Assetto Corsa
racer
11025697_10203917938582805_2159453725164
A few weeks ago a German boy, Fabian Werner, sent us a photo he took at the Nürburgring, where he (or someone else, we do not know) he wanted to testify in his own way his passion for AC. Since we have been doing everything possible to reproduce the circuit as closely as possible, we considered his picture as a hint
  • Like 4
Link to comment
Share on other sites
Changelog Assetto Corsa 1.1
- Added ai-hints
- New penalty system
- Added Kick Quorum to the server
- Fixed sound pops and clicks for some cars engines
- Fixed traction control sound events
- Fixed Tatuus FA01 limiter sound
- Improved sound dynamics under load for some cars
- Launcher: more graceful handling of missing/problematic content
- Launcher default theme: personal best time grid filtering by car/track added
- Fixed blank resolution box
- Fixed missing sound events
- Fixed crashes volume
- Reworked envelopment for interior and exterior sounds
- Higher exterior volume for surround speaker configurations
- Fixed tyre fake shadows in slowmo replay
- Improved AI
- Added custom head movements per car (driver3d.ini)
- Driver helmet/head now cast shadows in onboard camera
- Added custom weather selection
- Improved Pedals App
- Rendering performance optimizations
- Particle rendering optimiziations
- Render Stats form now features units
- Added "final" damage for high speed impacts
- Added quality settings to replay that allow up to 4x longer replays
- Fixed driver shift preload animation at race start
- Fixed camera car not using FOV value
- Fixed AI choosing wrong (slow) tyres
- Updated FMod to 1.05.13
- Updated Fmod SDK project (minor envelopment improvements)
- Tweaked exterior reverb parameters
- Tweaked envelopment values for some sound events
- Improved positional surface sounds
- Fixed wind and tyre rolling noise
- Fixed doppler effect for rev limiter and horn
- Fixed FOV in mirrors, now editable in system/cfg/assetto_corsa.ini
- AI race starts greatly improved
- Fixed wrong shadow resolution when moving through F6 camera car cameras
- Fixed graphics not following dynamic track grip levels in Multiplayer
- Fixed "fast" height evaluation for validating setup ignoring tyre pressure
- FPS caps is now compatible with the new 1ms resolution timer
- Suicidal server admins are now a protected species and not allowed to kick themselves anymore
- Adjusted fuel consumption for most of the cars
- UI now understand fuel range relative to car and track and adjust maximum race lap count
automatically for quick races and race weekends against the AI
- Added 4WD simulation in drivetrain.ini
- Added live axle suspension geometry
- [DATA] section in aero.ini is now obsolete and must be eliminated. HEADER=2 is mandatory if
damage is used.
- AC now support multiple configurations on circuits
- A to B gameplay options for hillclimb tracks and specific circuits that support.
- Tyre pressures can now be shown in digital_instruments.ini
- Limited static weather situations can now be selected from the UI. Weather is also moddable.
- Time Attack now has a global multiplier that controls the amount of time available for the first
checkpoint.
- Customizable TrackIR rotation range.
- Chat window now supports full Unicode charset
Έγινε επεξεργασία από Zenor
Link to comment
Διαβάζω προβλήματα που σχετίζονται με τα mod. Σβήστε τα όλα. (47 mod cars και 41 πίστες = 21GB!!! είχα χαχαχα).
Επίσης κ ένα integrity validation μετά το update.
Σε κανά 15' θα ξέρω.
Έγινε επεξεργασία από liakjim
Link to comment
