PM845GV1 help
didicola
ολη την ωρα μου λεει αυτα
Could not connect. FTP server may be too busy.
You tried to access the address ftp://ftp.albatron.com.tw/product/it/mb/Driver/Int.GFX/Intel/Int.GFX%20XP2K%203317.zip, which is currently unavailable. Please make sure that the Web address (URL) is correctly spelled and punctuated, then try reloading the page.
Make sure your Internet connection is active and check whether other applications that rely on the same connection are working.
Check that the setup of any Internet security software is correct and does not interfere with ordinary Web browsing.
If you are behind a firewall on a Local Area Network and think this may be causing problems, talk to your systems administrator.
Try pressing the F12 key on your keyboard and disabling proxy servers, unless you know that you are required to use a proxy to connect to the Internet. Reload the page.
Need help?
Open the Opera Help.
Go to Opera's on-line support desk.
ναι τον 9,22 εχω αλλα σε εμενα εριξε πορτα ο server τους ελεος πια
μπορει καποιος να τα κατεβασει και να τα κανει upload σε κανα rapidshare plz?
