K_tech Ιούλιος 3, 2012 #2031 Ιούλιος 3, 2012 MeGUI 1.0.2153# Features/Changes:* NeroAacEnc + DGIndexNV are now disabled by default as external dependencies are required. If they are already in use they will be enabled automatically, in all other cases they have to be enabled in "Options\Settings\External Program Configuration".* [AutoEncode] enabled option to set the audio language and the track name* [MediaInfo] improved information detection for DVD sources* [update] if a component is missing no jobs can be started# Enhancements/Fixes:* [Audio Encoder] cosmetics. Patch by andrewxeron929623* [Audio Encoder] Import() will be used for AVS input files. Bug #3506283* [Audio Encoder] NicAudio will be tried for DTS-MA decoding when DirectShowSource and FFAudioSource fail* [AVS Script Creator] crop values will only be added to the script if necessary* [AVS Script Creator] improved automatic cropping* [Chapter Creator] added option to sort the title list* [Chapter Creator] improved DVD PGC handling* [DGA/DGI Indexer] + [MKV Muxer] + [VobSubber] added job status message during processing* [DGI Indexer] fixed getting the film value* [FFMS] prepared indexer for handling index files stored in other locations* [Flac] changed input handling (PCM --> RAW) so that 24bit WAV files can be processed as well* [HD Streams Extractor] fixed handling of English tracks in a MKV container when the track name contains a language* [HD Streams Extractor] improved job queuing when no feature is selected* [Job] improved aborting of jobs* [Job] translate process exit codes to status messages* [Log] added required DLLs to the version information block* [Log] use system default encoding for AviSynth input script* [MKV Muxer] adjusted (de)muxer to the recent mkvmerge changes (requires mkvmerge revision 5.3.0+)* [MKV Muxer] improved handling of empty IDX subtitle files* [MP4 Muxer] fixed muxing files with names containing #. Bug #3531735* [OneClick] added some changes for the upcoming next release of the OneClick tool* [OneClick] fixed encoding of AC3 tracks which should be muxed only* [OneClick] fixed problem encoding WMA files* [OneClick] fixed processing of audio files which cannot be demuxed* [PGC Demux] added pgcdemux for DVD PGC processing* [Progress Window] added job name. Feature request #3488205* [settings] cosmetics* [VobSubber] improved detection of subtitle streams* Fixed problems with Turkish characters in various places (e.g. in the File Indexer)
K_tech Ιούλιος 3, 2012 #2032 Ιούλιος 3, 2012 Avant Browser 2012 Build 175- [update] Gecko engine (13.0.1.4562)- [update] Webkit engine (20.0.1132.47)- [Fix]Didn't recognize the environment variables in registry- [Fix]Security warning problem when opening links from start>Favorites- [Fix][Gecko]plugin_container crashed problem- [Fix][Gecko]Avant crashed when playing some videos- [Fix][Gecko]Autofill problem on certain page- [Fix][Gecko]Downloader: Filename garbled in certain Website- [Fix][Webkit]Avant crashed when exiting sleep mode
K_tech Ιούλιος 3, 2012 #2034 Ιούλιος 3, 2012 Rainlendar 2.10- The exception days were not applied correctly with the CSV export.- The time for the events and tasks did not take into account the daylight saving time when exporting CSV.- Deleting tasks with subtasks didn't work correctly when done in the manager dialog.- Dismissing alarms did not work if the UID property had spaces at the end.- Rainlendar crashed if the root item in the active skin list was double clicked.- Toodledo start time was set to the due time when creating or editing the tasks.- Improvements to the Toodledo recurrence support.- Changing the status of a task in the change fields dialog did not work correctly.
