v1.4 changelog
- New reflection rendering system
- HDR now matches real life photographic references
- Improved AI ability to stick to the intended racing line
- Improved AI braking code (able to understand and use locked inside tyre for FWD)
- Vastly improved multiplayer antilag/antiwarp system
- Fixed missing ksBrakeDisc script in all the remaining cars.
- Tweaked wet volume for reverb on high distance
- Tweaked dynamics for Audi R8 Plus interior sound
- New Bmw M3 e30 DTM and Group A exterior sounds
- New font rendering system for dashboards
- Fixed fadeout timing for gravel particles
- Improved digital instruments of all cars
- Fixed some bugged special events
- Tweaked most of the special events to be compatible with tyre model 5/6
- FXAA is now using Kunos' own shader
- Fixed blurred rim/tyres on car with animated suspensions on farther Lods
- ksEditor: added node grid
- Introduced [DRS_ZONES] IGNORE_ZONES in drs.ini to allow road cars to ignore DRS zones (ie. McLaren P1)
- Fixed exaggerate motion blur for some camera modes
- Added serial opponent selection on Options->General: if flagged then opponents skin is not randomly chosen, but alphabetically
- Fixed unrealistic qualify times when session is skipped
- Fixed LaFerrari rear wheels
- Fixed Huracan GT3 model to update it from the pre-season version
- GT3 and GT2 cars tyre heating improvements
- Ferrari 312T Tyre v6
- Audi R8 Plus front torque vectoring and central differential improvements.
- Headlights revised on all cars
- Added missing dashboard lighting to cars where present
- Fixed various LOD issues on a large number of cars
- Car shader overhaul
- Skins fixes and updates on various cars
- Added templates for DP3 cars and Audi R8 Plus
- Optimization across the entire car range (should help with large fields)
- Digital instrument updates
- Fixed collision boxes on various cars
Με bold αυτά που θεωρώ σημαντικά.
Με κόκκινο αυτά που με απογοήτευσαν. Θα ήθελα όλα τα αμάξια στο V6 tyre model.
Έγινε επεξεργασία από liakjim
omg omg omgomgosrmgpsrogm
αντίο ζωή
Βαλε μια καμερα της προκοπης ρε nooba για να μην σου κανω force την εσωτερικη.  :rofl:
Αρχικές εντυπώσεις.
  • Τα γραφικά με ξένισαν. Νομίζω πάνε προς cartoon κατάσταση κ δεν μου αρέσει καθόλου. Νομίζω είναι χειρότερα. Ο ουρανός άσπρος...Το FXAA ακόμα αφήνει jaggies παρόλο το ΑΑΧ4.
  • Το ΑΙ νομίζω καλυτερο.
  • Η πίστα καταπληκτική.
  • Το FFB μου φαίνεται χειρότερο. Πιο βαρύ. Πάμε πάλι σε κάτι 65%.
  • Αμάξια:
- Features Abarth 500 Assetto Corse (αδιάφορο)
- Features Ford Escort RS 1600 (απίστευτο)
- Features Lotus 25 ( καταπληκτικό. Το καλύτερο από το πακέτο).
- Features Lotus 72 ( πολύ καλό. Ταιριάζει με την 312).
- Features LAMBORGHINI Gallardo SuperLeggera ( πολύ καλό. Το S3 κόλαση).
- Features LAMBORGHINI HURACAN SuperTrofeo ( πιο ενδιαφέρον από τα GT3)
- Features McLaren 650 GT3 (Άλλαξε ο Μανολιός και έβαλε τα ρούχα του αλλιώς . Ίδιο σε ήχο κ αίσθηση με το παλιό)
- Features Mercedes-Benz AMG GT3 ( φοβερός ήχος ).
Γενικά δεν μου αρέσει το 1.4 . Multy δεν δοκίμασα. Θα περιμένω pp mods.
Έχω αρκετό καιρό να ασχοληθώ με το Assetto και πιθανόν να έχω συνηθίσει άλλα sims αλλά δυστυχώς δεν μου άρεσε καθόλου το FFB, το βρήκα πολύ βαρύ και χωρίς καθόλου πληροφόρηση για το grip που έχουν τα λάστιχα σε σημείο που να μου φαίνεται αδύνατο να οδηγήσω γρήγορα και με εμπιστοσύνη.
To αγόρασα κυρίως για να υποστηρίξω την Kunos και για το Ford Escort  αλλά  ενώ πηγαίνει με τις πόρτες το FFB πάλι ήταν ο αδύναμος κρίκος, το πιθανότερο είναι να με έχει καλομάθει το καταπληκτικό FFB που δίνει το rFactor 2 σε παρόμοιες καταστάσεις. Πολύ καλή η νέα πίστα άν και είναι καιρός η Kunos να αρχίσει να μας δίνει και αμερικάνικες πίστες με τα DLC.
