Καινούργιες εκδόσεις (Haya)
PGM
  • Replies 2,4k
Speccy 1.17.340
- Added Computer type (Desktop, Laptop) to Operating System section.
- Updated CPU detection for latest Intel Core i7 models.
- Improved compatibility with LGA 2011 motherboards.
- Added external drive information to Peripherals.
- Improved detection of Sharing and Discovery for printers.
- Improved exception handling.
- Added language support for Kurdish.
- Minor tweaks and fixes.
K-Lite Mega Codec Pack 9.02
- Updated Media Player Classic Home Cinema to version 1.6.3.5435
- Updated ffdshow to version 1.2.4471
- Updated LAV Filters to version 0.51.1-5-ga87ff5e
- Changed default MP4 splitter from Haali to LAV
- Updated Codec Tweak Tool to version 5.4.0
- Updated Win7DSFilterTweaker to version 5.5
K-Lite Codec Pack 9.02 (Full)
KMPlayer 3.3.0.32
- Added Web Search Bar.
- Supports Blu-Ray Play.
- Supports DIVX(xsub) Subtitle(AVI files only).
- Added video codec ProRes(APCH, APCN, APCS, ACPO, AP4H).
- Added video codec(IV50, RV40).
- Fixed AVI source filter(Supports playing damaged file).
- Fixed MKV source filter(Improved performance).
- Fixed RM, RMVB file seek error & Supports damaged file play.
- Fixed ASF file error.
- Fixed URL Play for AVI file.
- Fixed display infomation for MP3 bitrate.
- Fixed background resize error of SWF play.
- Fixed overflow of memory error when external audio file is used.
- Fixed access violation when updating.
- Fixed file name display error while starting a playback.
Total Commander 8.01 RC4
- Alt+Shift+F11 cm_FocusButtonbar and cursor keys within button bar: Handle special case where the first and/or last button is a separator (32/64)
- Changed tcmdx64.exe so it can also be used with TC 8.00 in search results context menu without causing a crash (32)
- When opening a subdirectory, set caret to first item before adding the new items to the list to avoid a duplicate cursor on Linux/Wine (64)
- Internal associations: When context menu is opened while multiple file types are selected, check more filters if the first doesn't match all files, e.g. *.c doesn't match, but *.c *.h further down matches all selected files (32/64)
- Removed: Default beep on ENTER in inplace rename box (64)
- Edit current path: Avoid that the in place edit box gets invoked twice (32/64)
- New delete function: Also hide "Pause" button so the user doesn't pause the operation with Del+Enter (32/64)
- Also adjust the width of the text field in FTP delete confirmation dialog for very long names with no spaces (32/64)
- Experimental: wincmd.ini [Configuration] NetHoodReadInfo=8: Windows Vista/7: Use new delayed method to read virtual network folders, to make it faster (all except for the network neighborhood) (32/64)
