deadlock7 Οκτώβριος 4, 2006 #41 Οκτώβριος 4, 2006 Κατεβαστε το από εδώ. * New HTML report. * Intel Core 2 Quad, Celeron 360, Mobile Core 2 Duo T5200 support. * Added VIA VT8237A southbridge.
Stelaras Ιανουάριος 14, 2007 #42 Ιανουάριος 14, 2007 Ολοκαινουριο memtest+ 1.70 ! Υστερα απο ενα χρονο το πολυποθητο update εφτασε !http://www.memtest.org/After more than a year without any update due to some lack of time, here is Memtest86+ V1.70 ! This new version comes with complete support for many new chipsets and many new CPUs, including Intel Core/Core2 and AMD K8 with DDR2 memory. Memtest86+ V1.70 now includes a new DMI polling feature in order to show all the memory-related DMI informations (conf. menu -> Error Report mode -> Show DMI Info). Users can enable a new option in configuration menu which will be able to show the exact memory stick that failed. This option require a fully DMI-compliant BIOS.Here is the complete changelog :- Added new DMI polling feature- Added Support for Core/Core2 Solo/Duo/Quad CPU- Added Support for AMD K8 with DDR2 Memory- Added Support for Intel CPU with 192/384 KB L2 Cache- Added Support for FB-DIMM based memory (DMI)- Added Detection for ALI CyberAladdin-T (M1644)- Added Detection for Turion 64 X2- Added Detection for AMD K8 with unknown chipsets- Added Support for ATi Radeon xPress 3200- Added Support for Intel i975X- Added Support for Intel Q965/P965- Added Support for Intel Q963/Q965- Some bug fixesThanks to Jesper Ekhall for betatesting and to Joachim D. for the DMI function.Download is available at http://www.memtest.orgOfficial Forum : http://forum.memtest.org
regent1442169115 Ιανουάριος 15, 2007 #43 Ιανουάριος 15, 2007 Version Date News and corrections1.38 11/22/2006 * VIA P4M890 and P4M900 chipsets. * NVIDIA 650i and 680i chipset. * AMD Athlon 64 FX-7x processor. * Core 2 Duo E6850, E6750, E6650 processors. * Socket 775 Xeon processor. * New parameters "-txt" and "-html" (see above for more details)Download
deadlock7 Φεβρουάριος 14, 2007 #44 Φεβρουάριος 14, 2007 Κατεβάστε το από εδώChangelog 2/14/2007* Windows Vista 64 support.* VIA CX700/VX700 chipset.* Added Merom XE (X7900/X7800)* Added "PCI" and "MaxPCIBus" in the ini file to configure PCI scanning.* Added "-core" parameter to display the clock speed of the specified core.
regent1442169115 Μάϊος 4, 2007 #46 Μάϊος 4, 2007 Version 1.40Date 5/02/2007News and corrections * VIA P4M800CE chipset support. * Preliminary support for Intel Penryn CPUs family (45 nm). * Intel Core 2 Duo E6x20, Pentium E2140/2160 processors recognition. * Intel P35, G33, G31, Q35, Q33, X38 chipsets support. * Intel GL960/GM965/PM965 chipsets support. * AMD Athlon 64 "Lima" processor support. * AMD Geode LX processor support. * NVIDIA nForce 520 chipset support. * New parameter "-console" to generate output in a command prompt (Windows XP only). * New icon, courtesy of Techlogica.
