlayer ξεχωριστά εγκατεστημένα (δεν δούλεψαν δλδ με το codec pack που έχω) Τι γίνεται τώρα; Τα βγάζω η τα αφήνουμε ως έχουν;Πρέπει να απεγκαταστήσω και το προηγούμενο pack και κάνουμε clean install η απο πάνω το νεο; Τα forums δεν αναφέρουν τίποτα. Link to comment Share on other sites More sharing options...
