Futuristic Δεκέμβριος 23, 2007 #21 Δεκέμβριος 23, 2007 το RIVA δεν μου βγάζει καμία επιλογή για clockaρισμα
viper1442169065 Δεκέμβριος 24, 2007 #22 Δεκέμβριος 24, 2007 το RIVA δεν μου βγάζει καμία επιλογή για clockaρισμα Πας στο σωστό tab? Έχεις επιλέξει το manual OC ή δεν εμφανίζονται καθόλου οι επιλογές?
Futuristic Δεκέμβριος 24, 2007 #23 Δεκέμβριος 24, 2007 καθόλου δεν φαίνονται! Σε ποιο tab πρέπει να πάω;
squid Δεκέμβριος 24, 2007 Author #24 Δεκέμβριος 24, 2007 http://forums.guru3d.com/showthread.php?t=195029http://www.guru3d.com/article/article/449/41) Read context sensitive help for the options related to your question. To do it either right-click desired option or click [?] button in the window caption and point desired option.Note: RivaTuner's built-in context sensitive help is not available under Vista by default. You must download and install WinHlp32 update from Microsoft website to get it working.2) Read documentation and FAQ supplied with RivaTuner. You can find the link to documentation right in your Start menu in RivaTuner’s application folder. If you are new to RivaTuner or new to a feature related to your question, then it would be good idea to start from reading “System requirements”, “Features” and “Known issues” sections. If you used RivaTuner before but noticed something strange in new release, try to examine the “Revision history” section, which documents all the changes in details. And don’t forget to peek in “FAQ” section or simply use documentation search feature, which can help you to find info by keywords.3) There is huge knowledge base in the forum and most likely your question was already asked many times in the past, so try to use forum search function and don’t forget to read sticky threads, which often contain useful info (for example, all open issues related to the latest released version are usually collected in the sticky thread dedicated to it).
dark22 Δεκέμβριος 24, 2007 #25 Δεκέμβριος 24, 2007 Μέχρι τώρα είμαι με 708 πυρήνα, 1704 shaders, και 947 μνήμη... λίγα δεν είναι? Ειδικά η μνήμη... Είμαι βέβαια με την στοκ ψύκτρα ρυθμισμένη στο 55% το ανεμηστηράκι...Θερμοκρασία 80 βαθμοί κλειδωμένο όταν το τσεκάρω για artifacts με το atitool...Η κάρτα είναι η Asus 8800Gt...Edit: Άκυρο για τις μνήμες... δεν ανεβαίνουν καθόλου τελικά... ακόμα και στα 947 μετά από δέκα λεπτά πετάει artifacts