deadlock7 Μάϊος 4, 2007 #47 Μάϊος 4, 2007 Aκόμη δεν είδαμε τις κάρτες,αλλά ας το βάλουμε να υπάρχει για το μέλλον.. Παράθεση This Overclocking and Monitoring Tool from AMD lets you manage clocks of all their cards including their yet unreleased R600 Series. You can also monitor temperature of the Radeon HD 2000 cards.Download
deadlock7 Μάϊος 15, 2007 #48 Μάϊος 15, 2007 Πρόγραμμα για να βάλετε στην κάρτα σας,το Bios που σας αρέσει.. Παράθεση Main features* Detailed BIOS information outputo Device IDo BIOS Versiono BIOS Dateo Vendoro Core/Memory Clock display+ 2D Core/Memory Clock+ 3D Core/Memory Clock+ Throttling Core/Memory Clocko Core Voltage display+ 2D Voltage+ 3D Voltage+ Throttling Voltageo Memory Timings displayo Product Identification* Ability to modify the several BIOS Parameterso Core Clock defined within the BIOSo Memory Clock defined within the BIOSo Core Voltage defined within the BIOSo Memory Timings defined within the BIOSo Temperature Settings defined within the BIOSo Fan Speed Settings defined within the BIOS* Specific Boot Settingso Graphics Card OEM and Advanced Signon Messageo Monitor Specific Parameterso Graphics Card Initiation Settingso TV Mode Selection (NTSC/PAL)* Ability to check BIOS Integrityo BIOS Checksum Checkingo BIOS Structure CheckingChanges in this Version* Added Support for GeForce 8800 Ultra PCI-E* Added Support for GeForce 7900 GS AGP* Added Support for GeForce Go 7600 PCI-EDOWNLOAD
viper1442169065 Μάϊος 15, 2007 #49 Μάϊος 15, 2007 deadlock7 έγραψε: Πρόγραμμα για να βάλετε στην κάρτα σας,το Bios που σας αρέσει..DOWNLOADΤο προηγούμενο πάντως στην 7600gt μου έδινε πολύ λίγες πληροφορίες για έξτρα πειράγματα, ειδικά σε ρεύματα που με ενδιέφερε, και τις έξτρα επιλογές τις έβγαζε με ερωτηματικό.Δηλαδή δεν είχες ιδέα τι ήταν οι έξτρα επιλογές.Ξέρουμε αν αυτό έχει βελτιωθεί στη νέα έκδοση?
deadlock7 Μάϊος 15, 2007 #50 Μάϊος 15, 2007 Δε μπορώ να πώ αν έχει όντως αυτό που θές,αλλά η νέα έκδοση θα σε βοηθήσει εφόσον υποστηρίζει την κάρτα σου!
deadlock7 Μάϊος 22, 2007 #51 Μάϊος 22, 2007 1.3.6.1042 - DOWNLOAD Παράθεση [*] Updated existing translation files[+] Added Polish translation[*] Updated Advances Tweaks databases[F] Fixed procedure to collect monitoring sources from ATT in "Motherboard Sources" FlashOSD Plugin.[F] Fixed current 3D profile detection in non CCC compatible mode[*] Updated Monitoring Graphs module to support external plugins. This excellent idea was first implemented in RivaTuner byUnwinder. ATT and RT plugins are incompatible.[+] Added example Monitoring Graphs plugin "Memory Monitor". Which can monitor global memory statuses like Memory Load %,Physical memory Available, Page File usage, Virtual memory usage. Source code included.[+] Added monitoring plugin "HDD Temperature". Allows monitoring temperature of HDD disks via S.M.A.R.T. [*] Updated plugins SDK to support new monitoring graphs plugins[*] Minor GUI updates[*] Updated Driver level Overclocking support for RV560/RV570 boards.[*]Added test support for voltage regulation on X1950XTX boards.[*] Added monitoring plugin "X1xxx Voltages" to provide monitoring sources for GPU/Mem voltages.[*] Updated installation GUI interface[+] Added new configuration option. "Disable using OverDrive in "Driver Level" overclocking mode". This option can be usefulif your video board has support for OverDrive, but ATT unable to overclock using "Driver Level" mode. Can be changed inatitray.ini or at installation process.[*] Updated Overdrive 3 support detection procedure.[*] Updated Core Names database. Added infotmation about RV610/M74/M72/M76/RV630 chips.[*] Updated registry handling function under CCC compatibly mode.[*] Added support for Vista 32bit. Not all of functions will work under Vista at this time.[-] Audio recorder and Volume control functionality disabled because of incompatible issues under Vista.[*] Updated Advanced Tweaks registry editor to support Windows Vista[*] Added new tweaks database "Avivo Tweaks" for Windows Vista only![F] Fixed memory calculation procedure for some of RV5xx video boards[+] Added new option to automatically restore desktop icon positions after resolution changes.[*] Updated RefreshLock subsystem. Now you should set only Width, Height and Refresh rate for refresh override. No need toset color quality. Old saved profiles are incompatible with this version so please recreate them again.[+] Added new Game Profile option. "Force VSync=ON". This option can force using VSync in D3D8/9 games under Vista[*] Now only "Driver level" mode overclocking are allowed for X1xxx video boards. If you want to use Low Leveloverclocking you should change options in atitray.ini.[*] Added support for Radeon X1050[*] Updated HW Monitor logging system. Added option to select log file folder location
TASOS Σεπτέμβριος 19, 2007 #52 Σεπτέμβριος 19, 2007 Νέο cpu-zΕπιτέλους δείχνει σωστά το Vcore των Core 2 Duo & Quad.http://www.cpuid.com/download/cpu-z-141.zipNew CPU voltage monitoring. Intel Xeon Tigerton support. Intel IA64 CPUs support (Itanium / Itanium2). Special thanks to Rami Radi and Ray Hinchliffe for their help. AMD K10 Phenom preliminary support. NVIDIA MCP73 support. Intel XMP profiles support. Memory modules nominal voltage.
