Nec 35XX Firmwares
PGM
  • Replies 224
Quikee 3500AG 2.28 Version 3 Firmware Beta 3
Αλλαγες
Notes:
13x CAV -> 12x Z-CLV for all 16x capable disc.
Milestone Extreme Fixes:
MAXELL 002 -> YUDEN000T02 (8x->16x)
CMC MAG. AF1 -> MCC02RG20 (4x->12x)
CMC MAG. AE1 -> MCC02RG20 (8x->12x)
DVD-R
BeAll G40001 -> 4x6x8x MCC01RG20
TYG01 -> TYG02
New:
MBI 01RG20 -> MCC01RG20 -> 4x6x8x TYG01 / 10x12x MCC02RG20
AN31(2,3,4,5) -> 4x AN31 / 6x8x TYG02
VDSPMSAB 01 -> FUJIFILM03 Limit 6x
MCC02RG20 -> 4x6x8x10x12x MCC02RG20 / 14x16xYUDEN000T02
RITEKG05 -> 4x6x8x RITEKG05 / 10x12x YUDEN000T02
TTH01 -> YUDEN000T02
SONY08D1 -> YUDEN000T02
SONY04D1 -> 4x6x8x MCC01RG20 / 10x12x YUDEN000T02
PRODISCF01 -> 4x6x8x PRODISCF01 / 10x12x MCC02RG20
TTG02 -> 4x6x8x TTG02 / 10x12xMCC02RG20 / 14x16x YUDEN000T02
MCC02RG20 -> 4x6x8x MCC01RG20 / 10x12x MCC02RG20 / 14x16xMBI03RG40
INFOSMART01 -> TTG02
LEADDATA01 -> TTG02
OPTODISCR008 -> 4x6x8x OPTODISCR008 / 10x12x PRODISCR03
Need Results:
CMC MAG. AF01 -> 4x6x8x MCC01RG20
RITEKG03 -> 4x6x8x MCC01RG20
RITEKG04 01 -> 4x6x8x MCC01RG20 / 10x12x MCC02RG20
MUST 001 -> MUST 003
PRODISCS04 -> 4x6x8x MCC01RG20 / 10x12x MCC02RG20
RITEKM02 DVD-R -> 4x6x8x MCC01RG20 / 10x12x MCC02RG20
DVD+R
New:
YUDEN000T00 -> 4x6x8x YUDEN000T01-001 / 10x12x YUDEN000T02
YUDEN000T01-000 -> 4x6x8x YUDEN000T01-001 / 10x12x YUDEN000T02
YUDEN000T01-001 -> 4x6x8x YUDEN000T01-001 / 10x12x YUDEN000T02
RICOHJPNR01 -> 4x6x8x RICOHJPNR01 / 10x12x RICOHJPNR02
RITEKR02 -> 4x6x8x RITEKR03 / 10x12x YUDEN000T02
RITEKR03 -> 4x6x8x RITEKR03 / 10x12x YUDEN000T02
RITEKR03-001 -> RITEKR03 Lim. 8x
IS01001 -> 4x6x8x MCC003 / 10x12x MCC02RG20
Need Results:
BeAll000P40 -> 4x6x8x MCC003 / 10x12x MCC02RG20
BeAll000P80 -> 4x6x8x MCC003 / 10x12x MCC02RG20
OPTODISCOR8 -> 4x6x8x OPTODISCOR8 / 10x12x RICOHJPNR02
PRODISCR02 -> YUDEN000T01-001
PHILIPS C16 -> TDK 002
ΚΑΤΕΒΑΣΤΕ ΤΟ : http://freeweb.siol.net/tvajng/Quikee_V3B3.rar
__________________
Updated: Στο κατω μερος απο το πρωτο ποστ αυτου του θρετ εχουν προστεθει καποια review ετσι ωστε οι υποψηφιοι αγοραστες να δουν τα χαρακτηριστικα και καποιες δοκιμες αυτου του drive. Με το καιρο βεβαια θα προστεθουν και αλλα.....
PGM θεικο το nec το πηρα πριν λιγο απο plaisio και ειναι τελιο!!!!!!!!!!!!!!!!!!!!!
μπορεισ να μου πεισ ποιο ειναι το καλητερο firmware για να βαλω?????????????
πλιζζζζζζζζζζζζζζζζζζζζζζζζζζζζζζζζζζζζ
Ε καλά τώρα μην τρελαθούμε που θέλετε να αυξήσετε την ταχύτητα των writers λόγω έλλειψης χρόνου!!!!!! :slap:
Δεν νομίζω να ήσασταν σε αυτό το φορουμ αν δεν είχατε χρόνο. :p
ΜΙΚΡΟΒΙΟ έχετε που δεν φεύγει.;) ;)
Αρχική απάντηση από D.J.AleXXX_gr [Σήμερα, στις 18:06]
Εγω εδω και καιρο εχω μεινει με του Quikee to 2.28 millestone extreme edition χωρις να εχω αντιμετωπισει κανενα προβλημα...