Η αλήθεια είναι πως ψιλοξενέρωσα και δεν του έδωσα τον απαιτούμενο χρόνο, ίσως να πρέπει να ψάξω να βρώ κατάλληλα FFB settings γιατί σίγουρα υπάρχουν σημαντικές αλλαγές και είχα τα ίδια settings από το καλοκαίρι που σταμάτησα να παίζω.
geovas τικαρισες το enhanched understreet effect? στο andvced ...και εκτος αυτου δεν ειναι το ffb για ολα τα αυτοκινητα το ιδιο
με το +- στα πληκτρα μπορεις ingame να ελαφρυνεις το τιμονι αν θες....σιγουρα θα χρειαζεσαι και καποιο σεταρισμα στο μενου πιστευω
η πιστα δεν με ενθουσιασε,μου φαινεται οτι βιαζονται τελευταια, αλλα ουτε στο pcars ειναι απο τις πιστες που μου αρεσουν...νομιζω οι πρωτες πιστες mugello,vallelunga,imola κλπ,κλπ ειναι σε αλλο level  :(
Το ffb το βρισκω λιγο διαφορετικο,δεν ξερω αν μου αρεσει περισσοτερο απο το προηγουμενο
Έγινε επεξεργασία από kyr..
Εμένα το συγκεκριμένο update+dlc μου άρεσε περισσότερο απ'όλα και η έκπληξη είναι οτι δε το περίμενα με τίποτα. Όταν έμαθα τι αυτοκίνητα θα έχει ενδιαφέρθηκα μόνο για το escort οπότε δε περίμενα κάτι διακαώς για να γράψω διθυραμβικά σχόλια μετά το release.
Να ξεκινήσω απο τα γραφικά?Απλά υπέροχα,δε θα επεκταθώ περισσότερο.
Τα αυτοκίνητα? Μου άρεσαν όλα πάρα πολύ εκτός τις Lambo που επίσης απογοητεύτηκα γιατί νόμιζα ότι η gallardo θα ήταν η μαμά... H shifter.
Οι lotus απλά καταπληκτικές και ειδικά η type 25 που δε περίμενα με τίποτα ότι πρώτον θα μου αρέσει και δεύτερον θα χαμογελάω σαν χαζός οδηγώντας τη.
Καλά το escort μάλλον είναι το αγαπημένο μου αυτοκίνητο πλέον.
Το abarth... ΕΠΙΤΕΛΟΥΣ αγαπημένο μου κουβαδάκι επέστρεψες απο το Nkpro,ακόμα πιο ζωντανό!
Την branch την έπαιξα πρώτη φορά στο nkpro και με είχε ξετρελάνει,ειδικά με την formula2000. Η laser scanned εκδοχή της είναι καταπληκτική,τα κέρμπ στη k2 σου έρχεται να τα φας!!!
Τώρα για το ffb που λέτε,πρώτον δε βλέπω να άλλαξε κάτι στο changelog αλλά νιώθω ότι κάτι άλλαξε(βασικά δε δοκίμασα κάποιο απο τα "παλιά" αυτοκίνητα για να το πω με σιγουριά). Σε αντίθεση με τον geova εγώ νιώθω τα πάντα,μέχρι και πως τρίβεται η γόμα στο οδόστρωμα,πως πιέζεται ο αέρας απο τα λάστιχα κάτω απο πίεση στις στροφές,ένα άλλο πράγμα νιώθω,υπέροχο! Δε ξέρω,αν έχετε g27 μήπως να σας δώσω τις ρυθμίσεις μου?Μήπως είναι η ιδέα μου?Δε νομίζω γιατί πραγματικά τις νιώθω όλες τις δυνάμεις στο ffb.
See you on track παιδιά,ελπίζω ειλικρινά να μπορώ να τρέχω σε περισσότερους αγώνες αλλά πάντα μα πάντα κάτι τυχαίνει όταν θέλω να παίξω AC. Πάντα όμως,απο το release date που δεν ήμουν στο σπίτι μου για 1-2 βδομάδες ώστε να το αγοράσω day1,απο το πρώτο dlc που πάλι δεν ήμουν σπιτι κτλ
Σας κούρασα το μυαλό και ζητώ συγνώμη!
  • Like 5
Καλημερα!Και δεν μας τις δινεις ετσι να τις εχουμε?
Η εδω η σε πμ οπως σε βολευει..