Simon1442169120 Οκτώβριος 6, 2007 #53 Οκτώβριος 6, 2007 GPU-ZΈνα μικρό και ελαφρύ utility που σας δείχνει πληροφορίες για την κάρτα γραφικών σας, παρόμοιο με το CPU-Z. Βρίσκεται στην 0.0.4 έκδοση (335KB), δεν είναι stable ακόμα.Για πληροφορίες και λήψη κάντε κλικ εδώ.
MadCatMk21442169156 Οκτώβριος 6, 2007 #54 Οκτώβριος 6, 2007 Simon έγραψε: GPU-ZΈνα μικρό και ελαφρύ utility που σας δείχνει πληροφορίες για την κάρτα γραφικών σας, παρόμοιο με το CPU-Z. Βρίσκεται στην 0.0.4 έκδοση (335KB), δεν είναι stable ακόμα.Για πληροφορίες και λήψη κάντε κλικ εδώ.Niiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiice :033: :033: :033: και το name, ωραία ιδέα για την προώθηση της εφαρμογής!:063:
thanos21unoDK Οκτώβριος 6, 2007 #55 Οκτώβριος 6, 2007 Simon έγραψε: GPU-ZΈνα μικρό και ελαφρύ utility που σας δείχνει πληροφορίες για την κάρτα γραφικών σας, παρόμοιο με το CPU-Z. Βρίσκεται στην 0.0.4 έκδοση (335KB), δεν είναι stable ακόμα.Για πληροφορίες και λήψη κάντε κλικ εδώ.καλουτσικο φενεται.
viper1442169065 Οκτώβριος 9, 2007 #56 Οκτώβριος 9, 2007 Simon έγραψε: GPU-ZΈνα μικρό και ελαφρύ utility που σας δείχνει πληροφορίες για την κάρτα γραφικών σας, παρόμοιο με το CPU-Z. Βρίσκεται στην 0.0.4 έκδοση (335KB), δεν είναι stable ακόμα.Για πληροφορίες και λήψη κάντε κλικ εδώ.Εμένα δε μου βγάζει σωστά τον πυρήνα.Έχω 560 default και παρόλο που τον έχω στα 607, πάλι 560 τον βγάζει.http://www.techpowerup.com/gpuz/cayyn/
deadlock7 Οκτώβριος 27, 2007 #58 Οκτώβριος 27, 2007 GPU-Z v0.0.9Upgrade:# Fix for more NVIDIA related crashes# Fixed NVAPI losing information after display settings reset# Added private submissions that can not be viewed publicy. Next time think before uploading RV670 info and then realizing you could lose your job# Added bug report submissions# Added numerous IGP adapter info# Added info for GeForce 8800 GT# Improvements to shader clock calculation on G80+# Updated iconDownload
deadlock7 Οκτώβριος 27, 2007 #60 Οκτώβριος 27, 2007 Rivatuner v2.06 betaVersion 2.06:Minor bugfixes:Fixed DDR2 videomemory detection for G84/G86 graphics processors.Minor UI and localization fixes.What's new:Added ForceWare 167.xx drivers family support including ForceWare 167.xx compatible overclocking. Please take a note that 2D/3D clock switching for some GPU families is completely broken in early 167.26 drivers. Until the problem is fixed in the driver RivaTuner bypasses this issue by mapping 2D, LowPower 3D and 3D performance level clocks to the same single clocking level provided by these drivers.Updated databases for Detonator and ForceWare drivers. Added databases for ForceWare 163.74, 163.75, 163.76 and 167.26.Added Catalyst 7.10 drivers detection.Updated Catalyst 7.10 certified SoftR9x00 patch script (for Windows 2000/XP drivers only).Added ATI RV670 graphics processors family support. Now RivaTuner's low-level features including overclocking, monitoring, diagnostics and fan control are available on ATI RADEON HD 38x0 family. Thanks to Anthony Tam @ HIS for providing ATI RADEON HD 3850 sample for testing.Added experimental support for the rest upcoming 55nm ATI RV6xx graphics processors families.Improved RV610/RV630 graphics processors families support. The improvements cover wide range of hardware overclocking, diagnostics, fan control and monitoring features.Added NVIDIA G92 graphics processors family support. Now RivaTuner's driver-level tuning and low-level features including overclocking, monitoring, diagnostics and fan control are available on NVIDIA 8800GT and other upcoming G92 based NVIDIA products.Improved driver-level fan control tab for NVIDIA display adapters:Added driver-level fan control tab for NVIDIA Vista drivers. Now RivaTuner is able to control fan on midrange NVIDIA display adapters with integrated fan controller under Vista via the ForceWare's NVAPI interfaces. Please take a note that unlike Windows XP fan control interfaces Vista's NVAPI fan control interfaces do not support independent 2D/3D fan speed adjustment and allow you to use either automatic or direct fixed fan control only. By default NVAPI fan control interfaces are used under Vista only, however Windows XP owners can also force RivaTuner to use Vista specific fan control interfaces if needed. The forcing can be useful to get fan control working on some graphics processors families, having broken separate 2D/3D fan control implementation in Windows XP driver (e.g. GeForce 8600 family).Driver-level fan control tab is now hidden on display adapters supporting