Nec 35XX Firmwares
PGM
  • Replies 224
LD3520 1.UB (Liggy & Dee NEC ND-3520A firmware)
Package contents
Binflash + LD3520 1.UB Firmware
Binflash + LD3520 1.UB Quiet Firmware
The firmware package can be used with Windows, DOS, Linux or MAC. (see minifaq)
Please make sure you read the documentation included in the package.
NOTES
LD3520 1.UB
RIPLOCK REMOVED for fast DVD ripping
LD3520 1.UB QUIET
RIPLOCK enabled for quiet DVD playback on your PC. Please note, this will only playback slow on pressed DVDs. DVD-R and +R media will still play at full drive speed. This is a feature of the STOCK NEC firmware.
Both firmwares share the same strategy edits and speedups.
A Big thanks to Liggy for making his patcher compatible with the ND-3520A drive, and his Binflash flasher utility packaged with this firmware.
Thanks to TDB for the RPC1 patch
This firmware is only compatible with NEC ND-3520 and IO-DATA rebadge
DO NOT try and FLASH a ND-3500 or rebadges drive with this firmware.
Changes
Now supports PI/PIF Disc Quality Scanning with CD-Speed and DVDInfoPro
Now packaged with Binflash 1.16
PLEASE NOTE This firmware only supports Bitsetting on +R DL media at this time. If you require bitsetting for SL +R media, continue to use Version 1.UA
Full media table included in the documentation
info & download @ cdfreaks thread
Όπως το βλέπω έχει τα speedups του 1.UA αλλά βασίζεται στο 3.04 και εχει δυνατότητα PIE/PIF scan. Οπότε δυνατότητα bitsetting σε SL +R δεν υπάρχει για την ώρα. Πάντως λειτουργεί πολύ σωστά.
Link to comment
Share on other sites
LD3520 1.UC (Liggy & Dee NEC ND-3520A firmware)
Package contents
Binflash + LD3520 1.UC Firmware
Binflash + LD3520 1.UC Quiet Firmware
NOTES
LD3520 1.UC
LD3520 1.UC QUIET
An extra big thanks to Liggy for his new bitsetting 3.04 firmware
Changes
Now supports Bitsetting for +R +RW +R DL media
Info Download
Link to comment
Liggy And Dee ND-3500 Modified Firmware V2.TC RC3
LD V2.TC RC3 (Liggy & Dee NEC ND-3500 firmware)
Package contents
Binflash + LD V2.TC RC3 Firmware
Binflash + LD V2.TC RC3 QUIET Firmware
Firmware package can be flashed with Windows, DOS, Linux and MAC (see mini faq)
Full documentation (please read)
NOTES
Release candidate 3
LD V2.TC RC3
LD V2.TC RC3 QUIET
Both firmwares share the same media speedups and strategy swaps
Changes
Now bundled with Binflash 1.15
RITEK F1 F5 speeded to 16X
RITEK R03 rev3 now at 12X (all other revisions remain at 8X)
Improved write quality of RITEK G05
Cleaned up media tables
Info Download
Link to comment
Παλιοτερα υπηρχε και ο Quikee αλλα αυτος παρατησε το αθλημα και εδωσε στο 'λαο' μια εφαρμογη για να γραφει ο καθενας την δικια του writing strategy.
Να ναι καλα τα παιδια να βγαζουν φιρμ ... Ετσι ενημερωτικα η Dee ειναι γυναικα :) Καπου εχω και την φωτο της , ετσι για να ξερετε ποια κυρια μας προμηθευει αυτα τα ωραια firm....
Link to comment
NEC 3520 Original F/W 3.04
Firmwareupdate ND-3520A - Important Information:
[F/W revision Brands]
3.04 (WIN) - 21-Apr-2005
You will find information for firmwareupdate changes here or on our homepage`s FAQ: http://www.de.nec.de
-> Support and Service -> Technical questions -> Optical storage -> DVD / DVD Writer
This Update works only with NEC ND-3520A (retail & bulk) drives, not with OEM releases. OEM means part of a full PC package or external USB or FireWire variant of this burner. For OEM products contact directly your dealer, distributor or manufacturer of PC- or USB/ Firewire- package for service, support and firmwareupdates.
You can only update from Firmwareversion 1 .04. You can verify your current firmware with NERO InfoTool: http://www.nero.com
Info
Download
Link to comment
NEC ND-3500A most used drive
VSO-Software recently released a tool that submits information about the burns made with VSO applications. The information is anonymously sent to the VSO website and the use of it is optional and free. On a page on the VSO website you can find what kind of information is collected. Fortunately many VSO customers are using the tool and a lot of valuable information is gathered.
