@gchristod, άλλο πράγμα είναι το damping. Αυτό που λέει ο liak αλλάζει το gain ανά % force ώστε να ισιώσει την καμπύλη απόκρισης.
Σαν equalizer για το ffb δηλαδή.
Ναι, το κατάλαβα τώρα :) Αργώ λίγο αλλά τα πιάνω[emoji14]Είχα ξεχάσει ότι το assetto έχει ξεχωριστή λειτουργία filter.
Αναρωτηθήκατε ποτέ γιατί υπάρχει φάκελος skins στις πίστες της Kunos?
Εεεεε να λοιπόν   :tongueout:
Spa light snow/hard frost
http://www.mediafire.com/download/uijlyttq88oq98m/default.zip
Extract τον φάκελο default στο \SteamLibrary\steamapps\common\assettocorsa\content\tracks\spa\skins\
Πηγή:
Stop Drop Gaming Forum
  • Like 4
Θα προτιμούσα 1000 φορές να έτρεχα παρά να έβαζα νέα, αλλά....
Τhe development of Assetto Corsa began in 2011. Since then, we have vastly improved our modelling techniques – today we have more resources (budget and manpower) and expertise, and the latest laser-scanning technology also allows us to obtain a better and wider scan, offering an opportunity to grab a higher number of objects surrounding the track. Moreover, during the development of Assetto Corsa, we have changed our approach to texturing and track modelling, creating more secondary details and trackside objects and also featuring 3D trees and camera-facing objects and crowds, something that resulted in nicer scenarios and better immersion. However, as a result there is now a visible gap in terms of graphics and details if you compare some of the first and the latest circuits created for Assetto Corsa.
Last year we made some tests with a new laser-scanning device, testing it at our HQ at Vallelunga race track, where we made our preliminary tests in early 2010 in preparation for the Ferrari Virtual Academy videogame. Since our aim is to offer our fans the best of our skills, know-how and quality, we are glad to tell you that we have started the process of optimizing and improving all our existing circuits, including Vallelunga, Nurburgring GP, Mugello, Magione, Imola, Silverstone, Monza, Spa Francorchamps, as well as the Nordschleife. The upgraded versions of these tracks will be available as a free update with build 1.5, currently in development.
Thank you very much for your great support!
12621945_1323632407663074_52368747104777
12657335_1323632404329741_53297931637289
12671936_1323632344329747_73445122229404
11257960_1323632514329730_19383168578384
Έγινε επεξεργασία από liakjim
ενα κακο για μενα στο immersion του παιχνιδιου ειναι οτι δεν κουνιεται τιποτα στην πιστα... ειναι ολα παγωμενα. δε το αισθανεσαι ζωντανο το μερος. εχουν βαλει καμια σημαια απο δω κι απο κει αλλα αυτο δεν ειναι τιποτα.
βαλε δεντρα σημαιες κοσμο κατι. κινηση στα πιτ ισως.
φτιαχνουν το ενα χαλανε το αλλο..
Καλυτερη η ασφαλτος  αλλα χαλασανε το enviroment..
Μα τωρα ειναι δυνατον αυτο το ασχημο "blend" του γρασιδιου με την αμμο ;
Ναι όταν τρέχεις εσύ, βλέπεις το blend in στην άμμο και όχι το περιβάλλον..
Το θέμα είναι ότι σε ένα δωρεάν update θα πάρουμε αναβάθμιση σε πολλές πίστες.
Δεν νομίζω ότι χωράει γκρίνια σε αυτό πόσο μάλλον σε WIP δουλειά.
Ας βγουν και πες μετά τί σε χάλασε.
Ναι γιατι οταν τρεχεις βλεπεις εσυ τα face to cam planes με θαμνους!!!
Βρε Δημητρη , τα παντα ειναι για το "οταν τρεχω" ? Τοσες συζητησεις εχουμε κανει για το replay του παιχνιδιου και τις καμερες.
Ε , αν το αφησουν ετσι...(λεω ΑΝ , αυτο βλεπω αυτο κρινω) δε θα ειναι μλκια ; Δεν ειναι παντα για το οταν τρεχω.
Ε , αν το αφησουν ετσι...(λεω ΑΝ , αυτο παρουσιασαν αυτο κρινω) δε θα ειναι μλκια ; Δεν ειναι παντα για το οταν τρεχω.
Δε καταλαβαινω γιατι επειδη ειναι WIP θα πρεπει να λεμε μονο καλα λογια ;
edit : ατιμο φορουμ..
Έγινε επεξεργασία από GoMaR
Δώστε κατιτίς να μείνει ανοιχτό το rsr.. Ξεφτίλα με τόσους users να μη μπορεί να μαζέψει 300 ευρώ...
http://www.radiators-champ.com/rsrworld/apps/
θα τα μαζέψει... 206 θέλει ακόμα (http://www.radiators-champ.com/rsrworld/apps/) :) ... Αλλά η απορία μου είναι γιατί να μπαίνουν σε αυτή τη διαδικασία, ενώ με 1-2 χορηγούς (διαφημιστικά banners) θα έβγαζαν πολλά περισσότερα με τόσους users!
Αν είχα e-shop, ή μαγαζί που πουλάει ανταλλακτικά αυτοκινήτων, ή σχολή οδηγών, ή ενοικιάσεις αυτοκινήτων, ή δε ξέρω και γω τι άλλο, θα τους έδινα από την τσέπη μου 300 ευρώ με αντάλλαγμα τη διαφήμιση (banner).
Θα τα μαζέψει σίγουρα. Το θέμα είναι ότι θα τα μαζέψει από 20 άτομα με το userbase να φτάνει τους 20.000.
Και ανάγκη από χρήματα να μην είχαν (μιλάμε για γελοίο ποσό), ένα donation το αξίζουν για τις υπηρεσίες που προσφέρουν.
