ΑΠΑΤΗ Η ΑΛΗΘΕΙΑ?
Kanonieris
Υπάρχει και το συγκεκριμένο κομμάτι το ποποίο με βάζει και σκεφτομαι
There is no catch - the software versions that we sell are OEM (Original Equipment Manufacturer) which means you will receive the installation CDs only (they do not come in their original retail packing and do not include the manual). We do guarantee that all programs are the 100% full working retail versions - no demos or academic versions. When you order, you will receive all materials required for a complete installation - or your money back. Why should you pay hundreds of dollars more if you can get exactly the same product but much cheaper? You don't have to pay that much for the fancy box and manuals.
Επισης λεει : Be aware that you will not be able to register the software with the manufacturer. Some of these products cannot be updated on-line.
The software is shipped from Eastern Europe :bye:
Even though you are not able to register the product online you will be able to receive automatic updates of the programs. When updates are ready to install you will see a popup window or an icon at the right bottom corner of your screen. Then you have to click on the icon and follow the instructions.
Επισης ακουστικε οτι η M$ θα τσεκαρει στο μελλον και τα σεριαλ των λειτουργικων για να κανεισ live update.
