Not optimum mode. Recommended mode: 1280 X 1024 60 Hz @ syncmaster 913v
didicola
I ran into this problem this morning. You are trying to run a resolution that your LCD does not support.
As an example, I have a 22" LCD that runs 1680 x 1050 native widescreen. The CRT I was using was running 1600 x 1200 so when I swapped them out I received the same error message you are receiving. To fix this I booted into safe mode and lowered my display resolution and then after rebooting into normal mode set it to the LCD's correct native resolution and all was fine.
Try this and hopefully it will fix your issue as well...
το δοκιμασα αλλα δεν εγινε τιποτα αδερφε
να σημειωθει οτι ηδη παιζει (απο crt) σε 1280*1024@60Ηζ αλλα οποτε θελει ξεκιναει