Unfortunately the numbers of many measurments are currently still too low to give statically correct information which is not strange if you imagine the amount of media and drives currently available. Fortunately the top ten of most popular drives is pretty stable, likwise to the top 5 of brands with the highest success ratio's. Also this time we have included the success ratio's.
Manufacturer Ratio
1 _NEC DVD_RW ND-3500AG 0.922
2 HL-DT-STDVDRAM GSA-4163B 0.953
3 _NEC DVD_RW ND-3520A 0.942
4 PIONEER DVD-RW DVR-108 0.892
5 TSSTcorpCD/DVDW TS-H552B 0.854
6 _NEC DVD_RW ND-2500A 0.937
7 HL-DT-STDVDRAM GSA-4120B 0.928
8 HL-DT-STDVDRAM GSA-4160B 0.939
9 LITE-ON DVDRW SOHW-1633S 0.908
10 PLEXTOR DVDR PX-716A 0.964
Link 1 Link 2
Link to comment
LD3520 1.UD (Liggy & Dee NEC ND-3520A firmware)
Package contents
Binflash + LD3520 1.UD Firmware
Binflash + LD3520 1.UD Quiet Firmware
NOTES
LD3520 1.UD
LD3520 1.UD QUIET
Changes
Verbatim DL Media (MKM001) speeded to 6X
All other +R DL media speeded to 4X
Informations Download
Link to comment
Below is some additional info from the author of CD-Speed.
Originally Posted by ErikDeppe
I haven't been able to test this myself but it seems that NEC fixed a bug with the scanning interval.
To change the scanning interval with Nero CD-DVD Speed the following registry value can be added:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\ahead\Nero Toolkit\CD Speed\CD Quality]
"Scanning Interval"=dword:0000009
To compare with other drives following intervals can be used:
8 ECC (to compare with BenQ/Philips/QSI/Pioneer)
1 ECC (to compare with LiteOn/BTC/Plextor)
32 ECC (to compare with AOpen)
The colored backgrounds and quality score are changed accordingly.
(Liteon drives) using K-Probe @4X scan speed or CD-DVD Speed (disc quality) @4X scan speed.
If scanning with a Benq drive. use CD-DVD Speed (disc Quality) @8X scan speed.
Link to comment
LD3520 1.UE (Liggy & Dee NEC ND-3520A firmware)
Package contents
Binflash + LD3520 1.UE Firmware
Binflash + LD3520 1.UE Quiet Firmware
NOTES
LD3520 1.UE
LD3520 1.UE QUIET
Changes
Thanks to Liggy, we hopefully have a fix for burning DL media. He managed to find some space in the firmware and added some assembler code to the firmware to allow this.
Verbatim DL Media speeded to 6X (Strategy import from 3540 firmware 1.01)
All other +R DL media speeded to 4X, each media now has its own write strategy and speedup. 2.4X uses the medias default strategy, the 4X section has been swapped from MKM001.
RITEK D01 has already been tested and works. The other medias should also burn.
Πληροφοριες
Κατεβαστε το
Link to comment
Έχω και γω μια ερώτηση, βλακία κατά πάσα πιθανότητα, αλλά ερώτηση none the less...
Έχω το 3520 εσωτερικό αλλά το έχω σε εξωτερικό usb2 κουτάκι. Μπορώ να το φιρμάρω εκεί όπως είναι ή πρέπει να το βάλω μάστερ σε κάποιο ide κανάλι?
Link to comment
Αρχική απάντηση από DarkSaga [14-05-2005 23:43]
να ρωτήσω κάτι?
το quiet με τι ταχύτητες ριπάρει ένα μαμα dvd????
Πρεπει να ειναι περιπου 3-5 ωστε να εξασφαλισουν την αθορυβη λειτουργια του drive. Εχε υποψιν σου ομως οτι το rip lock ισχυει για τα original δισκακια. Στα αντιγραμμενα δεν εχει rip lock. Αυτο ειναι χαρακτηριστικο και των original F/W.
Link to comment
LD3520 1.UF (Liggy & Dee NEC ND-3520A firmware)
Package contents
Binflash + LD3520 1.UF Firmware
Binflash + LD3520 1.UF Quiet Firmware
NOTES
LD3520 1.UF
LD3520 1.UF QUIET
Changes
Hopefully improved the burn quality on the following media
+R
YUDEN000T02
MCC004
MCC003
ProdiscR03
CMCMAG E01
RICOH JPRN02
RITEK R03 R2
INFOME R02
-R
MCC02RG20
MCC03RG20
TYG02
TYG03
RITEKG04
RITEKG05
CMCMAG AE1
New write strategies imported from 3540 firmware 1.01b for +R DL media.
Added Version History text file in the download package.
Πληροφοριες
Link to comment
  • 3 weeks later...