Αρχική απάντηση από PGM [Σήμερα, στις 20:05]
Aφου ξεζιπαρω το αρχιο τι το κανω???? το βαζω σε κανα directory???????
Αρχική απάντηση από D.J.AleXXX_gr [Σήμερα, στις 20:10]
1.Κανεις extract to αρχειο με το firm που κατεβασες.
2. Κατεβαζεις το Necwinflash (την Win32 GUI εκδοση κατεβασε). Πληροφοριες μπορεις δεις εδω : http://binflash.cdfreaks.com/ . Το κανεις extract το φακελο και μετα τρεχεις το προγραμμα. Πατας flash , βρισκεις το firmware εχεις ηδη κατεβασει απο πριν και πατας οκ..
Αν εχεις αλλες αποριες εδω ειμαστε .....
Έχω το NEC3500Α σε usb2.0 κουτί plextor. Μου καίει τα άπειρα δισκάκια. ’υριο το πάω για rma στο πλαίσιο. Firmware είχα βάλει μια φόρα ένα τελευταίο που βρήκα στο site της NEC.
Πριν με ένα samsung κόλλησε στο 91% τώρα με princo σταμάτησε στο 93%.
PGM καταρχην θελω να σε ευχαριστησω προκαταβολικα για την βοηθεια που μου εχεις προσφερει. Ευτυχως που ποσταρες στο φορουμ των cdfreaks και ειδα οτι υπαρχουν πατριωτακια που ασχολουνται με το αθλημα.Συγχαρτηρια για το site και το forum!!!
Αγορασα και εγω προσφατα το 3500AG και αρχισα και ψαχνομαι με τις δυνατοτητες του καθοτι newbie:cool:
Εχω καποιες αποριες, αν μπορεις να απαντησεις:
α) κατεβασα την 2.28 που εχεις και εσυ. Αυτο σημαινει οτι μπορω να εκμεταλλευομαι τις νεες ταχυτητες μονο με DVD+R και οχι -R;
β) Αγορασα ενα πακετο με 25 dvd+R απο το πλαισιο μαρκας acro circle δυστυχως πριν δω τη λιστα με τις υποστηριζομενες μαρκες της NEC, στην οποια -αν δεν κανω λαθος- δεν υπαρχουν μεσα. Θα εχω προβλημα αν τα χρησιμοπιησω;
Αρχική απάντηση από vaggos [Σήμερα, στις 10:47]
Καλως ηρθες στο φορουμ φιλε και καλη χρονια !
α. Να σου πω την αληθεια με τις writing strategies των -R δεν εχω ασχοληθει αλλα σιγουρα εχει κανει καποιες αλλαγες....πες μας τι δισκακια σκοπευεις να χρηισμοποιησεις για να δουμε σε τι ταχυτητες μπορεις να 'καψεις'.
b. Με μια προχειρη ματια που εριξα στου Quikee το firm δεν βρηκα καποιο writing strategy για τα συγκεκριμενα δισκακια αλλα δεν θα εχεις κανενα προβλημα να τα χρησιμοποιησεις . To nero τι maximum ταχυτητα σου βγαζει ?
Y.Γ Παντως αν θες φτηνα και ποιοτητικα δισκακια θα σου προτεινα τα TY +R 4x τα οποια γραφωνται σε 8χ με εξαιρετικη ποιοτητα. Λιγο ακριβοτερα ειναι τα ΤΥ +R 8x αλλα μπορουν να γραφτουν με 16χ !!!
Για τιμες τσεκαρε www.e-shop.gr και Discimpex .
Update:
Reason:Βγηκε η τελικη εκδοση του NecDump: Firmware Infomation Dumping Tool.
Μπορειτε να το κατεβασετε απο το πρωτο ποστ αυτου του θρετ.
Αρχική απάντηση από totally_wired [Σήμερα, στις 15:37]
Μήπως το NEC μου χάλασε επειδή έκανα update στο firmware χωρίς να το έχω σε ide αλλά στο usb2.0 case?
Δεν νομιζω οτι φταιει αυτο ...δες και εδω http://club.cdfreaks.com/showthread.php?t=119922
Για δωσε λιγο λεπτομερειες για το πως το φλασαρες....
Το φλάσαρα μέσα από τα windows με τα προγράμματα πού βρήκα στο site της NEC. Το winflash. Είναι αρκετά αναξιόπιστο. Δεν φταίει ούτε το pc μιας και έχει δοκιμαστεί σε 2, ούτε το κουτί μιας και έχει μπεί και plextor πάνω. Ούτε τα δισκάκια φταίνε.
Διάβασα το link και ένας έχει κάνει ότι και εγώ και έπαιζε σωστά. Δεν ξέρω... Απλά έχω κάψει σχεδόν τόσα όσα έχω γράψει!!!!!
Σήμερα πήγα στο πλαίσιο και με δώσανε νέο και η κατάσταση έγινε χειρότερη. Βγάζει σφάλμα απο το LeadIn...
Δεν ξέρω τι να κάνω πλέον...
Υπάρχει και το log
