Πολλά λεφτά, πάρα πολλά αλλά είναι some serious modified hi tech shit:
  Quote
The Toyota GR Corolla already has a firecracker of an engine. The 1.6-liter G16E-GTS turbo three-cylinder can hold over 700 horsepower on stock internals, and more will be possible when the aftermarket cracks it open. Soon, one of the biggest names in the tuning game will, because HKS has announced it'll build GR Corolla crate engines. Not only will they be bigger, stroked-out motors, but they'll use Formula 1-style ignition technology.
HKS detailed the project on its website, where it describes how it has modified a prototype for the "complete engine" it will eventually sell. For starters, HKS is incorporating a custom crankshaft that's been designed so the shop can delete the engine's balance shaft. Its stroke has been lengthened from 89.7 millimeters to 95.7, which will increase torque throughout the rev range. Cylinder bores have also been expanded by 0.5 mm, enlarging the engine to 1,746cc in total. There's no replacement for displacement, as they say, and this'll get the turbo spooled quicker. It also decreases the compression ratio from 10.5:1 to 10:1, allowing greater boost tolerance.
Expand
WWW.THEDRIVE.COM
Now we want an inline-six version of this engine even more.
  • Plits 1
η μεταδοση αντεχει τοσα αλογα/ροπη?
  Reveal hidden contents
Έγινε επεξεργασία από BloodMage
  On 10/6/2024 at 9:15 ΠΜ, το μέλος BloodMage έγραψε:
Expand
Καλά μόλις τσέκαρα, 37 κιλα ροπή στοκ, πόσα να βγάζει το βελτιωμένο 50?
30 κιλά ροπή έχει το κόρσα μου ρε. ΚΑΙ δεν είναι καν κανονικό αυτοκίνητο, ΕΙΝΑΙ ΟΠΕΛ ΓΤΧΣ!!!
  On 10/6/2024 at 11:39 ΠΜ, το μέλος Cyber_Cookie έγραψε:
Expand
αληθεια τωρα?
και το ST που εχω ειναι 32 κιλα, τι παει να πει? 1 ες 2ες γραφει σε οτι ασφαλτο και ειμαι
μην συγκρινεις ξερα νουμερα
χ2 diesel φιλου εχει 30 κιλα ροπη, αλλα μολις 130 αλογα
η ροπη απο μονη της δεν λεει κατι. σε ποιο φασμα στροφων την βγαζει ειναι ολα τα λεφτα
  • Haha 2
