USB Flash Info Tool
felix
Transcend Jetflash 810 16gb usb 3.0
Volume: G:
Controller: Innostor IS916EN A3
Possible Memory Chip(s):
Samsung K9ACGD8U0Ax2
Samsung K9ACGD8U0A *2
Memory Type: TLC
Flash ID: ECDE98CE 74C4
Flash CE: 2
Flash Channels: Single
Chip F/W: 1.13.02.10
VID: 8564
PID: 1000
Manufacturer: JetFlash
Product: Mass Storage Device
Query Vendor ID: JetFlash
Query Product ID: Transcend 16GB
Query Product Revision: 1.00
Physical Disk Capacity: 15804137472 Bytes
Windows Disk Capacity: 15803084800 Bytes
Internal Tags: CZXD-QCF3
File System: NTFS
Relative Offset: 1024 KB
USB Version: 3.00 in 2.00 port
Declared Power: 200 mA
ContMeas ID: 39D1-01-00
Microsoft Windows 8 x64
http://www.antspec.com/usbflashinfo/
Program Version: 8.0.0.550
πωωω tlc έχει το ρημάδι... τουλαχιστον το πήρα 8 ευρώ και έχει 80mb/s read, 12 mb/s write και lifetime warranty
Transcend Jetflash 110 4gb
Volume: G:
Controller: USBest UT161 compatible
Possible Memory Chip(s): Not available
VID: 0457
PID: 0151
Product: USB Mass Storage Device
Query Product ID: TS4GJF110
Query Product Revision: 0.00
Physical Disk Capacity: 4110417920 Bytes
Windows Disk Capacity: 4094373888 Bytes
Internal Tags: LHZK-9V7K
File System: FAT32
Relative Offset: 31 KB
USB Version: 2.00
Declared Power: 98 mA
Link to comment
Share on other sites
Το as ssd benchmark είναι αξιόπιστο? Μου βγάζει bad τον ssd (samsung 830).
Γενικότερα, τί παίζει με το offset?
Αξιοπιστο ειναι 100%. Φτιαξε το offset στον ssd σου. Λογικα έχεις αρκετα πεσμενες επιδοσεις. Φτιαξε θεμα και δωσε screenshot.
Link to comment
[B]Adata S102 Pro 64GB[/B]
Volume: D:
Controller: Silicon Motion SM3261 AAS
Flash ID: 89A825CB A9
Flash CE: 2+2
Flash Channels: Dual
Chip F/W: ISP 130311-1AB
MP: M0318V2
MPTOOL Ver.: 2.05.16
VID: 125F
PID: 312B
Manufacturer: ADATA
Product: ADATA USB Flash Drive
Query Vendor ID: ADATA
Query Product ID: USB Flash Drive
Query Product Revision: 1100
Physical Disk Capacity: 63854084096 Bytes
Windows Disk Capacity: 63836094464 Bytes
Internal Tags: 8V2M-T93K
File System: NTFS
Relative Offset: 17552 KB
USB Version: 3.00
Declared Power: 504 mA
ContMeas ID: 0EAD-01-FC
[b]Sandisk Extreme USB 64GB 3.0[/b]
Volume: G:
Controller: SanDisk
VID: 0781
PID: 5580
Manufacturer: SanDisk
Product: Extreme
Query Vendor ID: SanDisk
Query Product ID: Extreme
Query Product Revision: 0001
Physical Disk Capacity: 64023257088 Bytes
Windows Disk Capacity: 64016154624 Bytes
Internal Tags: BW4F-QAH3
File System: NTFS
Relative Offset: 16 KB
USB Version: 3.00
Declared Power: 400 mA
ContMeas ID: 0EAD-01-00
Link to comment
@NTG
Εδώ εισαι, και δεν έχει 4Κ στο AS SSD γιατί τελειοσε το qualifying session (μαζί με Pre-Quali kai post-Quali) και το AS SSD δεν είχε ακόμα τελείωση με το 4Κ Write.
Απο δεύτερα θα δοκιμάσω να το κάνω ένα format να δω τι θα αλλάξει.