Κι εμένα το ffb μου φαίνεται βαρύ... Ειδικά αν βγω στα χωράφια και πάω να στρίψω το τιμόνι ενώ είμαι σταματημένος, θέλει πολύ δύναμη! Στο pCars είναι ακόμα πιο βαρύ! Άρα κάτι παίζει με την G29... Πρέπει να βρω ρυθμίσεις για G29 μάλλον. Έχει κανείς;
Καταπληκτικο το update...σε ολα του!!!
Δεν ξερω τι λετε για την 650S αλλά δεν εχει καμια μα καμια σχεση με την mp12-gt3...αλλο αυτοκινητο.
Οι δυο lotus με εξεπληξαν ευχαριστα. Το μερσεντικο οχι και τοσο...
Οσον αφορα το ffb δεν ειδα καποια διαφορα...ισως να ειναι ελαχιστα πιο σκληρο αλλά και παλι σε καθε αυτοκινητο το ρυθμιζεις εκει που θες.
  • Like 3
Πρόλαβα μόνο την lotus type 25 να δοκιμάσω και μπορώ να πω ότι η FF μου άρεσε πολύ αφού ένοιωθα πολύ καλά το αυτοκίνητο. Μου άρεσε πολύ - όταν έχανα τον έλεγχο και είχα έξοδο, το αυτοκίνητο συμπεριφερόταν πολύ ποιο φυσιολογικά από ότι περίμενα (στα όρια) και η διόρθωση και επιστροφή στην πίστα είναι ποιο εύκολη και φυσιολογική χωρίς τις παράλογες "σβούρες" που φέρνω συνήθως...
  • Like 4
Ασ'τα αυτά! Φταίει που ήσουν τόσο καιρό χωρίς τιμόνι και έμεινες αγύμναστος!!
Δύσκολα βρίσκεις πιο φιλική μπανιέρα με ρόδες :)
Σαν το skip barber όπως είπε και ο @Stelios F.
Έγινε επεξεργασία από akis_z80
  • Like 3
Και εγω ικανοποιημενος απο το update+dlc.
Θεμα ffb δεν τιθεται στην περιπτωση μου (gamepad), οποτε δεν εχω καποιο σχολιο σε αυτο. Σχεδον την ιδια αισθηση εχω. Λεω σχεδον γιατι για πχ στις lambo το αυξησα λιγο.
Απο γραφικα δεν ειδα και καμια τρελη διαφορα, ειδικα στο hdr που περιμενα μεγαλη αλλαγη δεν ειδα διαφορα.
Τα αυτοκινητα μου αρεσουν ολα.
Στη mclaren οντως θα συμφωνησω οτι ειδα και εγω διαφορα σε σχεση με την mp12-gt3.
Το abarthακι μονο αδιαφορο δεν ειναι. Χτες επαιξα με αυτο 2-3 αγωνες multi στην brands hatch indy και 1-2 στην gp και οι μαχες ηταν επικες. Πολυ πιο ενδιαφερον για αγωνες απο το αδερφακι του. Αν το αδιαφορο πηγαινε στην αισθηση που σου δινει οδηγικα, παλι δεν μπορω να εκφρασω αποψη.
Η Brands Hatch απλα, υπεροχη.
Στο multi οσο επαιξα δεν παρατηρησα κατι προς το καλυτερο ή χειροτερο, γιατι στους σερβερ που μπηκα ειμασταν ολοι "κοντα" στο ping, οποτε δεν υπηρχε θεμα ετσι κι αλλιως.
Θελω να το δω πως δουλευει αμα υπαρχουν στον σερβερ ατομα με μεγαλη διαφορα στο ping.
Αυτα τα ολιγα για αρχη και θα επανελθω μολις ριξω περισσοτερες ωρες, γιατι κλασσικα (δεν ξερω πως τα καταφερνουν, ουτε συννενοημενοι να ηταν) χτες επαιξε και στο bf4 update και ηθελα να δω τι σκ@τα εκαναν και αυτοι εκει.
(επισης και στο R3E αλλα και στο codbo3) :wall:
Kάτι κάνεις λάθος, όλα high / medium εδώ και δεν ξεπερνάει τα 2gb ...
επανερχομαι.
gpu-z memory usage (dedicated)
1080p low settings: 1600mb
1080p max settings: 3153mb
triple 1080 δε δοκιμασα ακομα
:/ μετραω λαθος?
επανερχομαι.
:/ μετραω λαθος?
H nvidia είχε αναφέρει πριν λίγο καιρό ότι κανένα πρόγραμμα αυτή τη στιγμή δε δείχνει το σωστό vram usage. Δείχνουν την allocated vram.
