gaig Νοέμβριος 18, 2012 #21 Νοέμβριος 18, 2012 μιας και κατεληξε η συζητηση στα περι pico psu, να αναφερω ενα αρθρο που ειχα διαβασει πριν λγια χρονια. Δεν παιρνει οσκαρ efficiancy, αλλα στο αρθρο αυτο ειχα διαβασει συγκεκριμενα πως Both of the above results can be attributed to the Winmate DD-24AX, which regulates all the output voltage lines. This is a major difference between the Winmate DD-24AX and the picoPSU: The latter simply passes the 12V line through from its input. In other words, the 12VDC line is filtered, regulated and protected by the Winmate, while the 12VDC line in the picoPSU is entirely dependent on the quality of the 12VDC adapter feeding its input. For this reason, the picoPSU cannot be considered as secure or reliable a power supply as the Winmate DD-24AX.Παρασυρομενος απο το αρθρο το παρηγγειλα απο ebay και απο τοτε δεν εχει κλεισει με Q8200S και zotacGF9300Winmate DD-24AX DC-DC Module for Silent, Efficient Power | silentpcreview.com