Link to comment
Corsair Voyager GTR 32 GB
Volume: J:
Controller: ITE IT1168 A1CA
Intel 29F16B16MCME1
Intel 29F16B08CAME1
Intel 29F16B08CCME3
Intel 29F16B08CCME2
Memory Type: MLC
Flash ID: 8988244B A9
Flash CE Summary: 2
Internal Version: 1.68.4.72:1228
FlashDB: 1511
FW Date: 2011-08-20 16:12:41
FW Ver.: FMLG2.03S
VID: 1B1C
PID: 1A97
Manufacturer: Corsair
Product: Voyager GTR
Query Vendor ID: Corsair
Query Product ID: Voyager GTR
Physical Disk Capacity: 32480690176 Bytes
Windows Disk Capacity: 32479637504 Bytes
Internal Tags: 4P2M-996J
File System: NTFS
USB Version: 2.00
Declared Power: 480 mA
ContMeas ID: 1084-01-00
Microsoft Windows 7 SP1 x64
SANDISK ULTRA USB 3.0 16GB
Program Version: 8.0.0.550 Volume: J:
Controller: Phison 2303 (2251-03)
SanDisk SDTNQCAMA-016G
Memory Type: TLC
Flash ID: 454CA892 7657
Chip F/W: 01.08.53
Firmware Date: 2013-07-16
ID_BLK Ver.: 1.2.43.0
MP Ver.: MPALL v3.70.0E
VID: 0781
PID: 5581
Product: SanDisk Ultra
Query Product ID: SanDisk Ultra
Query Product Revision: PMAP
Physical Disk Capacity: 15504900096 Bytes
Windows Disk Capacity: 15500767232 Bytes
Internal Tags: 2Q2K-S72J
File System: NTFS
Relative Offset: 4032 KB
Declared Power: 300 mA
Link to comment
Ολα τα στικακια που εχω αυτη τη στιγμη
Δεν με βρηκε το Lexar μονο και το m2 με τον ανταπτορα(οκ αυτο κομματακι
χλωμο)
Volume: F:
Controller: USBest UT165 A1B
Intel 29F32G08AAMDB
Intel 29F32G08AAMDA
Intel 29F32G08AAMDD
Memory Type: MLC
Flash ID: 89680446 A9
MP Ver.: 1C.2B.57.04
Chip F/W: BM0793
VID: 1B1C
PID: 0B29
Product: Voyager Mini
Query Product ID: Voyager Mini
Physical Disk Capacity: 4040748544 Bytes
Windows Disk Capacity: 4032356352 Bytes
Internal Tags: 3GZD-LAEK
File System: FAT32
USB Version: 2.00
ContMeas ID: 246E-01-00
Volume: F:
SanDisk SDTNQCAMA-008G *2
SanDisk SDTNQCAMA-008Gx2
Memory Type: TLC
Flash ID: 45DE9892 7257
Flash CE: 2
Chip F/W: 1.04.02.20
VID: 125F
PID: C13A
Manufacturer: ADATA
Physical Disk Capacity: 15805186048 Bytes
Windows Disk Capacity: 15805116416 Bytes
Internal Tags: CZ2D-QCBK
File System: NTFS
Relative Offset: 64 KB
Volume: F:
Toshiba TH58NVG8T2JTA20
Toshiba TH58TEG8T2JBA4C
Toshiba TH58TEG8T2JTA20
Toshiba TC58NVG7T2JTA00
Toshiba TC58TEG7T2JTA00
Memory Type: TLC
Flash ID: 983AA892 76D7
Chip F/W: 01.08.53
Firmware Date: 2013-09-05
ID_BLK Ver.: 1.2.60.0
MP Ver.: MPALL v3.71.0C
VID: 1B1C
PID: 1A0C
Product: Voyager Mini 3.0
Query Product ID: Voyager Mini 3.0
Physical Disk Capacity: 31009800192 Bytes
Windows Disk Capacity: 31005667328 Bytes
Internal Tags: 2Q2K-S72K
File System: NTFS
Link to comment