binary fan control only (i.e. able either to run fan at full speed or shut it down completely) to avoid confusing beginners. Power users may unlock binary fan control if necessary by setting AllowBinaryFanSpeedControl registry entry to 1.Improved low-level overclocking tab for ATI R6xx/RV6xx display adapters:Now RivaTuner supports overclocking on ATI RV6xx display adapters using DPM (Dynamic Power Management) clock frequency adjustment.Now RivaTuner restores default clocks on ATI R6xx/RV6xx by means of the driver's PowerPlay table reset if possible.Improved low-level fan control tab:Improved duty cycle generation accuracy for display adapters using LM63, LM64, F75363 and ADT7473 external I2C fan controllers.Added low-level fan control support for ATI RV6xx integrated fan controllers.Added low-level fan control support for NVIDIA NV3x and newer integrated fan controllers. Please take a note that low-level fan control tab for display adapters using integrated fan controller (e.g. GeForce 6600, 7800GT, 7900GT etc) is provided only as a workaround allowing you to control the fan if the drivers are completely unable to do it. It is strongly not recommended to use low-level fan control for integrated fan controllers if driver-level fan control functions properly.Improved hardware monitoring module:Added ATI RV6xx DPM (Dynamic Power Management) technology support. Now RivaTuner is able to monitor dynamically changing RV6xx clock core and memory clock frequencies adjusted in real-time by DPM depending on the GPU usage.Added 'Reference fan duty cycle' graph for ATI RV6xx graphics processors families.Added 'Reference fan duty cycle' graph for NVIDIA G80 and newer graphics processors families. Please take a note that some non-reference G84 based display adapters use inverted PWM polarity fan control, which means that 'Reference fan duty cycle' displays inverted duty cycle as well as low-level fan control slider is inverted too. Such issues can be resolved by adding such display adapters to internal fan controller database represented by [FANPWM] section of RivaTuner.cfg file. The polarity can be inverted by adding the entry identifying such display adapter to the database and specifying inverted fan PWM controller ID (84h) for it instead of normal one (04h).Heavily optimized low-level I2C bus access algorithms for NVIDIA G80 and newer graphics processors families. Now the bus is accessed via new dedicated I2C registers instead of traditional I2C CRTC ports. Dedicated I2C access drastically reduces CPU time consumed by each I2C transaction (up to 5x - 7x times faster on certain hardware configurations). The effect of the optimization is the most visible in conjunction with MMIO mode when any device connected to I2C bus (e.g. ADT7473 thermal / fan controller) is being frequently polled. Power users may activate the previously available I2C access mode for performance comparison by setting NVI2CAccessModeG8x registry entry to 0.Now hardware monitoring graph renderer flushes bitmap caches after each display mode change to help display driver to render the graphs in optimal way. By default flushing is performed within a period of time defined by PostDisplayChangeBitmapFlushPeriod registry entry, the period can be changed by redefining it or the flushing can be disabled completely by setting the period to 0.Improved diagnostic report module:Improved navigation via the list of diagnostic report categories. Now report preview window is positioned on desired category more accurately when double clicking it in the list of diagnostic report categories.Improved PowerPlay table flags decoding in 'ATI VGA BIOS information' diagnostic report category.Added MMIO protection fallback support. Now RivaTuner automatically disables MMIO protection, notifies the user and starts in unprotected mode if the protective system is unable to allocate required protected MMIO range aperture (e.g. due to fragmented or limited kernel address space).Added #opt tag support to driver files database parser to allow including optional driver files in the database. This token was exclusively added to provide detection of ATI's ramdomly named OpenGL ICD drivers.Now RivaTuner uses %RTFolder% macro name when saving a path to external resources (e.g. databases or hardware monitoring log files) stored in the application folder. Power users can disable this feature by setting AllowRelativePathsEncoding registry entry to 0.Minor UI changes and improvements.Download
