Tagan 480 2/2
chill-out
Αρχική απάντηση από pcfreak
τελικα τυχαινει συχνα με αυτα τα tagan :
"After comprehensive analysis of all components we identified the source of the problem. The Tagan-built power supply TG480-U22 delivered a standby voltage of 5V, however could not be turned on again. Our test engineers suspected the Tagan device to be the problem already the day before, since the system demonstrated similar behavior then. Our power supply test station finally cleared any doubts and confirmed this device to be the problem's origin. The failed component from Tagan will stay in THG's test lab in Munich until the end of the test and can be reviewed by the manufacturer.
Tagan's weaknesses are not new to us. A total of five power supplies suddenly failed in our labs during the past year. A newly designed and rubberized casing is unlikely to improve the reliability of the devices. "
Αυτό που αναφέρεις είναι για το Pre-Production Item Of TG480-U22 . Καμμία σχέση με το ΤG480-U01.
Και για του λόγου το αληθές,αντιγραφή από εδω:Final Update :
UPDATE: Pressrelease From MaxPoint (Tagan)
Failure Of Pre-Production Item Of TG480-U22 Within THG Stress-out Test For The Intel System
The results of our revisal of the defective Tagan TG480-U22, which failed within THG Stress-out tests by the Intel system are the following:
The Tagan TG480-U22 power supplies, which we have given to Tom's Hardware Guide for the live-stress-out test between Intel and AMD systems, have been pre-production items. We are glad to detect that something needed to be enhanced before we have started the mass production of the new generation of Tagan Power Supplies.
Within a close examination of the components we figured out that only one transistor - Q1 was defective and the Schottky diode - D30 on the secondary Heat Sink was defective too, moreover the fix screw of this D30 on the Heat Sink was slightly loose. The other components like transistor - Q2, fuse and +5VsB output were all in good condition.
From the defective components we analized that the loosing situation of the lock screw on the D30 Schottky diode caused the heating conduction is not completed and the temperature rising accordingly; this overheat Oscillation of D30 Schottky diode caused the PG signal unstabile and causing the system to be reboot. When the overheat Oscillation of D30 Schottky diode last too long it will cause the Q1 defective.
The reason to cause the D30 Schottky diode to be loosing, we assume, happened by transportation. Within the mass-production of the Tagan TG480-U22 we will take care, that the fixing point of the D30 Schottky diode will be enhanced to avoid such kind of failure in the future.
MaxPoint Handelsges mbH
Παρεπιπτώντος επειδή το έψαξα αρκετά το θέμα βρήκα 5 reviews του ΤG480-U01 και σε όλα έλεγαν τα καλύτερα λόγια.
Δηλαδη, αν καταλαβα καλα, μας λενε να μην τα πολυκουναμε....χαχαχα...οκ.καλου κακου ας βαζουμε και κανα μαξιλαρακι...:p
Ασε φίλε μόλις πήρα ένα,και το κρατούσα σαν εικόνισμα!! :) .Πάντως από τεχνικής και ποιοτικής απόψεως είναι πολύ υψηλών προδιαγραφών. Εχει 2 molex ειδικά για Vga,4 για sata, 8 για συσκευές 5" και 2 για 3.5", ενώ διαθέτει και διπλά 4pin για επεξεργαστή!! Ολα τα καλώδια δε, είναι συνεστραμένα για μείωση των παρεμβολών ενώ διαθέτει και εξωτερική γείωση! Με 28Α στα 12volt και 48(!) στα 5V ,ε νομίζω ότι δεν υπάρχει περίπτωση να το "γονατίσεις" ότι και να βάλεις! Χώρια που έχει ειδικό καλώδιο ρευματος με αντιπαρασιτικό φίλτρο,5 πολύ πρακτικά reusable bandits με scratch (πρώτη φορά είδα κάτι τετοιο...) μέχρι και βίδες ! Δεν ξέρω αν παρόμοιας κλάσης τροφοδοτικά προσφέρουν τα ίδια ή και περισσότερα αλλά σε συγκριση με το chiftec 420 που είχα πάρει πριν 2 χρόνια (με o/c barton ,Χ800ΧΤ,3 σκληρους και 2DVD δυστηχώς δεν άντεχε την... "πίεση" και μάλλον το πρόβλημα ήταν στα 12v αφού εδινε μόνο 18A max) είναι η μέρα με τη νύχτα! Και όλα αυτά με 100euro τελική τιμή (90 είχα πάρει το chiftec!). E, αν το βάλω και δε μου σκάσει( :) ) μάλλον είναι καλή αγορά, έτσι δεν είναι?
Αρχική απάντηση από Gl0bAlZer0
Μια πατατια και τωρα όλοι θα σκεφτονται να το ξαναπροτείνουν ή να το αγοράσουν..:hi:
Και η πατατια μπορει να μην εγινε καν απο την ταγκαν αλλο απο τον εδω εισαγωγεα ή τον αντιστοιχο "απατεωνα" καπου εξω.
Αρχική απάντηση από ikonsgr [28-01-2005 21:18]
To μόνο πρόβλημα του TAGAN είναι τα πολλά καλώδια, δες τι έκανα στο πίσω μέρος του κουτιού για να τα συμμαζέψω....
ώστε χαλάσανε και τα τάγκαν έ? Και μετά λέμε για τα q-tec. Σε 2 υπολογιστές που τόλμησα και έβαλα q-tec πίνουμε στην υγειά τους!!! Δεν έχει κάνει το παραμικρό το συγκεκριμένο τροφοδοτικό. Και τα λεφτά που έμειναν τα έφαγα σουβλάκια λοοολ
