Καινούργιες εκδόσεις (Haya)
PGM
  • Replies 2,4k
Αρχική απάντηση από kreach [15-12-2005 20:11]
Τρέχτε ΓΡΗΓΟΡΑ !!!!! Όσοι το προλάβατε σε free edition διότι ΔΕΝ είναι πια freeware (βλ Forum- Benchmarking) ! Ήδη αρκετά sites το έχουν βγάλει :mad:
Δυστυχώς για όσους δεν προλάβαμε...
Στο guru3d.com, αν και φαίνεται ότι υπάρχει για download η home edition,
κατεβαίνει η ultimate edition (trial).
Αν κανένας ανακαλύψει κανένα site που να δίνει ακόμα τη home ας μας το πει...
With DVD2one you can make movie-only and full disk copies for personal use on a single DVD-Recordable. Key features include:
# Unique video compression engine: combines blazing speed with the highest quality.
# Multi-processor, multi-core and multi-computer (grid) compatible.
# Process a movie to fit on a single recordable in a matter of 15 to 30 minutes (depending on the speed of your computer).
# Make movies-only copies. Why waste space and image quality on unnecessary intros, menus and language tracks?
# Make also full disk copies. For those who want to keep those fancy menus and intros.
# Powerful join mode. Useful for putting multiple episodes of a (tv) series or joining both sides of a flipper on 1 disk.
# Remaster your CDs on DVD in Super CD quality.
# Builtin burnengine.
# Written from scratch, not based on any old code, libraries or existing opensource projects.
# Time critical parts written in assembly, for the highest possible speed.
# Both PC Windows and Mac OS-X versions available.
DVD2one V2.0.2
Here's a new version of DVD2one with the following features:
* Languages added: French (thanks to Antoine Desir), German (thanks to Sascha Lamprecht), Italian (thanks to Bruno Vella), Portugese (thanks to Marco Pinto) and Spanish (thanks to Fernando Conde).
* Nice icons to tree added.
* Mac: fixed missing system menu on OS-X 10.4.
* Mac: compiled again with GCC4. Panther users need at least OS-X 10.3.9 for this release.
* PC: fixed problem with special characters and Japanse symbols (kanji) in directory- and filenames. Only the Audio Remaster part does not handle Japanese symbols.
DOWNLOAD
Δείτε και αυτό (νομίζω ότι δεν υπάρχει σε κάποια από τις προηγούμενες σελίδες):
SIW - System Information for Windows.
This program perform computer configuration analysis and diagnostics. It gives detailed information about your computer properties and settings, detailed specs for CPU, motherboard, chipset, BIOS, CPU, PCI/AGP, USB and ISA/PnP devices, memory, monitor, video card, disk drives, CD/DVD devices, SCSI devices, S.M.A.R.T., ports, network cards, printers, operating system, installed programs and hotfixes, processes, services, serial numbers (CD keys), users, open files, system uptime, network, network shares, as well as real-time monitors for CPU, memory, page file usage and network traffic. It displays currently active network connections, passwords hidden behind asterisks, installed codecs, and more.
This program also creates a report file, and is able to run in batch mode.
A standalone tool that does not require installation - one less installed program on your PC as well the fact that you can run the program directly from a USB flash drive.
Το έκανα post, πριν λίγες μέρες, στην κατηγορία benchmarking, αλλά ισως εδώ είναι καλύτερα. Ένα σημαντικό πλεονέκτημα (σε σχέση με άλλα παρόμοια): "δεν χρειάζεται εγκατάσταση".
http://www3.sympatico.ca/gtopala/about_siw.html
AMD Power Monitor Version 1.0.1
This application is used to monitor the current frequency,
voltage, utilization, and power savings of each core of each processor in a system. This application also has a system tray icon that can be used to view and select power schemes on the system. The system tray icon will show the average utilization of every core on the system.
αρκετα φρεσκο .εδω περισσοτερα-->http://www.amd.com/us-en/Processors/TechnicalResources/0,,30_182_871_9706,00.html
Το Internet Cyclone είναι ένα πρόγραμμα βελτιστοποίησης της σύνδεσης του υπολογιστή, που υποστηρίζει πως μπορεί να αυξήσει τις επιδόσεις της μέχρι και 200%. Βέβαια, το νούμερο αυτό είναι λίγο... αισιόδοξο, μα όντως, η ρύθμιση των παραμέτρων του τρόπου επικοινωνίας των Windows (Maximum Transmission Unit - MTU, Maximum Segment Size - MSS, Time To Live - TTL κ.ά.) μπορούν να εμφανίσουν κάποια αύξηση ταχύτητας και να καταστήσουν, σε χαμηλότερων επιδόσεων συνδέσεις dial-up, πιό... υποφερτό το browsing πλούσιων σε περιεχόμενο ιστοσελίδων.
http://www.jordysoft.netfirms.com/
Το συγκεκριμένο firewall είναι εμπορικό προϊόν, αλλά διατίθεται δωρεάν για μια μηνιαία δοκιμαστική περίοδο κατά την οποία μπορείτε να χρησιμοποιήσετε πλήρως το πρόγραμμα.
Το firewall περιλαμβάνει μπλοκάρισμα διαφημίσεων και φιλτράρισμα των cookies. Μετά το πέρας του ενός μήνα επανέρχεται στη βασική χρήση του ως firewall.
Firefox 1.5.0.1
Multiple vulnerabilities have been reported in Firefox, which can be exploited by malicious people to bypass certain security restrictions, conduct cross-site scripting attacks, potentially disclose sensitive information, and potentially compromise a user's system.
Solution:
Update to version 1.5.0.1.
http://www.mozilla.com/firefox/
Nero 7.0.5.4
Changes/Bugfixes
It was impossible to edit an audio file anymore once the audio file has been added to a compilation
When ripping tracks, it was not possible to create a new folder from within the save dialog
In rare cases Nero crashed when getting free drive space
Encoding of single tracks was not possible - only all tracks of the compilation
Burn process may have failed in case a saved project is used and if the process will be started within 4 seconds. The error: 'unspecific recorder error' was displayed.
Last position of the window is not saved before closing the application.
Video CD menu entries were readable in preview, but not on the burned Video CD
Virus scan did not work with ZIP files
Nero did not detect any CD/DVD device if 3 or more devices are connected, but the virtual Image Recorder only
